Building Rock sliders - JeepForum.com
post #1 of 5 Old 07-23-2010, 12:28 AM Thread Starter
Xjpionner
1989 MJ Comanche
I'm about to start making my sliders for my Comanche and I have a couple of questions about the thickness of the steel I'll be using. In the shop I have 3 X 1-1/2 X 11 GA square tubing for the sliders/bracket arms, for the mounting point I have 3/16x6 flat steel. Does that sound like it will hold up? Or should I call my supplier and order some more beefy steel? I'm not attempting to build anything that I can use as a side step/slider I just want some form of protection for my rockers
Thanks
Can't spell my own user name
Xjpionner is offline
post #2 of 5 Old 07-23-2010, 12:47 AM
DannyRoark89
1995 XJ Cherokee
11 gauge is 1/8" so it should be fine. Just search XJ sliders there are a billion threads
i dont know if im the only one getting annoyed with all the people who are to lazy to search something. thats just me though sorry for making you the example your not the only one
But yes just search it with the forums search tool and there will be many threads about custom sliders including steel thickness
DannyRoark89 is offline
post #3 of 5 Old 07-23-2010, 12:49 AM Thread Starter
Xjpionner
1989 MJ Comanche
Thank you, sorry for not searching first.
post #4 of 5 Old 07-23-2010, 10:25 AM
IKIndy
I generally build all mind from TS 2x3 11ga. b/c that is a more common size my supplier carries. 1 1/2 x 3 would be more ideal, but i can't beat my deals.
I also use 1 1/4" sch 40 pipe (1 5/8"OD) for rub rails.
IKIndy is offline
post #5 of 5 Old 07-23-2010, 11:23 AM
DannyRoark89
1995 XJ Cherokee
ya schedual 40 is what i built mine out of, only because it was left over from some hand rails on a job site.
Rock Sliders ragsdale Fabrication Shop 20 01-02-2009 05:42 AM
Rock Sliders help fataltherabbit Fabrication Shop 4 12-27-2008 01:50 PM
Building a small rock garden kydave General Jeep & Off-Road Equipment 7 04-16-2008 06:03 AM
POR 15 on rock sliders? Bot General Jeep & Off-Road Equipment 2 04-09-2007 09:15 PM
Rock Sliders emx Fabrication Shop 3 06-03-2005 12:24 PM
