CJ Skid Plate - JeepForum.com
post #1 of 8 Old 12-01-2007, 07:46 PM Thread Starter
dirtman13
dirtman13's Avatar
2007 CJ7
CJ Skid Plate
So after having to repair my stock skid plate after almost every run I decided it was time to build my own out of some stronger material. After much research I came up with a design. I started by getting some 1 1/2"x.120 ERW tubing and borrowing a tube bender from one of my buddies. That's when I learned that bending tubing is not that easy. After much research I decided that the Pro Tool instructions was how I was going to do my bends. This is the link to their instructions. http://www.pro-tools.com/pdf/105.pdf
The bender I used is a Pro Tool MB 105.
I thought that .120 would be hard to bend in a manual bender but I have to say it bends really easy.
Once I finished the bends it was time to figure out the best place for the tubing. There is defiantly a limit to how far forward you can go because of the front drive shaft. Also in this picture you can see the stock skid plate that is beat to crap.
Once I got all the clearances figured out it was time to add some strength. For this to look clean I needed to notch the tubing as clean as possible. I picked up this drill press for $40 and bought a 1 1/2" hole saw. This was quite challenging but It work out great.
After I figured out the press (long story) I was home free and things went really smooth.
Once the cross tubing was complete it was time for the transmission mount. For this I used 1/4" steel plate.
After I got the transmission mount welded it was time for the tabs that would hold the aluminum plate on. For this I used 1 1/4"x1"x3/16" stock.
Now it was time for the aluminum. I used 1/4" for this. Again you will see the piece of junk stock skid. Things were starting to look good and I was happy with the results so far.
Then after about 9 hours and about $200 dollars I was done (except paint). I figured I came out ok as I still have lots of material left for future projects and I have seen similar skids for over $400.
All in all I"m very happy with the results. I would have really liked to just installed a piece of 1/4" aluminum flush with the frame but this was not possible. Now I can't wait to test it out.
dirtman13 is offline
post #2 of 8 Old 12-01-2007, 08:18 PM
bairy
Looks great.
I would have looked into UHMW instead of the aluminum for cost and "slidability". I never liked aluminum and rocks.
2006 LJ Claytonized
1999 TJ stockish
1987 J20
bairy is offline
post #3 of 8 Old 12-01-2007, 08:37 PM
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
Perfect timing on this! I am installing 4 to 1 gears in my D300 and also picked up a clocking ring. Plan is to build almost exactly what you did but I'll probably use steel and UHMW plastic. That stuff is great! I have it on the belly skid of my buggy.. slides really well on the rocks.
Great job!
BESRK is offline
post #4 of 8 Old 12-02-2007, 10:47 AM
Fatman
Fatman's Avatar
2008 CJ7
What a nice job. Going to have to make one of these for mine.
Simple, clean, efficient design.
Let us know how it holds up after your run.
Thanks!
Thread Links:
Fatman is offline
post #5 of 8 Old 12-02-2007, 03:46 PM
Exparrot
Exparrot's Avatar
Looks real good. I've been asking around about something like that for my YJ, I think I might just have to borrow your design idea.
I got a Jeep, it's lifted and it's got crap bolted to it.
Color by Rattle-Can.
LO Jeep Club #111 [and not proud of it]
Red Jeep Club #MC399
Exparrot is offline
post #6 of 8 Old 12-03-2007, 08:14 AM Thread Starter
dirtman13
dirtman13's Avatar
2007 CJ7
Thanks guys. I tried it out yesterday. I found myself actually looking for boulders. Skid worked great. Very durable.
post #7 of 8 Old 12-09-2007, 01:42 PM
puggles
Yep looks like a professional job.
Do you think the 1 1/2"x.120 ERW tubing would be stong enough for a roll bar? I have a single bar and would like to modify to cover the from 2 seats.
Really good job here's to ya
puggles is offline
post #8 of 8 Old 12-09-2007, 11:59 PM
tahoe wheelers
tahoe wheelers's Avatar
I used the 1.5" x .120 ERW for the two in bars on my roll cage and for my radiator hoop and stinger. Dont really care if it gets mashed as long as it prevents damage to the rig.
1985 cj 7. 360 V8, 35X12.50 BFG's sitting on Crager 15X8 rims, summer brothers axle rear, Yukon axles up front, lock rite lockers front and rear, 5" of lift, body armor, six point roll cage, 8000lb warn winch, 4.56 yukon gears front and rear, t-18, dana 300. And much more on the way.
color="Blue">www.reno4x4.com
tahoe wheelers is offline
Skid Plate Jeeptj2006 Engines & Drivetrain 0 05-30-2009 12:24 PM
YJ Transmission Skid Plate fataltherabbit Engines & Drivetrain 5 11-25-2008 08:53 PM
best skid plate material known to man mike_dippert Fabrication Shop 35 08-30-2006 05:06 AM
steering box skid plate, rocker panel, engine skid plate base shakers Fabrication Shop 2 07-27-2005 11:49 AM
Radiator Skid Plate themajor Fabrication Shop 0 08-04-2004 11:11 PM
