cage building question - JeepForum.com
post #1 of 3 Old 01-23-2013, 05:55 AM Thread Starter
underpowered
Bouncin' on a Budget
underpowered's Avatar
so, i am building a full cage for my blazer. first time ever building one from scratch. i have installed a kit cage and modified it to my liking, but never built one totally before.
i have the main bars in the rear done, but now i need to do my front portion. the two options i can see are:
1. do a roof Halo and two down bars that attach to it
2. two bars that attach to the frame, go across the roof then attach to the main hoop with a spreader along the top of the windshield instead of doing a whole halo bar
I had honestly planned on doing mine the 2nd way because that is how i have seen it done, but after some thought and looking online to kinda get idea's i think the Roof halo will be easier to pull off one shot and not have to do a compound bend on the front bars. but is one way better, or the "right" way?
1998 ZJ-- lowered a touch
2005 GMC 2500HD 496 C.I.
Fat Amy-1989 K5 blazer. Linked, lifted, 38.5's on won tons. Big Girls can play in the woods too.
underpowered is offline
post #2 of 3 Old 01-23-2013, 07:14 AM
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
Either way will work. However, as you mentioned, the halo would be easier to do. Simple hoop for the halo and simple legs with a single bend in each leg.
BESRK is offline
post #3 of 3 Old 01-23-2013, 02:26 PM Thread Starter
underpowered
not that i want to take the easy way out, i would just rather get it right the first time and not try a few times and waste tube so that it most likely how i will do it. was just unsure if one way or the other was considered the correct way, as i have seen it done both.
Thanks Besrk!
