cnc plasma cut rear corner guards tj - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Fabrication Shop > cnc plasma cut rear corner guards tj
New rockridge 4wd sales rep!!!FS: Wranger BRIGHT License Plate LED! Just $3! Great valueTJ BDS 2" suspension lift!! FINALLY a GREAT 2" l
Unread 12-03-2014, 06:42 PM   #1
Gavpowell
Hi all, I was thinking about cutting my own rear corner guards for my tj. want to do the cj tailgate conversion and the round led taillights. So after all that I wouldn't have to draw holes for the hinges. just the round taillights, license plate and the fuel cap. anyway, I was planning on using our cnc plasma cutter in class to cut from some 14 or 16 gauge steel. you can either draw your cut paths on the computer program or you can cut using a picture from the internet (to some extent). I am probably only a little less than an expert at the operation and could probably eventually draw the shapes I need BUT
I was wondering if anyone could give me ideas on how to go about it. Like should I measure from tailgate all around to where I want the guard to end and go from there? how should I go about the wheel arch? Does anybody have a flat layout picture of their corner guards before bent?
anyone familiar with cnc plasma cutting or the DesignEdge program any input?
I guess I could draw it out on paper or something but any help would be greatly appreciated!
"Jeeps don't get stuck, they just take quick naps... in deep holes... that sometime require an external force to be awoken." Anon "Everybody strap in... we're about to open some f***ing windows." Samuel L. Jackson
Gavpowell is offline   Reply With Quote Quick reply to this message
Unread 12-04-2014, 12:37 AM   #2
YoungGun
Start with cardboard and tape. Mock up what you want to do, then lay it back out and take measurements
There is no "I" in jeep. Just a lot of money.
YoungGun is offline   Reply With Quote Quick reply to this message
Unread 12-04-2014, 11:42 AM   #3
Gavpowell
wow thanks guess I should have just thought about it before making the post.
Unread 12-10-2014, 08:01 AM   #4
NalinMFG
Do you have a way to bend the radius?
[URL="http://www.NalinMFG.com/"][SIGPIC][/SIGPIC][/URL]
[URL="http://www.jeepforum.com/forum/f43/tj-5-25-speaker-adapters-nalinmfg-1325275/"]5.25" TJ Speaker Adapters[/URL]
[COLOR="DarkOrange"]
Linkedin:[/COLOR] [URL="http://www.linkedin.com/pub/andrew-nalin/30/65/825/"][B]Andrew Nalin[/B][/URL]
[COLOR="DarkOrange"] Email:[/COLOR] [B][email]NalinMFG@gmail.com[/email][/B]
[COLOR="DarkOrange"]Website: [/COLOR][B][URL="www.NalinMFG.com"]www.NalinMFG.com[/URL][/B]
[COLOR="DarkOrange"]Facebook: [/COLOR][B][URL="www.Facebook.com/NalinMFG"]NalinMFG[/URL][/B]
NalinMFG is offline   Reply With Quote Quick reply to this message
Unread 12-10-2014, 02:53 PM   #5
Gavpowell
I was planning on using an oxy acetylene torch to heat it up and slowly bend it around something with a similar bend. I have plenty of materials so if that doesn't work I can figure something else out. Do you have any better ideas to bend it?
Unread 12-10-2014, 06:54 PM   #6
NalinMFG
I've seen guys on here do it that way...I know it was a PITA making a die for production repeat-ability. A press and a 6"OD pipe would be a good place to start!
Unread 03-20-2015, 04:33 PM   #7
aggiejon
1979 CJ7
I drew mine up for my cj. I used 14 gauge and cut holes for round led lights on the Cnc table. I just mounted it up under the tailgate and worked it around the tub. No press or die.
aggiejon is offline   Reply With Quote Quick reply to this message
