bolt removale and install - JeepForum.com
post #1 of 4 Old 07-13-2004, 07:31 PM Thread Starter
83 cj-7 258
83 cj-7 258's Avatar
I was almost done putting a new steering box in, when on of the bolts that go into the frame, heads snapped. I've been told to bound it out with a hammer. Is there any tricks to installing the pitman arm. I only have basic hand tools.
THANKS!
83 cj-7 built Chevy 350, sm420, dana 300. Superlift 4in lift, 33x12.50 mikey thompson mtz.
83 cj-7 258 is offline
post #2 of 4 Old 07-13-2004, 08:50 PM
BigWaylon
tubework is cool...
BigWaylon's Avatar
THANKS!
you can go buy a pitman arm puller for $10-$15 at your local parts store...
something like this:
http://www.harborfreight.com/cpi/cta...emnumber=36861
or
http://www.harborfreight.com/cpi/cta...emnumber=36865
these are cheaper, but you might not have a Harbor Freight close to you...
Greg
2001 TJ 60th Anniversary Edition (details in Profile)
BigWaylon is offline
post #3 of 4 Old 07-15-2004, 10:39 AM
dzp
dzp's Avatar
Go to sears and get you a screw extractor. They work pretty well if you are carefull. Basically you drill a hole in the bolt, then screw this in and it backs the bolt/screw out.
As for the pitman arm, the puller is great to have when removing the old one. Just tap the new one on. Use a rubber hammer or a block of wood to keep from messing up the arm.
Tyler, Texas
97 TJ, Red, 33" MTR's, Locked F/R, D30/Ford8.8, JKS Disco's, DT3000's, tinted Sailcloth top, 8k Ramsey, Custom bumpers/armor, Ramps 890 on 25degree ramp.
dzp is offline
post #4 of 4 Old 07-16-2004, 07:06 AM
JKNIPE2000
JKNIPE2000's Avatar
dont use heat on the pitman....it will come off just takes some finess...
heat can distort the metal properties and weaken it...there is a lot more stress on that arm than people realize. weak=bad
Gone but not Forgotten:
1990 Islander O.D. Green
Currently no Jeep, but I'm in the market
JKNIPE2000 is offline
Source for bolt-in D60/Ford 9"/GM 14 bolt TJ axles? flatlander757 Engines & Drivetrain 2 01-21-2008 04:14 PM
Lower control arm bolt on a skid plate install rudy99 General Jeep & Off-Road Equipment 2 12-19-2006 12:10 PM
tj belt removale DrewZ Engines & Drivetrain 1 05-18-2004 05:36 AM
Front Spring Install (Stiff Bolt) BzJeep Tires & Wheels 11 06-20-2002 03:48 PM
