CJ7 High Steer Kit - JeepForum.com
post #1 of 44 Old 06-15-2010, 12:55 AM Thread Starter
Sportinwood
CJ7 High Steer Kit
Hello again all
I have almost finished up my custom high steer setup on my Cj7. I really like the way it is turning out and I am thinking of building a few more to sell. I just thought I would run my idea by you guys/gals to try to get an idea of how many people out there might be interested in a cheep, durable, and easy to install high steer setup for a SOA Dana 30 on a cj. My design will raise the drag link above the spring while leaving the tie rod in it's original position. No need for a drop pitman arm and very little fitting is required to install it you don't even have to take the knuckle off and it will beef up the stock knuckle too. Any input would be appreciated...
Thanks
Sportinwood is offline
post #2 of 44 Old 06-15-2010, 01:23 AM
ImpactFabWorks
Pictures go a long way
1990 YJ = The Toy/ My Daily Driver
1996 XJ= Wifes Daily Driver
Please fill out your profile, It helps us help you!!!
ImpactFabWorks is offline
post #3 of 44 Old 06-15-2010, 01:26 AM Thread Starter
Sportinwood
Sure when I get it all finised up and put back together pics will be posted. I am building a beefy drag link to go along with it right now so it may be a few days.
post #4 of 44 Old 06-15-2010, 04:40 AM
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
Make sure to upgrade to a Vendor Account before you post your pics and advertise your stuff for sale. Not fair to the paid Vendors if you don't.
BESRK is offline
post #5 of 44 Old 06-15-2010, 06:17 AM Thread Starter
Sportinwood
I will upgrade if I start selling them but Im not really a vendor im just trying to see if anybody would be interested and if you guys think its a good idea or not. Just looking for some feedback from the pro's..
post #6 of 44 Old 06-15-2010, 02:43 PM
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
Roger that
Now.. we need pics.. closeups..
BESRK is offline
post #7 of 44 Old 06-17-2010, 10:06 AM
shu2kill
Hello again all
Thanks
isnt that a crossover steering, rather than a true high steer??
shu2kill is offline
post #8 of 44 Old 06-17-2010, 10:59 AM
ImpactFabWorks
Yea that would be a cross over.
post #9 of 44 Old 06-17-2010, 11:31 PM Thread Starter
Sportinwood
I guess thats what it would be because im only moving the draglink...
post #10 of 44 Old 06-18-2010, 07:14 AM
shu2kill
ok. so, where are the pics?? i would like to do that to my YJ, but it has Wagoneer D44s now.... do you think it would be possible??
shu2kill is offline
post #11 of 44 Old 06-19-2010, 12:28 AM Thread Starter
Sportinwood
The pics are coming soon I just painted it up tonight and I will put it back together in the morning.. I dont think this bracket will work for the d44 with the flat top knuckles but the crossover kits for the d44 are alot cheeper then they are for the d30. I think all you need for the d44 is a couple of plates that bolt on to the top of the knuckles...
post #12 of 44 Old 06-19-2010, 12:42 AM Thread Starter
Sportinwood
Here check this out I think this is all you need to but you may have to have your knuckle machined.. Double check before you buy it because I'm not sure. Make sure you read the add on E-Bay too.
"We offer through holes up to 3/4" for free, tapering for your TREs' available for $7.50 per taper, we offer Scout II, Ford, Dodge, F.S. Jeep and GM tapers. We do not offer the small Jeep CJ, YJ, TJ, XJ, ZJ, or WJ tapers."
If you have the small taper TRE's you would have to buy a reamer..
If you want a true high steer you need a differant kit that comes with plates for both knuckles but they are not much more I think around $100 or so on E-Bay..
CNC machined Dana 44 RH high clearance steering arm: eBay Motors (item 380243281921 end time Jul-15-10 21:56:21 PDT)
post #13 of 44 Old 06-20-2010, 04:17 AM
KMD
1976 CJ7
Waiting on pics.
KMD is offline
post #14 of 44 Old 06-20-2010, 04:00 PM Thread Starter
Sportinwood
Ok here are some pics. of the crossover setup I built let me know what you guys think of it…
This is before
Before.jpg picture by sportinwood - Photobucket
This is the stock positioning of the drag link and tie rod end
StockTREDlink.jpg picture by sportinwood - Photobucket
This is how I positioned the new drag link before I built the bracket
Newdlinkpositioning.jpg picture by sportinwood - Photobucket
This is a pic of the knuckle after the drag link was removed
NewDlinkPositioning2.jpg picture by sportinwood - Photobucket
Machining the bracket
Machiningthebracket.jpg picture by sportinwood - Photobucket
Dry fitting everything before I painted it
DryFitting.jpg picture by sportinwood - Photobucket
Another view dry fitted
Dryfitting2.jpg picture by sportinwood - Photobucket
Close up finished
Closeupinstalled.jpg picture by sportinwood - Photobucket
Another close up
Closeupafter.jpg picture by sportinwood - Photobucket
Finally all finished
After.jpg picture by sportinwood - Photobucket
Can someone please unclick these for me so everybody can see?
Thanks
post #15 of 44 Old 06-20-2010, 07:10 PM
timatoe
timatoe's Avatar
Ok here are some pics. of the crossover setup I built let me know what you guys think of itů
This is before
Close up finished
Another close up
Thanks
Click Free
FYI, in the future paste the "img" tags rather than the "url" tags.
timatoe is offline
cj , custom , high steer
high steer set up nj95yj Fabrication Shop 4 03-25-2010 12:16 PM
Is this High Steer any good? dementedwombat Engines & Drivetrain 1 03-08-2009 05:36 AM
High Steer kit for TJ?? WillRyan Tires & Wheels 4 04-21-2008 06:50 PM
reverse tie rod mount for high steer jipjip Engines & Drivetrain 4 12-20-2006 09:30 AM
high steer mean green Tires & Wheels 3 02-25-2004 03:39 AM
