building rear bumper with tire carrier... need suggestions for 40" tire
#1 | |
BUILT. NOT BOUGHT.
so i plan to practice my rear bumper/tire carrier ideas by building my roommate one for her yj that will hold her 33" spare.....
i've found a few hinges but so far the rockstomper seems to be the strongest... comments? latches seem fairly simple and i'm not too worried about that aspect of it as of now. questions now... what do you guys think of the rockstomper hinge? any other suggestions? it will only need to hold her 33" spare but i plan to use it as a test mule to see how it will hold up to my 40" spare. if it works, i'll reporduce another one slightly different for myself. now before i go and waste my time with something that will never work i'd like to ask if ANYONE has a tire carrier capable of holding a 39.5" bogger SAFELY without the risk of the hinge self destroucting from all the weight and vibrations? if you have indeed made a carrier please give me your insight as to what you did and how you could have improved as well as things you wouldn't do again or products you wouldn't suggest such as particular hinges, latches, sizes of steel, etc. my plan thus far was a 2x4" bumper tied it to the frame with 2x2" square tubing that would make up the simple triangle, yatta yatta yatta... it'll be like practically every other tire carrier out there.... ok, i'm ready... throw your opinions and suggestions at me... -Erik
'89 Wrangler, 4.0/AW4, 106" Wheelbase, SOA, custom XJ packs, 2" Body. Front High Pinion Dana 44 w/yukon super-joints, chromo inners and outers, and a Lincoln Locker. Rear Dana 60 w/Yukon 1.5" 35 Spline chomo shafts and detroit locker. 5.38 Yukon Gears. Hydro-Assist, 39.5x18" Boggers on 15x12 RockKrawler's w/ 2.75" of backspacing. Comp cut, tube fenders, custom bumpers and rock sliders, fuel cell, CB, Stewart Warner Gauges, SmittyBilt XRC8 Winch, 140 Amp CS-144 Alternator, Electric Fan, and a cooler of beer. 3897 lbs March 1st, 8pm. WILMINGTON, NC MEET & GREET @ HOOTERS! |
#2 |
theres a lot of people that go with rockstomper, including myself.
i am only running a 32" tire for now and have no issues or worries. a couple other guys i know have rockstomper hinges on their homemade carriers, running 35's and 37's (GY MT/R's) and they havent had any problems with theirs either. im not sure how it would hold up to the 39.5" bogger. i doubt my jeep will ever get to tires that big so im pretty confident my carrier with the rockstomper hinge will last |
#3 |
Do it right or not at all
![]() Join Date: Jan 2003
I can't imagine a tire carrier made where the main support point is at one end on a bumper could ever hold up for long with a 40" spare tire.
Gone to King of the Hammers, back Sunday! Jerry's Geezer Jeep II Website Getting Savvy... Coolest offroad magazine ever! CRAWL Magazine When you have a choice, buy American.
#4 | |
H2 Recovery Team Member
RIP: '88 YJ 2.5L Ax-5 NP231 Posi-Loked. Herculined. Optima yellow top. 1" Shackle, 2" BDS. Cragar 397's Aussie front. 92 YJ 4.0L Ax-15 231 5" springs, 1" shackle 31's or 35's depending on my mood |
#5 |
GROUND POUNDER
Not sure what size the Rockstomper spindle is but I'm gonna assume it's a 1000lb rated piece. If I were gonna hang big rubber off it, I'd go with a 1750lb rated spindle and have the spindle hub tube machined accodingly. Or maybe use a piece of 1.75" OD cold rolled solid stock and just get a piece of thick walled DOM to fit over it as the hinge.
'80 CJ5 w/AMC360, T176, D44 w/Detroit 3.73s, RE 4" YJ lift and 35s.. Lower 2 Guardrail Down Schoolbus Slickrock Tellico Save Crozet More Crozet |
#6 |
BUILT. NOT BOUGHT.
thanks for the suggestions guys. maybe this is just a bad idea....
the more i think about it, the only time i would probably ever need the spare would be when off road and i don't carry more than 1 passenger then, so maybe i'll just make a carriet that will mount to the roll cage that is removeable..... the idea of a 2x5 or larger bumper is a great suggestion... in fact, i have a local metal shop with a 10' stick of 3x5 he said he'd sell me for $10 that i might consider... that is, if i decide to go on with this build. perhaps i'll get my rommate's built and then go another route on my own vehicle. beserk i think if i do go ahead with this build, i'll be following your advice.... very wise thinking....
