Building my first cage, maybe a n00b question. - JeepForum.com
post #1 of 10 Old 05-28-2013, 02:25 PM Thread Starter
warthog312
Ok so I'm building my first cage for my YJ. This will be a DD/Trail warrior. I've got her down to the frame right now, doing a whole ground up build, including a Ford 302/ T-18 powertrain. Check my other threads for updates.
Past that, I'm having what seems like a childishly simple question which has me stumped...
How on God's green earth do you retain the flange and bolts which hold up the windshield on the YJ when inserting a spreader bar and full A pillar bars down to the tub? It seems like you'd never be able to secure those 3 bolts from the factory "cage" to the windshield? And no, I'd rather not make it permanent by welding it in, because I do enjoy folding my windshield down from time to time.
Any advice here guys? I feel like an idiot for even asking
Click for build thread:
- 302//435//20//8.8
>>>the single greatest investment you can make for your jeep is to buy a good welder, and learn how to use it<<<
warthog312 is offline
post #2 of 10 Old 05-28-2013, 10:20 PM
fratis
fratis's Avatar
I removed them and dont even bother. Originally i used small straps to hold the frame to my cage at the top but dont even bother with that either. Stays up fine. I usually use a bikini and that is enough to hold it. It even works without the bikini. My cage does not have the silly spreader bar type tie ins. I fold down the frame and often remove completely for wheeling.
-insert meaningless out-of-place political diatribe-
fratis is offline
post #3 of 10 Old 05-29-2013, 08:58 AM
onlyinayj89
x2 ^^^
onlyinayj89 is offline
post #4 of 10 Old 05-29-2013, 12:22 PM Thread Starter
warthog312
OK. So, how do you fold down your windshield when the pillar from the top lateral bar down to the floor/frame is in the way? Can you still get to those 3 winshiled hinge bolts or at least the one necessary to fold down? Also, your rig look more purpose built trail only, mine is still daily driven at least a few days per week and needs to withstand highway speeds as well as a hard top in the winter, that's why this is kind of an important question.
Not sure what you mean when you say "spreader bar tie ins", care to elaborate?
- 302//435//20//8.8
post #5 of 10 Old 05-29-2013, 01:28 PM
fratis
fratis's Avatar
I push on the glass..
The bolts are gone never to return. With the fenders on, windshield on, and the street tires my jeep is a DD.
Some people cut off the flanges on the factory spreader bars that connect the factory bars to the windshield, and reuse on their custom cage.
fratis is offline
post #6 of 10 Old 05-29-2013, 02:54 PM Thread Starter
warthog312
so are you saying that NOTHING holds your windshield upright then save for a bikini top? Not those 3 torx by the factory dash speakers?
So if you're running down the road with no top, but you want to keep your windshield UP, what's keeping it from flopping down when you hit the brakes?
Maybe I'm missing something here....
- 302//435//20//8.8
post #7 of 10 Old 06-02-2013, 08:24 PM
onlyinayj89
Yes, just make sure there is enough room between your A pillar and dash area , just enough room so you can get that one bolt out with an open wrench. That one bottom bolt is all you need to fold the windshield down and up.
post #8 of 10 Old 06-06-2013, 04:24 PM
Copperhead89
I recently built a roll cage for my YJ, using Poison Spyder's Lazer Fit Full Cage kit. The kit didn't have any provision to secure the top of the windshield frame, so I fabbed up some mounts.
My YJ/CJ V8 Magnum Build: http://jeepforum.com/forum/f22/magnum-force-mopar-mans-build-1412306/
Copperhead89 is offline
post #9 of 10 Old 06-07-2013, 11:40 AM Thread Starter
warthog312
Awesome. Thanks Copperhead, that's what I was looking for. Even if I just may a quick disconnect version with a codder pin, it will at least be some sort of peace of mind for me. Thanks!
- 302//435//20//8.8
post #10 of 10 Old 06-07-2013, 04:42 PM
schitzangiggles
King of Macastan
schitzangiggles's Avatar
You could even do a coupla rubber bump-stops and a 500# ratchet strap, Cotter pin would be way "rattlely". Uber quick and easy.
"Axeheads are supposed to be sharp, but you are one blunt tool."
FLynes
If you love wealth more than liberty,the tranquility of servitude more than the animating contest of freedom, go home from us in peace. We seek not your counsel nor your arms. Crouch down and lick the hand that feeds you. May your chains sit lightly on your shoulders and may posterity forget that you were our countrymen.
-Samual Adams
A government big enough to give you everything you want is big enough to take everything you have.
Thomas Jefferson
Calling Illegal Aliens "Undocumented Immigrants" is like calling drug dealers "Unlicensed Pharmacists"
Nemo Me Impune Lacessit
"No one provokes (attacks) me with impunity".
"Your right, the Tea Party and the OWS are the same, just like the America Revolution and the French Revolution were the same. The only problem is the American Revolution ended with Liberty, Freedom, Justice for all and a shining light upon a hill. The French Revolution ended with lynchings, guillotines, murder and socialism. So yeah, I could see how one could confuse the two..."
Mac Wilson
schitzangiggles is offline
