creating a tire carrier on stock bumper - JeepForum.com
post #1 of 15 Old 10-03-2012, 12:49 PM Thread Starter
Tkoffroad
I want to create a tire carrier on my stock rear bumper does anyone have any idea. Any input would help thanks
2001 60th anniversary edition Jeep Wrangler 33 inch General Grabber AT2 Spectre cold air intake
Tkoffroad is offline
post #2 of 15 Old 10-03-2012, 02:03 PM
Jason
I don't think the stock bumper will support the extra weight of a carrier + tire.
Jason is offline
post #3 of 15 Old 10-03-2012, 02:41 PM
ltrail
1984 XJ Cherokee
I second the weight issue. But if you are up for building something like this maybe build it to look like stock but more rigid for the added weight. Would be a good time to think about recovery points also. Maybe a few D rings?
84 xj 350tbi, sm465, 203/205, 60/70. links and other junk.
what size sawzall blades does it take to fit 40's?
ltrail is offline
post #4 of 15 Old 10-03-2012, 02:45 PM
sjones26573
The stock bumper is basically tin foil. It would crumple under the weight.
The Offroad Club @ NC State; Founder
The Yellowtail Build
Jeep-Owner.com
sjones26573 is offline
post #5 of 15 Old 10-03-2012, 02:47 PM
Jason
Something that looks like this perhaps?
Jason is offline
post #6 of 15 Old 10-04-2012, 12:21 PM Thread Starter
Tkoffroad
Ok thanks guy can anyone recommend a bumper with a tire carrier that looks close to stock a possible
post #7 of 15 Old 10-04-2012, 01:10 PM
Apostle
Try looking at an XJ (cherokee) stock tire carrier. It is tied into the unibody with L brackets, then tied again onto the bumper. when all said and done, you have a C around the bumper and the carrier is part of that C.
Here is the one i did on an old rig. it was a pre 97, put onto a 97.
"To learn who rules over you, simply find out who you are not allowed to criticize.”
–Voltaire
Apostle is offline
post #8 of 15 Old 10-04-2012, 02:41 PM
Diamond-x
1991 XJ Cherokee
If you used the stock bumper as a skin that fit tightly over an internal structure you could make it work. But personally, I think a custom bumper could be made to look nicer than the stock unit.
Diamond-x is offline
post #9 of 15 Old 10-04-2012, 07:10 PM
sailsurf7713
Genright's mimics the rear crossmember. What size tire are you running?
What do you mean by stock? Tin bent into a squarish profile with some milk jugs shoved in the end?
'99 SE: The "It could be worse..." jeep
Originally Posted by 97flexy View Post
...I say don't lift but CUT. :)
sailsurf7713 is offline
post #10 of 15 Old 10-05-2012, 06:29 AM
monkers
2010 JK Wrangler
Aev makes a carrier that will work with the stock bumper. Ties to the frame not the bumper
2010 Rescue Green 2 Door 6 Spd, 2.5" RK Max Travel, Fox 2.0 IFP Shocks, 37" Nitto Trail Grappler M/T, EVO Sleeves, Gussets, Mini Skids, Rock Stars, Poly Perf Long Travel Upper Shock Mounts, Poison Spyder Evap Skid, Diff Covers, Grab Handles, Cobra 75WXSt, Stern Cibie/Osram Light Upgrade, Mopar Heated Seats, Trimmed Flares & Bumpers
monkers is offline
post #11 of 15 Old 10-05-2012, 12:27 PM Thread Starter
Tkoffroad
Did you make this cause it is pretty awesome and I am running 33
post #12 of 15 Old 10-05-2012, 12:36 PM Thread Starter
Tkoffroad
What is the aev carrier called
post #13 of 15 Old 10-05-2012, 12:57 PM
Apostle
No, its a stock pre-97 cherokee carrier (few were put on over its lifespan). I jsut modified it to fit my 97.
but you can see how it is a plate with the carrier on it, then behind the bumper is another plate (bumper is sandwiched between) with all the mounts for the frame/unibody
–Voltaire
Apostle is offline
post #14 of 15 Old 10-07-2012, 05:18 PM
CaseyTibbs
The original owner built this for my TJ.....
Its on my short list to be replaced but it certainly is structurally strong and does what it was intended to do.... not the greatest fabrication skills but very functional.
My very slight contribution was to add the HL Jack mount and shovel hanger:
Whats under the passenger seat now....
Stock bumper plus +++
"This ain't my 1st rodeo..."
Casey Tibbs;
St. Joseph's Hospital Emergency Room
Deadwood, SD
August 1959
CaseyTibbs is offline
post #15 of 15 Old 10-08-2012, 05:26 AM Thread Starter
Tkoffroad
Looks great thanks
