Can I cut down head bolts? - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Fabrication Shop > Can I cut down head bolts?
RCV Axles at CCORSave 17.76% for the 4th of july with ruffstuff specialtiesIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed Line
Unread 01-30-2015, 09:30 AM   #1
svshaw82
1989 XJ Cherokee
Hey guys. Rebuilding my 4.0. Just got my new head bolts, and my deepest socket won't clear the top threaded section of some of the new bolts.
My question is, can I cut 1/2" off the top of them? Or would this compromise the strength of the bolts?
If I can't cut, just means I will have to go buy a really deep 1/2 - 12 point socket.
Thanks in advance for any replies! :-)
svshaw82 is offline   Reply With Quote Quick reply to this message
Unread 01-30-2015, 07:51 PM   #2
Ironworker709
Ironworker709's Avatar
I's personaly buy a deep well socket over chopping some new head bolts up....
Don't DREAM your life, LIVE your dreams
Never forget 9/11
"Welding is like a woman,Get 'er HOT and Penetrate"
Gotta LOVE a person who knows everything about NOTHING
The only Thing necessary for the Evil to win is a good man to do nothing....
"How far you go in life depends on your being tender with the young,compassionate with the aged,sympathetic with the striving,and tolerant with the weak and strong--because someday YOU will have been all of these"....George Washington Carver
Want to know what an Ironworker is and the job scope of a Journeyman?..click here...http://www.ironworkers.org/becoming/careers.aspx
Ironworker709 is offline   Reply With Quote Quick reply to this message
Unread 02-06-2015, 06:58 PM   #3
thantos858
1974 CJ5
If the bolts are to long for a deep well socket they aren't seated all the way in or the incorrect bolts. Like Ironworker said I wouldn't cut them. If you have to cut the head bolts its possible but you want to keep them cool so you don't mess with the properties of the metal.
thantos858 is offline   Reply With Quote Quick reply to this message
Unread 02-06-2015, 07:16 PM   #4
svshaw82
1989 XJ Cherokee
It's not that the bolts are wrong. It's the threads on the top part of the bolts, the heads are 1/2" 12 points. My deep sockets don't clear the extra threads on top.
I'm not going to cut them. I will take one with me to harbor freight and buy a extra tall socket.
Unread 02-08-2015, 02:07 PM   #5
svshaw82
1989 XJ Cherokee
Solved my problem. Put my socket in my drill press and drilled out with 1/2" bit. After putting it in the freezer and some oil, hollowed out enough material so it clears those threads now.
Thanks for all the input guys!
