Bumper tie in metal thickness - JeepForum.com
post #1 of 4 Old 01-23-2014, 05:12 PM Thread Starter
nsargeant
1974 CJ5
I have some 3/16" plate steel left over from a tire carrier/bumper project that i just finished and was wondering if you guys thought it would be thick enough to use as a tie in for the bumper? I just plan on welding 2 pieces at a 90 degree angle with a little gusset in there somewhere. I would like to use the receiver that is built into the bumper as a recovery point.
thanks,
Nathan
nsargeant is offline
post #2 of 4 Old 01-23-2014, 05:28 PM
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
I've seen some Tie Ins made from as thin as 1/8" material. 3/16" will probably be fine. Just inspect it periodically.. especially after a hard tug or towing.
BESRK is offline
post #3 of 4 Old 01-23-2014, 10:07 PM
Shadownwpa
Yea, 3/16" is thicker than your frame. Should be alright.
Shadownwpa is offline
post #4 of 4 Old 01-23-2014, 10:55 PM
RenoF250
That is what I was thinking, should be fine if you do it right - gussets and good welds.
RenoF250 is offline
