Calling all TIG weldors.. - JeepForum.com
post #1 of 4 Old 05-04-2012, 01:47 AM Thread Starter
Maximus856
1968 J-Series Truck
I know MIG pretty much rules the roost now in terms of offroad fabrication. Understandably, as it produces good welds in all positions on a various amount of metals. With a bit of training, it is a 'do all machine,' and an affordable one at that. For those who prefer or simply don't have a choice (for whatever reason), what do you prefer in the way of using a TIG machine? I ask this in reference to scratch start vs. footpedal. I've done some out of position TIG welding with a footpedal, and it certainly takes some getting used too. I can't recall off the top of my head ever using scratch start, but I feel that this way would certainly be beneficial to doing something such as a cage, especially with todays finger controls. I realize most people who have access to a nice TIG machine typically have access to a MIG machine, but I'm speaking TIG only..
If you're curious as to why I'm asking this, it came to me when I found an add for a syncrowave with a footpedal but no torch... usually its the other way around
Maximus856 is offline
post #2 of 4 Old 05-04-2012, 06:03 AM
Ironworker709
Ironworker709's Avatar
Scratch start is just the very basic setup..it can be usable but if you have the resources to get and use a high frequency start or lift arc it makes it MUCH nicer...and a foot pedal to control your heat at all times is also a big plus all around,havin the heat very low on a start makes it much nicer to have more control before you "throw the heat" to it.making sure you are in the exact spot you want to be before the work begins...it is also real nice for controling the heat through the weld to keep the heat zone controlable and possible burn through.....it is also real nice for the stops,your not "yanking" the torch quickly away from the end of the puddle to stop the arc and possibly losing your inert atmosphere before the weld puddle cools,causing contamination.
The reason that machine has the pedal and not the torch is most likely because the torch is a consumable,probably was wore out or even used for another machine they bought in place of this one.
Finger controls have thier ups and downs....if your in a spot laying down on your back or in any funky position it could be nice....but in a good position i didn't like the finger control,i felt like it took more focus attention and steadiness from the torch hand to control the puddle more fluently everytime youd try to turn the knob for heat adjustment, it sort of hindered the focus and steadiness of controling the puddle...i geuss with alot practice with them it could be real nice..i just personaly like the foot control better when possible.
Don't DREAM your life, LIVE your dreams
Never forget 9/11
"Welding is like a woman,Get 'er HOT and Penetrate"
Gotta LOVE a person who knows everything about NOTHING
The only Thing necessary for the Evil to win is a good man to do nothing....
"How far you go in life depends on your being tender with the young,compassionate with the aged,sympathetic with the striving,and tolerant with the weak and strong--because someday YOU will have been all of these"....George Washington Carver
Want to know what an Ironworker is and the job scope of a Journeyman?..click here...
Ironworker709 is offline
post #3 of 4 Old 05-04-2012, 06:08 PM
tangotag
Foot pedal but many times we have used hand, knee, or a second man operating the foot pedal. It depends on the position and available space to wiggle into.
Re: the add
Maybe the seller is keeping his liquid cooler for his torch. We have both TIGs with coolers and others without. The chilled torches are best for prolonged welding.
tangotag is offline
post #4 of 4 Old 05-06-2012, 03:11 AM
parker007
1977 CJ5
im glad im not the only one that strugle with foot pedal. i weld food grade pipe and tanks and inside a ss tank runing foot pedal and filler is a frustrating task. i endup using knee also and feel like a monkey pating head and rubing stomach. But i will say tig is way beter for clean welds with no distortion and low heat. but tig require much patience in set up. if you try to fill gaps it is not desirable. and remember the faster you weld the less loss of chemical composition. which means cleaner weld.
parker007 is offline
Calling Hemifever Diggs59 Street Jeep Forum 0 02-19-2010 08:59 PM
CALLING ALL COOPER STT's sturge23 Tires & Wheels 4 03-22-2009 12:25 PM
Calling all PRO welders... Acidcold Fabrication Shop 15 07-13-2008 09:41 PM
to all the weldors out there NJscott Fabrication Shop 14 12-13-2007 12:25 PM
calling anyone with a light bar! ElvisV04290 Audio, CB & Ham Radios, GPS, & Electrical 5 11-09-2006 08:19 AM
