Chop Saw Help - JeepForum.com
post #1 of 10 Old 10-01-2010, 08:54 PM Thread Starter
DDove
Chop Saw Help
If I have a 10inch compound mitre saw can I put a chop saw blade in it and cut metal. Thanks
DDove is offline
post #2 of 10 Old 10-01-2010, 09:08 PM
Ironworker709
Ironworker709's Avatar
I wouldn't advise it..2 reasons..the metal chop saw blades are designed for a different RPM..plus needs to be a stronger motor to handle the strain it puts on it..so it'll wear that motor out in no time..
2..metal chop saws are designed without any plastic materials..most wood saws have plastic parts and the sparks/fire will destroy it
Don't DREAM your life, LIVE your dreams
Never forget 9/11
"Welding is like a woman,Get 'er HOT and Penetrate"
Gotta LOVE a person who knows everything about NOTHING
The only Thing necessary for the Evil to win is a good man to do nothing....
"How far you go in life depends on your being tender with the young,compassionate with the aged,sympathetic with the striving,and tolerant with the weak and strong--because someday YOU will have been all of these"....George Washington Carver
Want to know what an Ironworker is and the job scope of a Journeyman?..click here...
Ironworker709 is offline
post #3 of 10 Old 10-02-2010, 03:24 AM
Warlord2
I tried doing that with my wood chop saw. It worked fine for small stuff but once you get into the heavy material for like body armor the motor just wouldnt cut it. I was able to take off all the plastic parts so I didnt damage anything. Worked good for cutting the 1 1/2" OD EMT I used for making my light bar and roof rack.
07 JK 2D X model with 6 speeds. Full Traction 3" ultimate lift kit. 315x75x16 Toyo Open Country M/T on Rock crawler procomp rim. Ruby dana44's front sleeved inside/outside C truss and rear with 5.13's gears. Homemade rock guards, rear bumper w/tire carrier, oilpan/tranny skid, evap canister skid, light bar, switch pod. Riddler diff covers, Cobra 75 w/wilson antenna, Polk speakers, 10" sub, 2x Amps, Lightforce 240 drive light, backup lights, rock lights.
Warlord2 is offline
post #4 of 10 Old 10-02-2010, 06:19 AM
thatnameisinuse
What ironworker said , I use this saw and love it
YouTube - Evolution Rage 2 Dry Cut Chop Saw
thatnameisinuse is offline
post #5 of 10 Old 10-02-2010, 10:14 AM
Jim1611
Jim1611's Avatar
How do you like the Evolution? Is that the 12" 0r 14" model?
(Crabtree Shackle Hangers)
My build thread
Jim1611 is offline
post #6 of 10 Old 10-02-2010, 12:04 PM
ksander
It kind of depends on what kind of saw you have. I've used an abrasive wheel on my miter saw to cut lots of metal and it works great. Its a really old saw but it was also designed to cut masonry stuff so I think it is a lot tougher than the cheap plastic ones sold now.
RE 3.5 Super-flex, RE Monotube Shocks, 31 MTR's on Moabs, RE HnT and CV driveshaft.
ksander is offline
post #7 of 10 Old 10-02-2010, 08:18 PM
thatnameisinuse
i have the 14 and its a beast
post #8 of 10 Old 10-06-2010, 01:32 AM
Warlord2
Im in the market to purchase a dry cut chop saw. Im really interested in the Rage 2-3 but wanted to see if anyone knows whats the difference between the Fury 2 and Rage 2? seem very simular but the price is much different.
Are there any other brands of Saws that I should be looking at? Dont want to spend more then about $300 and the max thickness of metal I would be cutting is about 1/2" to give you an idea of what Im using it for....
Warlord2 is offline
post #9 of 10 Old 10-06-2010, 03:29 AM
Ironworker709
I think you're best bet would be to start another thread asking about dry cut shop saws to get more responses....
I use a few at Nuclear power plant fab shops and a few other jobs but these saws are WAY over you're 300.00 budget
Never forget 9/11
post #10 of 10 Old 10-06-2010, 05:41 PM
bairy
I love my rage 3 saw. Cuts like steel is butter. It is loud though. Find a local saw sharpening guy. I get mine resharpened every once and a while for 11 bucks.
2006 LJ Claytonized
1999 TJ stockish
1987 J20
bairy is offline
chop saw advice ScottHarr_TJ Fabrication Shop 6 10-27-2009 02:59 PM
Chop Saw BAH07 Fabrication Shop 9 09-08-2009 05:18 PM
Chop saw/ Miter saw melius Fabrication Shop 7 04-01-2009 07:15 PM
Chop saw blades.. SleddinJeeper Fabrication Shop 2 03-22-2009 07:19 PM
Should I chop it up? TEXASRAM Fabrication Shop 19 10-02-2006 10:58 AM
