#1 | |
Custom Belly Up Skid Build
I have been planning on building a skid for a long time. After looking at many other builds and seeing how other people did it, I made my decisions.
I found a massive (200lb.) piece of 3/16" scrap at the local steelyard and purchased it for $65. This is enough to do my belly-up and engine skid with a lot left over. One bonus about the piece I bought was that it had a 1" lip bent at 90* which helps to stiffen the skid without added weight. My initial design was to use 3/8" along the frame rails so I could counter-sink my bolts. That didn't pan out (couldn't find 3/8" scrap) and I had the 1" x 2" x .120" laying around so I decided to use that. The biggest challenge I had was lack of cutting tools. I borrowed a buddy's sawz-all and cut out my main skid. That was not fun at all and it was very difficult to cut straight. After some discussion I purchased a Dewalt 7" abrasive cut-off wheel and put it on my circular saw. Lots of sparks, but it worked like a champ to cut out my cross-brace. The next real challenge was drilling the 1" holes. I had done it before with my drill press and a 1" hole saw, but it's just a huge pain. In retrospect I would rather do the solid stock in my original plan and use countersunk allen bolts. That would have saved much time and frustration (and broken bits and 1 burned up drill )The cross-brace was cut from the scrap with another convenient bend which left me with an angle of about 6* - matching the angle of the tranny mount on the OEM skid. Material: - Skid and cross-brace: 3/16" - Side Rails: 1" x 2" x .120" Clearance gain of 2", TC moved 2". Buddy = ChiliPalmer ![]() I'm sure I'll need to notch the front for the driveshaft and I may brace the passenger side with a piece of angle, but it's very stiff with zero sag. I will be making an engine skid as well. The main components ![]() Side rails have a 1/2" hole on the top side and a 1" hole on the bottom side (to allow for counter-sinking the bolts). ![]() Put together: ![]() Mounted: ![]() ![]() Comparison: ![]() ![]()
#2 |
Very very nice!
![]() In terms of beer-hours, how long did this take you? I have a similar problem cutting metal--no plasma and not enough gallons in my air tank to run the cut-off wheel forever. |
#3 |
I have a lot of hours into it (15?) but I have more time than $$
. The final fit/welding took the better part of a day. There was a lot of skid on, skid off.I'm really happy about the 7" wheel on my circular saw, in the future it will help a lot for long cuts. |
#4 |
mmmm beefy. Too late now but you could have just cut the holes out on the edges of your plate with your circ saw. Would have done 6 holes anyway. Theres noting worse than drilling holes in thick steel such a pita. Thats what the hot knife is for (Torch)
Make sure you clean up your saw real good or the guard might stick open. The one time i used my dads circ saw for metal it did. My dad cut a nice gash in our deck when he set it down. Bought a grinder after that
1967 cj-5, 1946 Willys Jeep cj-2a, 1982 911sc turbo look, 1958 impala, 1987 k5 blazer |
#5 |
NICE
![]() I like how you have your bolts recessed. Mine are getting pretty messed up but I don't have time to fix it now. Did you reuse your stock mount? Hows the clearance above the trans? Heh I re read and saw where you said the angle matched the stock angle. So I assume you did reuse the stock mount. Still hows the clearance? Any issues with the shifter? |
#6 |
Bacon Ends & Pieces
![]() Join Date: Dec 2006
Looks good all mounted up! I'll have to look for my camera so I can post up the few pictures we took at my house.
And don't worry about the drill - I'm the one that had the fan covered up... ![]()
If you want to help the sport of offroading visit the EnviroBeat Forum! Blue Ribbon Coalition | Idaho State 4x4 Association | UFWDA | NAXJA | The KAT Team! |
#7 | |
I think I'm going to have to throw a couple washers under the tranny mount as my TC is barely touching the skid. It's livable, but I'm going to fix it. |
#8 | |
I netted 4" of clearance gain, but that was measured from the lowest part of the stock skid compared to my flat skid. I ignored the fact my bolts are now the lowest point of my skid. I do plan to recess them but want to get some solid stock to drop the skid slightly. Then drill 1" holes in the current skid and 1/2" holes in the solid stock. Basically like your original plan with the 3/8" stock. Were you able to do this with your BB and no SYE? With the TC raise of 2" + the 2" BB is 4" of relative lift. Any vibes? |
#9 |
I just received my SYE today. I'll be installing it this weekend and I'm waiting on my control arm bushing sleeves to get here so I can get those built.
#10 |
Update:
After driving it more than around the block, I have decided that what I thought (by hearing) was the TC rubbing the skid, must just be TC/Tranny noise in general. I'm driving in FWD/4H right now until I get my SYE/Driveshaft installed and the noise I'm hearing sound like the extra TC noise you hear when in 4H. That and the fact that everything is a little closer to the body. If the TC were actually touching the skid, I believe it would be really loud. |
#11 |
so your driving in front wheel drive?
also, did you just mount your tranny/t-case to the skid? So just one piece?
1997 TJ 4.0 5 spd. rock track 4:1, 3.5 inch Rock Krawler 5 inch stretch long arm, 35 inch MTRs, Warn 9k, D44/30 locked with 4:88s, Vanco BIG BRAKES!!and more... |
#12 |
Looks Great make me one for my YJ please.....
#13 |
Yes. I'm installing my SYE this weekend. My final parts for my control arms come in tomorrow so I can build those and then I'm getting a front Explorer CV shaft cut down.
The tranny mount bolts to the skid. I will take some more pics of the top side all welded up when I pull it back off this weekend. |
#14 |
Bacon Ends & Pieces
I found my camera but my new laptop doesn't have an SD slot so I can't get them to the computer yet...
#15 | |||
Disgruntled Jeepforum'er
Location: NY/NJ/PA Tri-State Middletown NY 10941, New York
I'm interested in those pics. Subscribed. Good work on this and the control arms.
-Ryan Google Voice (or the number Grape calls when drunk): 845-476-8182 Quote:
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
