buying a welder - JeepForum.com
post #1 of 14 Old 09-22-2010, 02:31 PM Thread Starter
XGoBoomJ
1997 XJ Cherokee
buying a welder
I have read a bit on this, and instead of taking my jeep to somebody to pay them and weld i want to do it myself. But things like stiffeners, sliders, minor things around the jeep, up to 1/4th possibly.
Now i know the HF welders are not worth my time, but yet i dont have enough $$ to throw down on a 400-500$ hobart or lincoln really..
Is there a happy middle option? that runs on 120v, decent duty cycle, mig
would use be my only option here?
I am the Stormtrooper..
XGoBoomJ is offline
post #2 of 14 Old 09-22-2010, 02:56 PM
rustywrangler
Got my eye on you.....
rustywrangler's Avatar
Used will be your best bet here. You will regret buying a HF welder in the long run.
Congenital Heart Disease is a reality for me, BOTH of my children have it. Please read up and become aware for future generations
Lydia Ann-Acquired 08/05/05 Open Heart surgery 08/10/05
Jacob Patrick-Acquired 01/17/08 Open Heart surgery 02/15/08
rustywrangler is offline
post #3 of 14 Old 09-22-2010, 03:16 PM
ImpactFabWorks
I would start looking on craigslist.
1990 YJ = The Toy/ My Daily Driver
1996 XJ= Wifes Daily Driver
Please fill out your profile, It helps us help you!!!
ImpactFabWorks is offline
post #4 of 14 Old 09-22-2010, 03:52 PM Thread Starter
XGoBoomJ
1997 XJ Cherokee
As much as i just want to buy even the $99 120v 90amp to just install my stiffeners/ sliders/ lca skids, and a steering brace
It seems it would work for that, taking a decent amount of time on cooldown, but it might be better adding the 100 to the funds for a 2-400$ one i guess..
XGoBoomJ is offline
post #5 of 14 Old 09-22-2010, 05:05 PM
dagr8tim
dagr8tim's Avatar
1997 XJ Cherokee
I'm planning on snagging a 110 HF welder to start learning and play with before I move up the big leagues. Remember, you can also find 20% off coupons for a single item all over the internet for HF.
$79 for a cheap welder to start learning is probably the best deal in town. Atleast for me that's maybe 2 months worth of saving.
Jeeping - The art of getting dirty & going broke while slowly heading nowhere, and taking all day to do it.
97 XJ SE - The War Wagon
98 TJ - Mall Crawler/Light Trail Rig
dagr8tim is offline
post #6 of 14 Old 09-22-2010, 10:49 PM
baldeagle1
i would buy a 220 volt lincoln buzz box, can find usedones all time for 100-200
baldeagle1 is offline
post #7 of 14 Old 09-22-2010, 11:53 PM Thread Starter
XGoBoomJ
1997 XJ Cherokee
I do not have a 220 volt outlet. 110 is the only way for me. there are plenty powerful machines that run off 120v. just cost near 400-500 lol.
part of me wants to just get the 99$ one, im sure once the settings are dialed in i will be able to weld on my stiffeners/sliders. But if they will hold is the question...
or i can have some local 4x4 guys help me out.. hmmm
XGoBoomJ is offline
post #8 of 14 Old 09-23-2010, 02:21 AM
Warlord2
so you dont have a dryer outlet? Ive never heard of a house not having 220, the line that comes in off the power line from the transformer to the house is always 220-240v. Usually always 1 hookup in the house, the AC uses 220 as well.
07 JK 2D X model with 6 speeds. Full Traction 3" ultimate lift kit. 315x75x16 Toyo Open Country M/T on Rock crawler procomp rim. Ruby dana44's front sleeved inside/outside C truss and rear with 5.13's gears. Homemade rock guards, rear bumper w/tire carrier, oilpan/tranny skid, evap canister skid, light bar, switch pod. Riddler diff covers, Cobra 75 w/wilson antenna, Polk speakers, 10" sub, 2x Amps, Lightforce 240 drive light, backup lights, rock lights.
