Quantcast Burning Aluminum? - JeepForum.com
Jeep Home Jeep Forum Jeep Classifieds Jeep Registry JeepSpace Jeep Reviews Jeep Gallery Jeep Blogs Jeep Clubs Jeep Groups Jeep Videos Jeep Events Jeep Articles
Go Back JeepForum.com > General Technical Discussions > Fabrication Shop > Burning Aluminum?
Trail Canvas Seat Covers & Smittybilt G.E.A.R. Covers Free Shipping on all Engo Winches Continues...starting at Introducing MONSTALINER™ UV Permanent DIY Roll On Bed Line
JeepForum Membership Drive - Reduced Premium Membership For a Short Time Only
Old 08-08-2007, 03:39 AM   #1
Jeepcreep927
Burning Aluminum?
I have found a local shop that builds trailers outta aluminum, and they said I could scrounge their scrap heap. I am thinking of doing a tire carrier and tube fenders out of aluminum however... I don't have and can't afford a TIG set up just for a hobby. I saw a "kit" that is supposed to let you weld aluminum with a MIG machine. I was skeptical about it. Anyone seen this or used one? Thanks.
Jeepcreep927 is offline   Reply With Quote
Old 08-08-2007, 07:43 AM   #2
Scotch740
Want to give us a name or a link or just make us guess? What did this Kit include?
What about taking some TIG classes and see if you can do your own projects to be graded on. Maybe then you will run into a used TIG set up for cheaper.
What thickness tube would you use for the fenders? I would think you would want to go thicker wall than steel.
Scotch740 is offline   Reply With Quote
Old 08-08-2007, 08:19 AM   #3
Matt Gertsch
www.lp.org
Matt Gertsch's Avatar
MIG on aluminum looks like butt unless you have one of the Lincoln double pulsed MIG machines.
"'Did you ever wonder why we had to run for shelter when the promise of a brave new world unfurled beneath a clear blue sky? "
Roger Waters
Matt Gertsch is offline   Reply With Quote
Old 08-08-2007, 12:13 PM   #4
Happy Joe
MIGs can be converted to aluminum (ususally just change the wire and gas (sometimes you need to replace the wire tube to prevent comtamination)).
I used to work at a sign company and we welded aluminum all day every day with Millers.
Enjoy!
...a well prepped, well driven, vehicle should do well in any terrain, including the highway.
Carburetors became obsolete during the last century... do what ever it takes to get fuel injection...It makes bigger grins off road.
Happy Joe is offline   Reply With Quote
Old 08-08-2007, 07:22 PM   #5
bryans98tj
Lincoln now has a spool gun for their new 140 and 180 machines. I just went and priced them today and found one local for $157. Pretty good deal and it'sjust an easy add on. I guess Miller is also supposed to have one coming out too.
[SIZE="1"][B]98 TJ-bought-not built
[url]www.PNWJeep.com[/url]
كافر - Infidel[/B][/SIZE]
bryans98tj is offline   Reply With Quote
Old 08-14-2007, 02:37 AM   #6
Dan Fredrickson
Vendor
Dan Fredrickson's Avatar
I still weld Aluminum better than steel......
Yes, its an easy switch to aluminum, use straight Argon and you have to have a spool gun or a puller. I used to use a Cobramatic gun and feeder (dating myself) when they first came out. You need to move faster but the problems of Aluminum all but rule it out as a material for anything taking stress. Aluminum has a very definate fatigue life when not heat treated and stress relieved. You see it riveted together on airplanes, not welded!
Welding aluminum is harder for most people but TIG welding aluminum is also pretty easy for most old school welders that came up with a gas torch. Brazing steel is another almost lost technique among welders that is very strong (I first built Fillet Brazed Bicycles 25 years ago), I'm sure you have seen cast iron repaired by brazing. But the inexpensive MIG gun pretty much did away with the gas torch and stick welders........and the only people brazing anything nowadays are working in radiator shops.
Dan Fredrickson
www.ruffstuffspecialties.com
Much Better Than Good Enough
Sales 916.509.2242/Sales & Tech 916.600.1945
Dan Fredrickson is offline   Reply With Quote
Old 08-14-2007, 02:43 AM   #7
Island4x4
Ehhh... no it doesn't.
Lincoln isn't the only manufacturer that makes a nice aluminum machine lol
Miller > Lincoln
on another note... I've welded aluminum with oxy-fuel but I wouldn't recommend it to a beginner lol
God is good to the Irish because nobody else is.
[COLOR="White"]White Jeep Club Member # 1337[/COLOR]
Island4x4 is offline   Reply With Quote
Old 08-19-2007, 06:39 PM   #8
severous01
if you dont want to buy a welder check out dura-weld. 20lbs of rod for 40 bucks aint bad.
it's an aluminum alloy soldering rod used with a propane or MAP gas torch. it's pretty sturdy. we welded a soda can back together after cutting and ripping it with a knife. we then proceeded to crush the can with hammers. the can was totalled except where the 'solder' put the can back together. it's pretty tuff stuff...harder than the aluminum you're welding together.
1994 jeep cherokee, xj, 3" rough country springs / bilstein 5100's, 31" tires with trimmed fenders, aussie locked front diff, herculined ext, hella FF75 driving lights on factory fog location
[COLOR="Lime"]soon to be[/COLOR] 4.11 gear and and a ford 8.8 LSD rear and herc'd interior
severous01 is offline   Reply With Quote
Old 08-19-2007, 07:45 PM   #9
Matt Gertsch
www.lp.org
No you didn't. Oxy-fuel doesn't run hot enough to melt aluminum.
Roger Waters
Old 08-19-2007, 08:29 PM   #10
Ryanpowell167
?!?!?!?!?!?!?Since when?
DARK STONE 2005 6.0l v-8 PowerStroke F-350
BLACK 1992 YJ 383Stroker, TH350, looking for a np205, d44 front, 12bolt rear, SOA on 4" springs, 35" Baja Claws, m8000, Electric fan, sliders, bumpers, crossmembers, all made by myself.
Black Jeep Club Member #167
Ryanpowell167 is offline   Reply With Quote
Old 08-19-2007, 08:35 PM   #11
Matt Gertsch
www.lp.org
My bad, looks like it does. It would make for a crappy weld though, without any shielding gas.
Roger Waters
Old 08-20-2007, 01:44 PM   #12
bryans98tj
The new Lincoln welders (140 and 180) are set up for an easy install for aluminum. Once you have a welder you simply buy the spool gun kit for about $170 and get the correct gas and you are good. It is on my list of things to buy though I'm not sure when.
Old 08-20-2007, 03:36 PM   #13
jpfaris
1979 CJ7
spool guns, IMHO, are highly overrated. way too much hassle. aluminum was just not meant to be pushed through a nozzle. go with tig, pure tungsten, and pure argon.
79 CJ7, 304, TF727, D300, FULL WIDTH D44's, 4.56:1, SPOOL LOCKERS, SOA, OUTBOARDED, SHACKLES REVERSED, HOMEMADE D-SHAFTS, 38.5" BOGGERS
jpfaris is offline   Reply With Quote
Old 08-21-2007, 02:46 AM   #14
Island4x4
Look up a product called Durafix
you don't need flux or gas for it... it does the job in a pinch
I never did like the pure tungstens for alum tig... always found zirconium to work better, but thats just me.
Old 08-24-2007, 07:58 PM   #15
severous01
i already said that.
Glock Forum
