converting a ford axle - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Fabrication Shop > converting a ford axle
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineRaceline/Allied Wheels on Sale NOW !Bead Lock Wheels! Raceline, Trail Ready, & Trail-Gear
Unread 07-10-2004, 10:44 AM   #1
Down&Dirty
So I am looking to rebuild a Ford 8.8 to fit under my TJ. Does anyone know of any good write ups for this? Also, what kind of welder is going to work best for attaching all the new brackets? I have a small wire feed, but there is no way it will cut it. Can I just hit it up with a stick welder? I hope so, this is where most of my experience is. Can the control arm mounts be raised up to make the bottom of the axle clean? I could just keep posting question after question about this so give me your input and help me clean up the idea.
53 willys wagon with less of rust and no more bugs. Now sporting a 1988 wagoneer frame, amc 360, dana 44's.
'80 CJ-5, full width, 3 link front, 1/4 elliptical rear, 38's, and propane.
Down&Dirty is offline   Reply With Quote
Unread 07-10-2004, 03:36 PM   #2
77'cj7
Quan has this one in his signature
http://members.cox.net/quanno/ford88.html
there are some good writeups at the bottom
'06 Rubi Unlimited, 2" bb, 32" swampers, bumpers, sliders, and skids
77'cj7 is offline   Reply With Quote
Unread 07-10-2004, 05:34 PM   #3
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
Haven't messed with TJ brackets...yet. However, 220 stick will be fine for the rear axle. That's what I used until I bought my Lincoln 175 wire feed. Without looking at a TJ's mounts, I don't know about moving the mounts up to gain clearance. I would however, be careful about throwing off the 4 links geometry unless you are well versed in suspension design and setup. Good luck!!
'80 CJ5 w/AMC360, T176, D44 w/Detroit 3.73s, RE 4" YJ lift and 35s..
Ground Pounder Fab
Lower 2
Guardrail
Down Schoolbus
Slickrock Tellico
Save
Crozet
More Crozet
BESRK is offline   Reply With Quote
Unread 07-13-2004, 02:45 PM   #4
Down&Dirty
How about a lincoln weld pak 100? I just got access to one this morning. No gas attachment but I am working on the bossman to get one added.
Unread 07-23-2004, 10:13 PM   #5
Crash&Burn
For the brackets I would recommend a DC stick welder, and a expedienced if not certified welder..........have seen accidents in racing caused by failed brackets...not petty
1979 CJ7 (YJ tub) full cage, Currie 9inch rear with Warn full float kit, detroit locker, 456 gears both ends, Lockrite in front, T 18 trans, 360, 040 over, Isky cam, 2 into 1 Flowmaster exhaust
I'm not as good as I once was....but I'm good once as I ever was.
Crash&Burn is offline   Reply With Quote
