Quantcast Chosing an Entry Level Welder.... - Page 2 - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Fabrication Shop > Chosing an Entry Level Welder....
GR8TOPS Introduces the Exogate HD Tire CarrierThe Original 3/8" Ruffstuff Diff Cover!Ruffstuff Axle Simple Swap Kit!
Old 08-29-2008, 12:18 PM   #16
jgorm
Upgrading can be expensive. If money is an issue, just get a stick welder instead of a low quality mig. If you go mig, get one with gas and 220V if you ever may want to do 1/4". I started with a O/A torch, then got a millermatic 180, then a old school Miller dialarc 250 AC/DC tig/stick with the watercooled torch. I should be ok for a bit as far as welders go, but i still need a plasma torch.
jgorm is offline   Reply With Quote
Old 09-02-2008, 09:09 AM   #17
joemac421
I was looking at the Hobart 140 myself and I like their products, I did however spend more and I got the Miller 180 w/AutoSet. I have not been unhappy with it's performance. It's roughly $150 -$200 more than the Hobart 140 but well worth it. If you are stuck on a 110 machine then get the Hobart Handler 140 I am sure you won't be dissatisfied.
Better to have Jeeped & Rolled Over then to never have Rolled Over.
joemac421 is offline   Reply With Quote
Old 09-02-2008, 09:44 AM   #18
LaCeS OuT
1994 ZJ
I have the HH140 because I dont have a 220 outlet in my garage and I wasnt going to put one in. So far the HH140 is working great. Still havent used gas with it yet.
Jeep Sold! 02/2009
Need AMSOIL? Click Here!
LaCeS OuT is offline   Reply With Quote
Old 09-03-2008, 03:07 AM   #19
mr4x4
the miller 180 with the auto set is nice I dont know much about the hobart
but the lincon 180 mig is a good little welder it will weld up to 1/2" thick
and its cheaper then the miller
I use millers at work and a lincon at home both brands weld great
you can go to home depot and pic up a lincon 180 pro mig mig welder for around $650
that one works just as well as the millers at work
I built this bumper with my lincon out of scap 3/16 steel then powder coated it at work
94 stock zj and a 95 zj with the front to rear spring swap the 2" budget boost in the front and a about a 1/2" spacer in the rear giving me 5.5" lift with 35" bfg km2 soon to have a rear currie 9in with 4.56 gears an arb and 35spine axle shafts and 4.56 gears in the front Hp30 with a Aussie locker and a 231 tcase with sye swap
mr4x4 is online now   Reply With Quote
Old 09-03-2008, 03:12 PM   #20
j0nesy
Originally Posted by Jerry Bransford View Post
My wife assures me my recent upgrade to a new Miller Auto-Set 180 wil be the last welder I will ever buy.
thats about right ...
though my SO is pretty understanding now ... when i say im too broke to go out, she asks what i bought for the jeep / shop ....
assure her size matters to you just as much as it matters to her .. and the 180 just wont get the job done!!!
j0nesy is offline   Reply With Quote
Glock Forum