Warlord2 is offline
post #9 of 14 Old 09-23-2010, 02:44 AM
ImpactFabWorks
wiring a 220 plug is easy, and chance are you do have one already.I just don't understand why people spend so much money to just limit what they can do
post #10 of 14 Old 09-23-2010, 11:12 AM
jeepin1995
jeepin1995's Avatar
no expert welder by any means, but have burned quite a few things..... here's my opinion..... i have tried several welders, including a HF welder, a campbell hausfeld, a lincoln, and a hobart (110 & 220) with the cheaper welders it was hard to get a good constant line feed..... which makes learning how to weld impossible..... everything with the higher end welders is better quality therefore more dependable/easier to learn on. i couldn't do crap with the Hf or CH..... but with the lincoln and especially the hobart.... i'm actually not half bad!!! if i was you, i'd save until i could afford the welder i wanted. not buy a cheapo to learn. learn on what you're gonna use!!
"IF YOU CAN'T DAZZLE THEM WITH FACTS, BAFFLE THEM WITH BS"
jeepin1995 is offline
post #11 of 14 Old 09-23-2010, 01:02 PM
bruteboy
the biggest issue for me when I had my first cheap 110v welder was the duty cycle.
when welding 1/8" or thicker material,the welder would heat up and then shut down(thermally protected)
and I would have to wait for it to cool down before continuing.
even welding sheet metal,once the welder got hot,it would shut down and I would have to wait.
any money spent on a cheap welder is that much less to spend on a good one.
an extension cord to the stove or dryer plug should take care of your 220v issue.
bruteboy is offline
post #12 of 14 Old 09-24-2010, 10:55 AM
jatepper
X100. DO NOT BUY the HF welder! As mentioned, search craigslist. I have seen many nice welders for cheap on there. A Lincoln, Miller, or Hobart 30 amp is good as long as you are not making safety related items, such as spring perches or receiver bumpers.
1986 CJ7 Laredo - Auto 14k miles
1985 CJ7 Renegade - Auto 33k miles
1982 CJ8 Scrambler - T5 T-SPD
jatepper is offline
post #13 of 14 Old 09-24-2010, 11:43 AM
Jim1611
Jim1611's Avatar
If you buy a good quality used welder it will most likely last you a lifetime. My first welder was Lincoln stick welder, still have it after 15 years and it was used. I can weld just as nice a bead as many folks can with a mig and it's got plenty of amps to burn anything in that you'll ever need to weld. My point is that you could get by with a stick welder and get one cheaper than you might a mig. Some say a stick is harder to weld with, but I think if you're going to weld you might as well have the skill to use whatever you have, even a stick.
(Crabtree Shackle Hangers)
My build thread
Jim1611 is offline
post #14 of 14 Old 09-24-2010, 01:07 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
You won't find any "plenty powerful machines" that run on 110v. 140 amps is it for a 110v welder and you'll quickly learn how limiting it will be if you start trying to weld big pieces of even 3/16". That is why I sold my 110v Hobart welder and bought a Miller 180 amp 220v welder.
I didn't have 220v in my garage either, I moved my laundry room's 220v dryer outlet into my garage which works fine. All I had to do was install the right kind of outlet (NEMA 50-R) to match the welder's 220v type of plug.
Our Technical Staff is working to fix our database error problem, thank you for your patience.
Getting
Jerry Bransford is online now
Thinking of buying a welder Delox Fabrication Shop 401 03-17-2015 04:24 PM
buying first welder in recommendations Wrangler11 Fabrication Shop 52 04-08-2011 03:24 PM
need help w/buying new mig welder rodjr Fabrication Shop 15 10-20-2009 11:31 AM
Thinking about buying a welder to learn on... C-Mil Fabrication Shop 5 09-17-2009 10:17 AM
Thinking of buying a welder... (i read the sticky ) jamoka3 Fabrication Shop 12 01-14-2009 11:27 AM
