CAD File Sharing Now Possible!! - Page 4 - JeepForum.com
 2Likes
post #46 of 88 Old 03-12-2014, 10:39 AM
Tomb Raider
Addicted...
Tomb Raider's Avatar
Originally Posted by tdkask View Post
Helldorado, are you making it for multiple vehicles or just need one? I happen to have one I will never use nor a late style CJ. It's the same thickness as whatever stock is, I guess. Someone bought it as a aftermarket part and didn't use it, I got it in a trade or something, and will not need it (building a beefier crossmember and bumper combo). It's available for shipping and $15 (beer money).
I'm just repairing one...now....lol. I'll take it !! Just send a request for dollars through paypal to helldoradocustoms@gmail.com and I'll send it your way ! and....much appreciated !!
-Scott
I like to build stuff. Want to know what I build, you can google it
Tomb Raider is offline
post #47 of 88 Old 03-25-2014, 02:17 PM
JStrider
Originally Posted by BESRK View Post
TJ and YJ Winch Plate w/ 4"x10.5" Bolt Pattern
Are the mounting holes for the fairlead really supposed to be offset that far above the midline of the fairlead hole?
It seems like you would want the holes on either side to be centered with the main hole.
If they are supposed to be offset, what is the advantage? it seems most pictures I'm finding online show the holes centered.
Thanks!
ON-ON
JStrider is offline
post #48 of 88 Old 04-29-2014, 06:17 PM
nickbol9
2009 JK Wrangler
baleigh tn-250 knock off
would anyone be interested in a baleigh industrial tn250 knock off? I have designed my own based off from their design and have all .DXF files for it
nickbol9 is offline
post #49 of 88 Old 05-01-2014, 07:19 PM Thread Starter
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
Thanks!
Doh! I just saw this post..
I offset the holes higher so that a big roller fairlead will fit, without hitting the bumper that the winch plate is sitting on. Also, I tried to keep the lower lip of the fairlead hole nice and low.. so that it doesn't chafe the cable coming off the bottom of the drum. However, I need to have at least 1" of lip to fit in my pressbrake die correctly (2" V die).
You can center the holes if you're running an aluminum hawse fairlead and synthetic rope... but with a roller fairlead, it usually works better raised up a bit.
BESRK is offline
post #50 of 88 Old 05-06-2014, 03:29 PM
JStrider
Thanks for the info, I've got a friend that is cutting this for me, once he gets his plasma cutter aligned properly... might have happened this weekend. I'll have to touch base with him about centering the holes, since I'm running synthetic. sounds like it will work fine either way.
ON-ON
JStrider is offline
post #51 of 88 Old 06-11-2014, 10:29 PM
steveinil
1995 VJ
Yj belly skid? D60 disk brake brackets? D60 d44 diff cover?
steveinil is offline
post #52 of 88 Old 10-25-2014, 11:02 PM
Motas
1983 CJ10
Hey guys anyone got any drawings for dana 30/44/60 diffs? A solidworks model of the outside of the housing would be ideal. Need to make trusses for each and would be happy make the templates available here in return for any help with the reverse engineering part.
Cheers.
Also if anyone needs anything drawn or modeled let me know and we might be able to work something out.
http://cj10camper.blogspot.com.au/
Motas is offline
post #53 of 88 Old 11-30-2014, 09:56 PM
SadDayPanda
I have the them for 44's and 60's and 14's and 9 inch faces, they are all in AutoCad though. Not sure if they will help you.
87, 93, 95 YJ
92, 98 XJ
87 J10
SadDayPanda is offline
post #54 of 88 Old 12-23-2014, 05:06 PM
Motas
1983 CJ10
Would definitely be helpful! Any chance you could post them up? Especially the 44 and 60. Autocad is fine for me as well if anyone has anything to do with a truss drawn.
Thanks.
Motas is offline
post #55 of 88 Old 01-04-2015, 09:20 PM
SadDayPanda
Apparently I lied on the dana 44, here is the d60, 14 bolt and ford 9...
If anyone happens to have a cad of the YJ skid plate mounts.. Ultimately I just need the bolt holes... I'm look around the web and see if i can find it, but cad would be best for me.
87, 93, 95 YJ
92, 98 XJ
87 J10
post #56 of 88 Old 01-04-2015, 09:33 PM
Motas
1983 CJ10
Dont know if you noticed but it has a D44 cover ring drawing, not sure exactly what it is but its something. Thanks for the 60 that will help me heaps later on.
Anyone else have a D44 drawing?
Cheers.
Motas is offline
post #57 of 88 Old 01-05-2015, 09:05 PM
SadDayPanda
Haha, i was just going by the name of the file.
87, 93, 95 YJ
92, 98 XJ
87 J10
post #58 of 88 Old 01-21-2015, 04:10 PM
SadDayPanda
If anyone has any drawing requests, I'm looking to do a bit of polishing on my cad skills. I'm kind of running out of things to draw for my own purposes. Post them up. I'll see if I can't help ya out.
87, 93, 95 YJ
92, 98 XJ
87 J10
post #59 of 88 Old 01-22-2015, 10:47 AM
tdkask
You can NEVER go wrong with the basics.
Disc brake brackets. Cool gussets. Trusses. Foot pegs. Diff covers/skids. Shock towers/tabs. Etc etc.
80 CJ7_360_32RH_D300_44/9"(4.56)_custom bumpers/cage
4" lift,tube fenders,comp cut_37s on H1 rims
tdkask is offline
post #60 of 88 Old 03-16-2015, 11:54 AM
GrantYJ
If you're doing much modding to your Jeep at all, I highly recommend drawing it in 3D. Not necessarily the entire Jeep (but that wouldn't be bad), but at least the front and rear end of the frame, rough in the body (doesn't necessarily need all the contours); however, it aids greatly when you're designing bumpers, rock rails, and etc. It's also handy when you want to see what the profile is going to look like with "X" amount of lift or stretch.
“The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed.” ― Robert M. Pirsig, Zen And The Art Of Motorcycle Maintenance: An Inquiry Into Values
GrantYJ is offline
door , door latch
