building a tube bumper - JeepForum.com
post #1 of 14 Old 08-28-2014, 03:20 PM Thread Starter
4x4Jeep
looking to have a winch tube bumper built and trying to decide if i need DOM or can use Schedule 20, 40, or 80. is the DOM worth the extra cost? this is all new to me so any help is appreciated.
Build -
SOLD
4x4Jeep is offline
post #2 of 14 Old 08-28-2014, 07:15 PM
underpowered
Bouncin' on a Budget
underpowered's Avatar
HREW. seamed tube.
DOM is not necessary for a bumper IMO. but pipe is not teh best choice either, i would (and do) use HREW tube. it has a a welded seam. Cheaper than DOM and comes in the same sizes, where pipe will be sized different
1998 ZJ-- lowered a touch
2005 GMC 2500HD 496 C.I.
Fat Amy-1989 K5 blazer. Linked, lifted, 38.5's on won tons. Big Girls can play in the woods too.
underpowered is offline
post #3 of 14 Old 08-28-2014, 07:51 PM
rjbruzan
Pipe is ok also. As Underpowered said the sizes are different as 4" pipe is actually 4.5". Schedule 40 is a good choice.
Of all the things Ive lost
The one I miss most is my mind
Its like a fart in a windstorm
It smells good but thats about it
Registered Six Offender
Home of the Buzzin Half Dozen
rjbruzan is offline
post #4 of 14 Old 08-28-2014, 11:44 PM Thread Starter
4x4Jeep
ok, thanks. i'm having one built and he's asking me all these questions about what size i want and it's a lot of info.
Build -
SOLD
4x4Jeep is offline
post #5 of 14 Old 08-29-2014, 10:13 AM
AtTheHelm
Usually tube bumpers are made from 1.75"x.120 tube. 1.5" or 1.25" is sometimes used for smaller filler pcs with less structural support.
AtTheHelm is offline
post #6 of 14 Old 08-30-2014, 10:15 AM
Ironworker709
Ironworker709's Avatar
If using pipe,shedule 40 is most common to use for bumpers and such.
Just for an FYI for those who don't know...
HREW tube is the EXACT same thing as common Pipe,the only difference is the sizes,,they are both made of the same exact material and process and then rolled and seam welded
DOM even starts out as HREW,but is then ran through a Drawn Over a Mandrel process.....
Don't DREAM your life, LIVE your dreams
Never forget 9/11
"Welding is like a woman,Get 'er HOT and Penetrate"
Gotta LOVE a person who knows everything about NOTHING
The only Thing necessary for the Evil to win is a good man to do nothing....
"How far you go in life depends on your being tender with the young,compassionate with the aged,sympathetic with the striving,and tolerant with the weak and strong--because someday YOU will have been all of these"....George Washington Carver
Want to know what an Ironworker is and the job scope of a Journeyman?..click here...
Ironworker709 is offline
post #7 of 14 Old 08-31-2014, 10:34 AM
rjbruzan
And "pipe" gets a protective coating applied.
rjbruzan is offline
post #8 of 14 Old 09-01-2014, 01:30 PM
framanda
I thought pipe was a harder material than standard HREW. I have always been told sch 40 pipe was a little more resistant to dings than tube. Also pipe is measured inside diameter, tubing is measured outside diameter 1.5 sch 40 is like 1 5/8 outside diameter.
framanda is offline
post #9 of 14 Old 09-01-2014, 07:36 PM
AtTheHelm
Astm schedule 40 pipe is a different alloy than hrew and dom tube.. It's built to hold pressure rather be a structural building material. There is 'pipe size tubing' though, which comes in pipe sizes but is uncoated and A500 spec for structural use.
Nominal 1 1/2" pipe is 1.90" OD btw.
post #10 of 14 Old 09-02-2014, 08:42 AM Thread Starter
4x4Jeep
would 12 gauge steel be good enough for the front skid? i live in FL and don't do any rock crawling.
Build -
SOLD
4x4Jeep is offline
post #11 of 14 Old 09-02-2014, 01:45 PM
AtTheHelm
12 gauge is pretty light, it's thinner than 1/8". IMO 3/16" would be best regardless, you might encounter a rock or two even in FL.....
post #12 of 14 Old 09-02-2014, 02:42 PM Thread Starter
4x4Jeep
ok, thanks for all the help. i think i have all the info i need.
Build -
SOLD
4x4Jeep is offline
post #13 of 14 Old 09-02-2014, 07:25 PM
underpowered
This was always my understanding.
Pipe is in fact NOT the same as Hrew.
post #14 of 14 Old 09-06-2014, 08:05 AM
Ironworker709
The most common NPS pipes seen and used is A53,the old A36 is pretty much become obsolete.
A53 pipe is for LOW pressure and structural uses..which is the most common schedule 40 mentioned here...........
The most common used HREW these people use and most cost effective is the A513-1..which has several chemical composition allowances according to ASTM from 1008-1015....
To really understand the actual chemical composition difference between the 2 would be to take a close look at the Carbon and Manganese contents in the material itself..then notice the very close if not exact alloy...
Also notice the "loose" requirements of percentages allowable to be "tagged" a certian ASTM
Also notice mills pouring the from the same "pot"(furnace) and spread out to different size tubing/pipe sizes and both HREW or CREW.(i've worked many of the US Steel,Bethlehem,RG Steel,,which is shutdown now in baltimore,etc plants on shutdowns and such and SEEN the actual processes).
If you want to get into a real freindly debate without cluttering this man's thread up anymore than it already has and add any expertise to the actual differences in pipe and tube chemical compositons and alloy mixtures in detail according to the ASTM grades..then lets do it over here and open this old thread up where a few of us who actulay work the trades and hands on expereince chimed in on some pretty good debates on pipe vs tubing to clear up some internet myths and mumbo jumbo...
http://www.jeepforum.com/forum/f37/p...00/index3.html
I'm all for it,for the fact i am in some pre-metalurgic studies at the moment on my own to be more than ready for an AWS-CWI school and test and venture into the WE side of it too(welding engineer)..and i am getting some GREAT help from a GE-Engineer i have known for years as a scheduler on these nuke outages and just this outage he moved up to the new Project manager/engineer for GE now and we are trying to help design some new lifting rigs to make the heavy lifting jobs much easier,safer and quicker..and we have to be "on our toes" so to speak when presenting these designs to the people who will actualy approve the money spent to build these..and that includes knowing the type of steel and such we will be using in our plans..
So i'm all for another debate in that thread to update it if you all like.
Bottom line here,,if i have a choice between common HREW and common NPS pipe and the pipe size fits the purpose..I'd more than likely buy the cheaper priced pipe over the higher priced HREW....
And..i will only reply as i can..i am at the moment in the middle of a Pre-outage prepping for another Turbine outage with GE on overtime and will be on 7-13's and more for a month or 2 in a week or so now..thats why i haven't been around in the past week much
Never forget 9/11
