CJ bumper - JeepForum.com
post #1 of 8 Old 09-27-2003, 06:23 PM Thread Starter
firegod33
1977 CJ5
CJ bumper
It's not quite finished, yet. Hopefully, tomorrow.
Earth first... We'll Jeep the other planets later.
firegod33 is offline
post #2 of 8 Old 09-29-2003, 05:56 PM Thread Starter
firegod33
1977 CJ5
Well, it's "finished". I am thinking about adding two more tubes to the hoop, to give it some more strength.
post #3 of 8 Old 09-30-2003, 10:40 AM
dzp
dzp's Avatar
Looks good. What material did you use? Looks like a 2x6 or is it 2 pieces?
Tyler, Texas
97 TJ, Red, 33" MTR's, Locked F/R, D30/Ford8.8, JKS Disco's, DT3000's, tinted Sailcloth top, 8k Ramsey, Custom bumpers/armor, Ramps 890 on 25degree ramp.
dzp is offline
post #4 of 8 Old 09-30-2003, 12:24 PM
MudLover
MudLover's Avatar
That's pretty sweet. Only thing I'd suggest (though I don't weld so I dunno how hard it would be) would be D rings and Light Tabs. All in all I think it's cool, and I like your idea of the extra hoops.
Marc
1979 CJ5 project
"Life is an issue of mind over matter. Ya see, I don't mind, and well...you don't matter."
Red Jeep Club Member #2
MudLover is offline
post #5 of 8 Old 09-30-2003, 12:41 PM Thread Starter
firegod33
1977 CJ5
It's one piece, 2"x6"x3/16". I goofed when I welded on the mounting brackets and put the seam of the tube in the front. Oops. I want to put D-rings on it, but only have a 110 volt welder. That's a critical item and I would feel better if those were put on with a 220 machine.
post #6 of 8 Old 10-01-2003, 12:34 PM
dzp
dzp's Avatar
The 220 welder would be better, but you can weld it with a 110. Just bevel the pieces to get full penetration and run several beads to fill and strengthen. I use 3" x 5" x 3/16' and even weld an additional 1/4" plate on the front around the mount for better distribution of the stress.
Tyler, Texas
dzp is offline
post #7 of 8 Old 10-10-2003, 12:06 PM
TG CJ7
I want to put a nice hoop on the front of my bumper also. Yours looks great. How did you bend it, do you have a tube bender? Did you just heat it and bend it.
Looks great
1979 CJ7 Renegade 304, 3spd, 2.5 BDS lift, Hedman headers.
Check it out
TG CJ7 is offline
post #8 of 8 Old 10-10-2003, 01:02 PM Thread Starter
firegod33
1977 CJ5
For now, I only have a cheap hydraulic pipe bender. Up close you can see that the bends aren't perfect. I will have a garage, soon. That = JD2. JD2= all kinds of cool stuff, being built!
Does anybody have design plans for an XJ front bumper or rear bumper RescuedJK Fabrication Shop 1 03-15-2010 05:58 PM
What Bumper!!!! wyo69 Fabrication Shop 2 04-19-2009 03:50 AM
Where to find rear bumper w/integrated rear hitch in bumper? djaychris General Jeep & Off-Road Equipment 15 01-09-2006 08:29 PM
94 ZJ homemade rocker guards, front bumper, rear bumper? haywood Fabrication Shop 1 12-17-2004 04:11 PM
Smitty Built Bumper to the way it should have been built bumper V8wrangler_idaho Fabrication Shop 1 10-21-2002 12:53 AM
