Crossmember Drop / Reinforce - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Fabrication Shop > Crossmember Drop / Reinforce
Paracord grab handles, door limiting, etc at JeepHut.comRough Country Deals at JeepHut.comNew! JK/U skid plate system.
Unread 05-03-2015, 09:11 PM   #1
McColorado
I just installed a 3.5" lift kit on my 94 Zj, and in the process of attempting to install the t-case drop, I have broken a cross member bolt, and one other just spins. Now, I could go and tear apart the interior in an attempt to gain access to these bolts, however, I have some experience welding, and have some scrap metal to work with. Here is my thought: use a 1" steel tube and some 3/16" plate to make myself a t-case drop bracket. I would weld and bolt the bracket to the frame, and bolt the cross member to the bracket using grade 8 hardware. All the joints between bracket and frame would be welded together. Here is my general idea:
So my question is: would this work? I'm just trying to find a way around the weak bolts, and thought this could be an effective solution. Any advice would be greatly appreciated!
The Jeep in question:
Project Ugly Betty
http://www.jeepforum.com/forum/f22/97-zj-ugly-betty-build-2948561/
McColorado is offline   Reply With Quote Quick reply to this message
Unread 05-08-2015, 03:52 AM   #2
bdmead01
Your design seems solid, but I think the problem is with the crappy nutserts. You would think Jeep would have changed their design by now...
'00 RED Sport: 4.0L, 32rh, 3.07's and 31's
bdmead01 is offline   Reply With Quote Quick reply to this message
Unread 05-08-2015, 07:03 PM   #3
underpowered
Bouncin' on a Budget
underpowered's Avatar
to keep from crushing the uniframe and properly torque the bolts that appear as if they would go all the way through it, a small tube should be welded in place through the frame before the bolt is put through it.
1998 ZJ-- lowered a touch
2000 powerjoke tow pig
Anti-jeep--1989 K5 blazer. the new off road ride
underpowered is offline   Reply With Quote Quick reply to this message
Unread 05-08-2015, 07:14 PM   #4
jason m
Nothing but the facts
jason m's Avatar
A chunk of tube is needed as underpowered said to keep the sides from crushing. And if it were me I would run the 3/16 plate on both sides, yes this means it needs to get a bend in it, well really two but adding it on both sides ensures it won't go no ware.
Jason.
1993 YJ 4.0 60 Front, Rear steer 60, bolth spooled, 5.38's, 700r/241 39.5 iroks and beating it like it owes me money.
And on the 8th day, God created the 14 bolt....
jason m is offline   Reply With Quote Quick reply to this message
Unread 05-08-2015, 08:00 PM   #5
JeeperDon
Join a 4x4 Club
JeeperDon's Avatar
Do it right. Just fix the bad nuts in the frame. Weld a nut on a small plate. Make a hole in the frame at the dead nuts (cut them out) just big enough to finesse the plate inside the frame, then weld the plate with the nut to the frame.
'93 YJ, '02 GM 4.3 Vortec V6, SOA, dual ARB's, 8.8+D30(w/WarnHubs), 4.88 gears, 35" BFG KM2's, AX15, 15x7 wheels, NP231+4:1+SYE+2LO, York OBA, Warn M8000, no top or doors Apr-Oct.
Member and Web guy: New Mexico 4 Wheelers My Truck Page on NM4W Site
JeeperDon is offline   Reply With Quote Quick reply to this message
Unread 05-10-2015, 11:19 PM   #6
McColorado
Thought I'd throw a quick update on this -- Decided to just do it right. Got some grade 8 hardware on the passenger side with nuts welded to the inside of the frame, I welded the floor back in place, siliconed it to make sure it won't leak, and painted it to hopefully not have to deal with rust down the line.
Project Ugly Betty
