Brazing Aluminum..? - JeepForum.com
post #1 of 9 Old 01-07-2012, 06:18 PM Thread Starter
Jeremylerv
2003 WJ
Brazing Aluminum..?
Is it possible? If so, how hard is it? I have quite a bit of welding experience but I've only brazed a handful of times, and I would be brazing the keel on an aluminum boat.
.,_______.o_o.
//_|__l__,\___\,___
l_--\__\__l----[]llllll[]
(o)_)____(o)_)--o)_)
Jeremylerv is offline
post #2 of 9 Old 01-07-2012, 06:21 PM
TjinTopeka
I braze copper to copper all the time at work, I wouldn't think aluminum would be that much harder/different. Just get the proper brazing rod and go to town.
TjinTopeka is offline
post #3 of 9 Old 01-07-2012, 06:24 PM
youngjeepr
its possible but im not sure how difficult it is i wouldnt think it would be to hard
88 YJ- 4.7l stroker, AW4, SOA, 8.8, hp D30 powertrax no slip,3" front stretch with waggy springs, stock replacement springs in the rear, 35/12.5 r15 goodyear kevlars
youngjeepr is offline
post #4 of 9 Old 01-07-2012, 07:19 PM
wushaw
Rockin jeep
wushaw's Avatar
Good luck on brazing aluminum with something other than aluminum.
wushaw is offline
post #5 of 9 Old 01-07-2012, 09:16 PM
Netpackrat
Easy, if you have the right stuff. This is the right stuff:
http://www.tinmantech.com/html/brazing.php
Netpackrat is offline
post #6 of 9 Old 01-08-2012, 07:29 AM
jasonswelding
You can use aluminum welding rods to braze. Make sure everything is clean. I've done it before but is was years ago.
jasonswelding is offline
post #7 of 9 Old 01-08-2012, 10:49 AM
snofrog
the welding shop I work at will charge double to anyone that tried it first and failed ... just saying
snofrog is offline
post #8 of 9 Old 01-09-2012, 01:24 AM
shadowulf
What are you trying to braze?
There is always this stuff... http://www.durafix.com/
shadowulf is offline
post #9 of 9 Old 01-09-2012, 07:20 AM
Netpackrat
Mig Aluminum Cts6867 Fabrication Shop 6 08-06-2008 11:41 AM
Backspacing of stock XJ aluminum wheels vs stock TJ/LJ aluminum wheels (non-Rubi) ? CB3 Tires & Wheels 5 12-27-2007 09:54 PM
Chromed aluminum, polished aluminum or other? red7 Tires & Wheels 4 06-18-2007 01:08 PM
JB Weld or Brazing valeech Fabrication Shop 2 08-04-2006 09:10 PM
Aluminum MeCasa Fabrication Shop 27 04-26-2006 04:34 PM
