Coilovers on a DD? - JeepForum.com
post #1 of 4 Old 09-27-2010, 11:14 AM Thread Starter
LOCAL
Coilovers on a DD?
Figured someone in here could help me out, im wondering how coilovers perform on the street. Ive read about people saying they will heat up and not work properly, but that dosent really make any sense to me since they run them trophy trucks, and monster trucks. Does anybody have any insight to this, or have experience running them on the street. They would be in the front, with coil 4 link or leaf springs in the rear.
LIVEforTODAY
LOCAL is offline
post #2 of 4 Old 09-27-2010, 07:34 PM
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
All they are is a high quality shock (normally) surrounded by the springs. They should be fine for street use provided the suspension is setup properly.. spring rates, antisway bar...etc.
BESRK is offline
post #3 of 4 Old 09-27-2010, 07:35 PM
mikes_muse
X2. I ran coilovers up front, 4 linked rear with reg springs and shocks on my old DD, never any issues at all. Rode great.
mikes_muse is offline
post #4 of 4 Old 09-28-2010, 01:53 AM
Warlord2
They work fine, but need to be setup correctly. Just make sure whoever your buying them from knows what they will be going under so they can valve/pressure them for you. They can be very stiff/soft if not setup correctly and tuned for your vehicle.
07 JK 2D X model with 6 speeds. Full Traction 3" ultimate lift kit. 315x75x16 Toyo Open Country M/T on Rock crawler procomp rim. Ruby dana44's front sleeved inside/outside C truss and rear with 5.13's gears. Homemade rock guards, rear bumper w/tire carrier, oilpan/tranny skid, evap canister skid, light bar, switch pod. Riddler diff covers, Cobra 75 w/wilson antenna, Polk speakers, 10" sub, 2x Amps, Lightforce 240 drive light, backup lights, rock lights.
Warlord2 is offline
Coilovers lasvegasjeeper Fabrication Shop 6 02-20-2009 08:36 PM
Opinions on coilovers jw98tj Tires & Wheels 1 04-04-2005 10:08 PM
Coilovers or 1/4 eliptic JEEPIN_I_AM Tires & Wheels 2 03-21-2003 03:01 AM
Coilovers Gator Tires & Wheels 1 10-15-2002 11:50 AM
