on-board air compressor question - JeepForum.com
post #1 of 8 Old 05-16-2004, 09:50 PM Thread Starter
Poseidon17
Poseidon17's Avatar
I have access to the various write-ups for this project, but none for on a '98 TJ 2.5L with NO A/C. If anyone has a writeup specificly for that type of jeep, please post it. Once I get a york air compressor, will I be able to just bolt it onto the alternator (there are mounting holes there where the air conditioning compressor would be if I had one) or do I need a braket from www.onboardair.com to make it fit?
Jeepless...for now...
Poseidon17 is offline
post #2 of 8 Old 05-19-2004, 12:14 AM
Rio_Grande
You need a bracket so that the york will mount to the ac holes. The holes are diffrent.
I love this crap!!
Rio_Grande is offline
post #3 of 8 Old 05-24-2004, 07:40 PM
V8wrangler_idaho
just get a stock ac unit for your jeep. with the stock mounts. an ac is pretty much the same thing as a air compresser. the ac will do the job of a air compressor very well.
Daniel Mclay
93 wrangler 8 inch SOA SRS suspention lift 35/12.50 Mt. efi 350 700r4 tranny np 205 t case dana 44s front and rear. lots of extras.
V8wrangler_idaho is offline
post #4 of 8 Old 05-25-2004, 04:49 AM
bullyyj
Oba Compressor
I have to agree with V8 Wrangler. I went to the junk yard and picked up a $75.00 stock compressor. It bolts right on and you can find the longer replacement belt at your local parts store.
If you want pics send me a email.
bullyyj is offline
post #5 of 8 Old 05-25-2004, 09:09 AM
V8wrangler_idaho
at least somebody thinks im smart. LOL
Daniel Mclay
post #6 of 8 Old 05-27-2004, 02:28 AM
JIM79CJ7
JIM79CJ7's Avatar
I believe the stock pump is a sanden compressor , which will make air , but is in no comparison to the cfm a york puts out . if your just gonna pump up tires go to the junkyard and get the pump and bracket out of a similar jeep , don't forget to get the belt and idler pulley if it is equipped .
originally posted by Mikeythefireman :
Mr. Bill, you're a Jacka$$! or should I say 'drack you're a Jacka$$ I was looking for a straight answer there.
Custom Stuff---
ORANGE JEEP CLUB
MEMBER # 1
1979 CJ7 / 304 /T 150 /HUGGER ORANGE PAINT JOB/ Lots of cool stuff
2003 Inca Gold Rubicon , <------ Sissy jeep :)
JIM79CJ7 is offline
post #7 of 8 Old 06-17-2004, 12:40 PM
JeepCrawler_98
JeepCrawler_98's Avatar
Actually the sanden compressor is very close to capacity of the York - not as powerfull, but close. Downfall is that you need to lube it as air passes through the compressor, with the york you dont. WIth that said, I went with sanden because it was easy - here's my writeup: http://4x4tj.dyndns.org:81/articles.php?id=6 and http://4x4tj.dyndns.org:81/articles.php?id=7 Since then I've replaced the filter with a coalescing type so all oil is removed.
New kid on the block!:
JeepCrawler_98 is offline
post #8 of 8 Old 06-18-2004, 08:31 PM
JIM79CJ7
JIM79CJ7's Avatar
Downfall is that you need to lube it as air passes through the compressor, with the york you dont. .
I have seen many people use the PVC line or the breather off the valve cover as an oiling source , a fine mist of oil is all that is really needed for the Sanden .
Custom Stuff---
ORANGE JEEP CLUB
MEMBER # 1
JIM79CJ7 is offline
On board air using an AC compressor Ratmeat General Jeep & Off-Road Equipment 11 08-20-2008 02:55 PM
On Board Compressor surfcaster General Jeep & Off-Road Equipment 13 07-11-2007 04:43 AM
on board air compressor from a lincoln EMT General Jeep & Off-Road Equipment 12 04-28-2006 11:10 AM
Will this compressor work for on-board air? webdr Fabrication Shop 7 03-19-2006 08:48 AM
On board air compressor help FearTheDentist General Jeep & Off-Road Equipment 1 05-06-2005 12:55 PM