#7 |
The main issue when going with larger (more the 4" deep) tubing is the spindle is too short. I ended up purchasing two spindles and welding them together and cutting to the needed length when I built mine. My bumpers are 2x5x1/4"
Another couple things... The latch I bought from McMaster Carr (www.mcmaster.com) p/n 5071A62. It is a De-Sta-Co latch. It has a double lock however. They sell regular ones for about 2/3 of the price of this one. When welding the stuff together make sure to distribute your heat. I didn't and my carrier warped about 3/4". It is a little upsetting when you spend endless amounts of hrs and find out everythign is off. My carrier is built from 2x2x1/4" tube.
'84 CJ-7 Junkyard TBI 360/T18/D300, 4" 4WDH Lift, D44 front with ARB and HS/D44 Rear w/ Detroit, 4.56s, 36" Iroks, TFI, TJ flares, Homemade rocker guards and bumpers with swing out, Optima Yellow Top, M8000, York OBA, 6pt cage "when you're up to your *** in alligators, it is hard to remember that your original intention is to drain the swamp" |
#8 | ||
Disgruntled Jeepforum'er
Location: NY/NJ/PA Tri-State Middletown NY 10941, New York
Look into the poison spider stinger bumper. That bumper hinges from two ponts and sectures by another two points. It's the best design that I can forsee for something that you plan to do.
-Ryan Google Voice (or the number Grape calls when drunk): 845-476-8182 Quote:
#9 |
Look at this site the tire carrier hinge is a 1" Grade 5 Bolt Welded into the 2x4 bumper..... There is no need for bearings, except maybe to pay more for your hinge. It's not a axle so you dont need'em.
http://wrangler.kicks-a$$.net/index.htm Replace the $$ with ss.
[B]Engine:[/B] 4.2L L6 258 [B]Trans:[/B] Automatic [B]Carb:[/B] Stock 2Brl [B]Exhaust:[/B] Dynomax [B]Ignition: [/B]Stock [B]Suspension : [/B]1" Prothaine Body Lift [B]Rims:[/B] Stock [B]Tires:[/B] P235/75R15 [B]Wench:[/B] 7500lb Champion [B]Interior:[/B] Bedlined [B]Paint:[/B] Custom Camo [B]Driving lights:[/B]Hella 500's [B]Rear Lights:[/B]50w Halogen [URL="http://www.cardomain.com/ride/2426963"][B][COLOR="Silver"]My Jeep Website[/COLOR][/B][/URL] Last edited by horseman; 10-04-2006 at 02:59 PM.. |
#10 |
Just thinking out loud here, but what if you made the tire carrier swing open horizontally. Take a utility trailer tailgate into mind, something like that. You could use multiple hinges and then use 3/4 pins (hardened of course) as latches. I would think that to be a good solution, swing away to allow the hatch to open, as well as to lower the tire toward the ground. Like I said, just a thought.
Jason
DD-- 2005 Dodge Ram 2500 Cummins TD Quad Cab 4x4 6 speed Toys: 1998 Sport Auto trans, 3.73 gears, D30/lockright D44/Detroit, 33" Mud tires, FT LCA's JKS Adj. Trac bar FT 4" coils, RE GEN II Disco's--1 1/4 JKS BL, 1" MML XD9000i up front, HD bumpers with extraction points.-Done. 1973 cz 250 MX Not much suspension, but 36 BHP at 6k rpms! 2006 Rhino SE, 27" Mud lites and a cupholder. http://www.caos4x4.com/cmbs/index.php |
#11 | ||
Aside from the hinge strength, I'd also think that on a conventional a-frame type bumper/carrier you'd have to worry about the carrier leaning away from the body over time due to the size and weight of the tire. Something else for you to think about. Good luck and let us all know what you end up doing.
99 Sport I6 Auto | 4" Currie/ProComp/Skyjacker| 35" BFG KM2's on black steel rims | LoD xtreme duty rear bumper/tire carrier | Rokmen Mercenary rockers | Quote:
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
