Clutch, hanging pedals, tilt column - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Fabrication Shop > Clutch, hanging pedals, tilt column
Year End Clearance Sale! Save 20%Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineNEW!! HMF 50"-52" light bar mounting brackets!!
Unread 12-24-2014, 04:06 PM   #1
PreacherPat
1960 CJ3B
I am attempting to put Saginaw steering in my CJ3B, I am using a frame from a 1973 CJ5 and the power steering box. I need advice (pictures, dimensions, drawings, anything that would be helpful), I am putting in a tilt steering column and hanging/swinging pedals from the CJ5. I also would love to get advice on the clutch, since I am going with the newer pedals, do I need a longer fork for the throw-out bearing and any help for clutch linkage would be greatly appreciated. I am using a 225 cu. in. Buick V-6, with a Borg-Warner T-10 4 speed, Dana 18 transfer case.
PreacherPat is offline   Reply With Quote Quick reply to this message
Unread Yesterday, 04:53 PM   #2
Jim1611
Jim1611's Avatar
You'd likely get better responses in the CJ section.
www.crabtreetool.com (Crabtree Shackle Hangers)
My build thread
http://www.jeepforum.com/forum/f8/ji...build-1093702/
Jim1611 is offline   Reply With Quote Quick reply to this message
clutch linkage , tilt column
