Building an Off-Road trailer. Pintle ???S
| Truck-Lite's New LED Headlamp Series | 4.25" 97-06 Jeep TJ Wrangler Lift Kit - NO SYE Needed | Ruffstuff Axle Simple Swap Kit! |
#1 | |
I want to build a trailer for off-road.
What do I need to know about pintles? It looks like you can get different sizes of rings. How do I know which to buy? Does anyone have a close up of the tongue/ring on a homemade trailer? I am having a hard time envisioning how to build the tongue to use one of these: http://www.etrailer.com/mm5/merchant.mvc?Screen=PROD&Store_Code=E&Product_Code =63023 http://www.etrailer.com/mm5/merchant.mvc?Screen=PROD&Store_Code=E&Product_Code =63023
#2 |
Not hard to envision. The part you have pictured it what goes on the tongue end of the trailer. Mount it horizontally.
The only real bad thing with a Pintle Hook mount is that it jerks when you start going and smacks into you when you stop. Translation for what I just wrote.......... It is not as smooth as a tow ball. If I was going to make an off-road trailer I would go with the Pintle Hook system.
Dave 2004 Rubicon with a bunch of stuff added. <-----------------------------------------------> Are you an NRA member? You should be. [URL=https://membership.nrahq.org/forms/signup.asp]Click here to join.[/URL] |
#3 |
Some Call me RockDog
www.tentrax.com makes trailer and you can get an option of both a coupler and a pintle hitch. coupler for street and pintle for trail.
![]() ![]() I like this hitch design for the trail... from www.adventuretrailers.com ![]() I think having a removeable hitch on the trailer end is a good idea for street and trail use.
Stretched TJ Future, Coil overs, 40s, 60/14 bolt My Build Thread. www.kifourwheelers.com www.indyorv.com For Sale: TJ 44 Combo, 4.88s, detroit, Alloy USA shafts, Disc Brakes, HD lower mounts, Clayton tube Truss 35" procomp tires with Aluminum wheels $650 (4) 5x4.5 steel beadlocks $200 3 11"& 2 13" BBCS shocks Ford Dana 60 Rear $150 Big Daddy Offroad HD tie Rod (4) 15x8 5x4.5 TJ, YJ, XJ, etc bolt pattern Aluminum wheels $175 |
#4 |
Anyone have closeups of homemade trailer tongues?
#5 |
not exactly a close up but it may help ya. It uses a removable coupler made from
3" x 1/4"wall with a 2 1/2" x 1/4" sleeve. It works well. ![]() The lock an roll hitch last pictured works very from what I've heard, but expensive. Pintles are tried and true, probably what I'll use.
[URL="http://www.rccrawler.com"][/URL] |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
