Chop saw blades. Some are so slow! - JeepForum.com
post #1 of 5 Old 11-06-2003, 05:18 AM Thread Starter
BamaJeeper
BamaJeeper's Avatar
A friend of mine got a Milwaukee 14" chop saw and the original blade needed to be replaced after alot of cutting. He got a DeWalt blade and it's slow as hell. The original blade would cut through a 4" pipe in one minute but the Dewalt blade never made it through after 4 minutes. On goes the old blade and it zips right through.
What gives?
Any similar experiences out there?
What brand of blades do you like?
Out of the darkness comes light.
BamaJeeper is offline
post #2 of 5 Old 11-06-2003, 07:12 AM
FunkSkunk
Sold my soul to JeepForum
FunkSkunk's Avatar
Some of the guys said the thinner blades cut faster, makes sense. You just got to be careful not to blow one by pushing it too hard. How does that milky do? are the cuts good and square?? how about changing the angle on it, easy/fustrating??
FunkSkunk is offline
post #3 of 5 Old 11-06-2003, 10:27 AM
rickr
hey Bama: how thick of a blade are you using? if it,s an 1/8" wheel, take it off and play frisbee with it! i,ve found that the 7/64" and especially the 3/32" cut faster with less of a burr on the end of each cut. but, don,t push hard, they will deflect! i,ve also found that the cheapest wheels last longer. ( no name brands ) anyway, that,s my 2 cents worth. good luck!
rickr is offline
post #4 of 5 Old 11-07-2003, 12:51 PM
awachwhiteboy
1975 CJ5
Our Milwalk chop saw is ok, it cuts 90 great it really sucks when you have to try to cut a 45. Its hard to explain but once the garud is at 45 as the vice part is screwed down the material starts to move 43, 40, and so on as you tighten it down. Its a ****ty design, I usually hold it by hand or if its possible use a C clamp.
Sacramento Jeepers Group #1
awachwhiteboy is offline
post #5 of 5 Old 11-10-2003, 08:45 AM
FunkSkunk
FunkSkunk's Avatar
hmm... thanks for the tip, I'll look at that if i ever get one. We finally got to borrow this guys Dewalt for a couple of weeks, its ok. Never tried a 45' angle on it yet. It just never cut straight.
Chop Saw BAH07 Fabrication Shop 9 09-08-2009 05:18 PM
Chop saw/ Miter saw melius Fabrication Shop 7 04-01-2009 07:15 PM
Chop saw blades.. SleddinJeeper Fabrication Shop 2 03-22-2009 07:19 PM
Should I chop it up? TEXASRAM Fabrication Shop 19 10-02-2006 10:58 AM
susp./ chop top wheelchairman Fabrication Shop 6 05-12-2006 03:57 PM
