Countersinks for 3/16" steel - JeepForum.com
post #1 of 7 Old 05-13-2013, 02:14 PM Thread Starter
CJ7ROB
Anyone know what type of countersink armor manufacturers like Poison Spyder use to countersink the holes in their armor? Particularly their crusher corners.McMaster-Carr has the countersinks in all different angles, but I'm not sure which one to go with, thanks.
I need one like this for these type of bolts.
http://shop.poisonspyder.com/CJ-7-Re...4-010-alum.htm
CJ7ROB is offline
post #2 of 7 Old 05-13-2013, 05:16 PM
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
If you've got the bolts, you can just mike the heads to see what diameter you'll need.
Even without the bolts, if you know what size you're going to use (5/16" Countersunk Allen Heads for instance), you can look up their dimensions online to see which bit you'll need.
I'm not at the shop right now, but I think I use a 5/8" bit to get a good fit with 5/16" allen heads going thru 3/16" plate.. I could be mistaken though.
BESRK is offline
post #3 of 7 Old 05-13-2013, 07:07 PM Thread Starter
CJ7ROB
Thanks Eddie my bolts are 3/8" and the diameter of the head is 3/4" Do you think I need a 3/4" countersink bit? Also how do I properly check the angle so I get the right bit? Thx It looks like it just may be a std 45 degree bit.
CJ7ROB is offline
post #4 of 7 Old 05-13-2013, 09:42 PM
popascj7
1976 CJ7
Standard machine screws have an 82 degree angle.
popascj7 is offline
post #5 of 7 Old 05-14-2013, 03:10 PM
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
If the bolt head is 3/4" dia, then the 3/4" bit would allow a perfect fit flush with the surface of the sheet. The issue then becomes the "thickness" of the head. If the head of the bolt is thicker than 3/16", then it will protrude above the surface.. or, you'll have to make the hole (in both the 3/16" and the sheetmetal under it) big enough for the bolt head to drop in all the way.
When I was digging around for my countersink bit, I think I went with 5/16" allen head countersunk bolts because the head thickness worked out to be about 3/16" thick.
BESRK is offline
post #6 of 7 Old 05-15-2013, 01:27 PM Thread Starter
CJ7ROB
Oh I see what you mean. I'll have to play with it to see how deep the head goes into the metal. Thanks for the info.
CJ7ROB is offline
post #7 of 7 Old 05-22-2013, 07:46 PM
Copperhead89
Correct. SAE flat head machine screws are 82 and metric flat head machine screws are 90.
My YJ/CJ V8 Magnum Build: http://jeepforum.com/forum/f22/magnum-force-mopar-mans-build-1412306/
Copperhead89 is offline
