building long arms, need help - JeepForum.com
post #1 of 15 Old 12-20-2012, 10:30 PM Thread Starter
tjhomeboy
So I wanna build some long arms for my tj. I have about 4 inches of lift and some 35s. I have a bunch of free metal and am in school right now to be a welded so that's not a problem.
My questions are would sold bar work or is that to much? Where do I get the joints? I heard something about johnny joint and I think there made by currie
Thanks for the help
tjhomeboy is offline
post #2 of 15 Old 12-21-2012, 03:01 AM
lamar_j77
Johnny joints (correct, made by Currie) or Heim Joints are what you will need. All of the fab material places resell them. You will need DOM for the links. Some folks with deep pockets go aluminum. Also, I recommend using the calculators:
http://www.jeepforum.com/forum/f369/...ators-1301802/
lamar_j77 is offline
post #3 of 15 Old 12-21-2012, 05:11 PM Thread Starter
tjhomeboy
Thanks that's a lot of help
post #4 of 15 Old 12-21-2012, 07:49 PM
jasonswelding
Rustysoffroad.com has some good stuff.
jasonswelding is offline
post #5 of 15 Old 12-22-2012, 03:29 PM
sailsurf7713
No they don't.
'99 SE: The "It could be worse..." jeep
Originally Posted by 97flexy View Post
...I say don't lift but CUT. :)
sailsurf7713 is offline
post #6 of 15 Old 12-22-2012, 06:06 PM
wushaw
Rockin jeep
wushaw's Avatar
Square tube also works well and can be had at most metal yards.
wushaw is offline
post #7 of 15 Old 12-22-2012, 09:02 PM Thread Starter
tjhomeboy
Nothing cheaper than free thou
post #8 of 15 Old 12-23-2012, 08:00 AM
rchase559
Do you have the ability to drill an tap them or do you just plan on getting them close enough and burning everything in?
rchase559 is offline
post #9 of 15 Old 12-23-2012, 09:13 AM
jasonswelding
Originally Posted by sailsurf7713 View Post
No they don't.
More info please. I haven't bought from there. I just meant they had a lot of parts needed. You may save me from buying bad stuff.
post #10 of 15 Old 12-23-2012, 11:28 AM
JohndKc
1987 YJ Wrangler
Free is free, but you're still going to spend a good chunk of change to build your own long arms. The correct joints, either heim or Johnny, are expensive. I spent 60 dollars on one, when i decided i wanted some lateral motion in my ladder bar.
33rd BCT
Alpha 2/122 FA
68W
JohndKc is offline
post #11 of 15 Old 12-23-2012, 02:11 PM
sailsurf7713
Some of their builder stuff is alright. However, their customer service is well documented as horrible and their stuff is no better than any other fab company out there.
Joints, bushings, shocks, stuff like that. Downright miserable quality.
post #12 of 15 Old 12-23-2012, 08:39 PM
Griff1918
Lowrange has the cheapest weld in bungs I have found. Telco has the cheapest price on johnny joints.
Griff1918 is offline
post #13 of 15 Old 12-25-2012, 10:18 PM Thread Starter
tjhomeboy
Yeah I am a machinist and have access to machines so ill probably drill and tap it out
post #14 of 15 Old 12-25-2012, 10:32 PM
Ripper3494
When building my arms the calc was really no help, don't over think it, just build some adjust ability in the upper frame mounts
Make your arms as flat as reasonably possible
Make your arms as long as reasonably possible
Vert separation at axle should be about 25% of your tire height
Frame separation should be about 80% of your axle but build vertical adjustment into the mounts incase your suspension jacks or squats too much
Triangulation of either uppers or lowers should be greater than 40 to keep the axle nice and controlled
I like my uppers being a little longer than my lowers to help the pinion track nicely
Others may say different but this is what I've seen to work. Every Jeep is different
build thread:
1997 ZJ limited - BONE stock
RC vs BDS
Ripper3494 is offline
post #15 of 15 Old 01-12-2013, 06:23 PM
LJWrangler
I think he was saying LONG ARM not 4-link. Long arm is simple- Just make sure and lock/brace and tack the axle into place before you remove the arms to start building. all you need to keep the axle from moving is 4 pieces of angle or square tube- tacked to the axle and the frame to keep it from moving.
SILVER JEEP CLUB #71
My Build
LJWrangler is offline
