cheapo tubing bender for tube fenders - JeepForum.com
post #1 of 12 Old 11-30-2009, 12:55 PM Thread Starter
maxonaplane
I was looking at this on ebay, but does it only bend pipe or tubing also as it leaves you to believe?
New 12 Ton Hydraulic Pipe Tube Tubing Bender Roll Cage - eBay (item 160378065615 end time Dec-13-09 16:31:39 PST)
I wanted to bend my own tube for a set of tube fenders because the price of the complete sets are outrageous!
Max
maxonaplane is offline
post #2 of 12 Old 11-30-2009, 05:36 PM
jsc7002
1966 CJ5
its a pipe bender, itll do tube but itll kink it.
jsc7002 is offline
post #3 of 12 Old 11-30-2009, 05:41 PM
ImpactFabWorks
its the same as a harbor freight bender. It can work but it takes a lot of trial and error. I used one before and we packed the tube with wet sand and capped the ends and it turned out great. but its a lot of work
1990 YJ = The Toy/ My Daily Driver
1996 XJ= Wifes Daily Driver
Please fill out your profile, It helps us help you!!!
ImpactFabWorks is offline
post #4 of 12 Old 11-30-2009, 05:45 PM
chet44
It'll work fine if you make your "tube" fenders out of sch40 pipe.
chet44 is offline
post #5 of 12 Old 11-30-2009, 05:46 PM
johnny9
ive used that a few times and i hate them..you got to learn its ways as it teaches you..it dosent never do what ya think it will do..i wont ever get another one imho
JACK OF ALL TRADES,,,MASTER OF NONE
fla cracker head born and bred
build-
johnny9 is offline
post #6 of 12 Old 11-30-2009, 05:48 PM
jjg214
nothing wrong with schedule 40 tube fenders!!!!
to the OP, it wont work well with tube.
WTB: HP Dana 30, Long Island/New York Area
detours backbone system for sale
jjg214 is offline
post #7 of 12 Old 11-30-2009, 05:53 PM
HELMET
You will not be happy with it. A friend had one and it was a nightmare trying to match another bend.
HELMET is offline
post #8 of 12 Old 11-30-2009, 06:08 PM
Unlimited04
This post/info=my opinion
Unlimited04's Avatar
if you want to make pipe fenders that bender will work. it ain't gonna work for tube tho.
i'd like to see somebody make fenders out of 1" conduit
Useful Write-Ups:
Fabrication & Build:
Funny:
Unlimited04 is offline
post #9 of 12 Old 11-30-2009, 09:43 PM
chet44
I didn't say there was. I made the brush bar on my front bumper out of it:
With a Harbor Freight Pipe Bender no less.
chet44 is offline
post #10 of 12 Old 12-01-2009, 08:40 AM
limegreentj
to cut down on your trial and error...use a thing called bend it calculator....do a google search and you can download it...then in that program you'll have to enter the radius of the die you are using...i couldnt figure out the radius so i called harbor freight and they read them to me in their set of instructions (why they dont put that in the user manual i have no clue) but here they are....
die/radius
1/2"-2" rad
3/4"-2.2650" rad
1"-4.8750" rad
1.25- 4.250" rad
1.50"-5.250" rad
2.00"-6.00" rad
input all that info into bend it calculator and your life will be a whole lot easier...and also, use good sched 40 pipe..not the **** from lowes. fill the pipe with sand TIGHT!!! and then cut some pipe about 3 inches long...then cut that down the middle and use that to go between the rollers and the pipe you are bending....ive said it before and ill say it again...i can bend stingers to 140 with no kinks or dents
hope i helped
limegreentj is offline
post #11 of 12 Old 12-01-2009, 08:44 AM
limegreentj
i think a guy on JU did that....and using the methods i talked about above you can bend DOM tube in a pipe bender...i have bent 1 5/8 dom in the 1 1/4 pipe die (because it fits tight) the other ones you may have to grind out to make your tube fit, but honestly, the dies are about 3 bucks a piece at HF warehouse (they ship them to you) so it doesnt hurt to have all the dies for pipe and then order 2 more and grind them to fit tube.
post #12 of 12 Old 12-01-2009, 08:50 AM
jpony645
check out www.jeeptubes.com . You can get pre-bent tube for the fenders for $80 plus shipping then just weld them up yourself.
jpony645 is offline
what kind of tubing and what size for tube fenders Goobersbro Fabrication Shop 2 10-23-2009 10:25 AM
How much tubing for tube fenders?? GzrGlide Fabrication Shop 6 06-05-2009 02:53 PM
Tubing bender ? melius Fabrication Shop 10 10-11-2008 09:49 PM
tubing bender ugrider21 Fabrication Shop 2 08-21-2005 12:21 PM
