Blue Torch Fab trail cage modified and installed - JeepForum.com
post #1 of 16 Old 04-03-2012, 01:48 PM Thread Starter
svtkev
posted this in the TJ tech section,then realized it might be better off here
http://www.jeepforum.com/forum/f9/bt...alled-1351941/
finally installed my BTF trail cage ,turned out really nice,we modified it so it can be removed in sections instead of a 1 piece cage
welded nuts inside the dash bar and bolted that thru the uprights
sleeved the center bar and bolted the spreader bars thru that with some massive bolts from a mercedes k-frame (at least 18mm bolts,the hex on that bolt is 1-1/16")
added some grab handles
added a rear spreader bar
painted a piece of sheet metal for the backside of the BTF logo,color is a little off but not too bad,looks better in person
sleeved the rear bars for a later rack project
painted it with rust-oleum truck bed coating
svtkev is offline
post #2 of 16 Old 04-03-2012, 03:13 PM
youngjeepr
just curios why would you want to remove it in sections?
88 YJ- 4.7l stroker, AW4, SOA, 8.8, hp D30 powertrax no slip,3" front stretch with waggy springs, stock replacement springs in the rear, 35/12.5 r15 goodyear kevlars
youngjeepr is offline
post #3 of 16 Old 04-03-2012, 03:18 PM
DualPurposeXJ
1994 XJ Cherokee
x2
If you're in control you're not going fast enough - parnelli jones
DualPurposeXJ is offline
post #4 of 16 Old 04-03-2012, 03:37 PM Thread Starter
svtkev
In case I have to remove the dash ( or even replace a speaker) sometime, and it was alot easier to put it in the jeep in sections
svtkev is offline
post #5 of 16 Old 04-04-2012, 01:48 AM
karlo
Looks good and tough. Great job!
karlo is offline
post #6 of 16 Old 10-10-2012, 01:48 PM Thread Starter
svtkev
Little follow up info on the rack project that i sleeved the cage for
This was a hitch basket we hacked up
Wanted something we could take some things with us when we go on the dunes
since it bolts to the cage its plenty strong ,i was up on it and i weigh 235,its solid
Top goes on with the rack on just not the back window
good for haulin tires
or entertainment centers haha
svtkev is offline
post #7 of 16 Old 10-11-2012, 06:05 PM
sailsurf7713
That looks awesome. I like the modular idea. I may have to steal the idea for the rack as I never use a rear window. Only recommendation would be to round the corners on that angle before it unexpectedly gets someone. I'm torn between the BTF cage and the one Poly sells (which is twice the price!). Just don't like the fact that the BTF doesn't go through the dash, although it does look pretty stout.
'99 SE: The "It could be worse..." jeep
Originally Posted by 97flexy View Post
...I say don't lift but CUT. :)
sailsurf7713 is offline
post #8 of 16 Old 10-14-2012, 07:35 PM Thread Starter
svtkev
Thanks man , I had planned on rounding those edges but didn't realize I didn't do it until I was painting it , too late , still gonna do it maybe over this winter
Thanks for the compliment
svtkev is offline
post #9 of 16 Old 01-14-2013, 09:49 AM
duc202
wow, that looks real good
can you still put on your hardtop/after installing the cage?
duc202 is offline
post #10 of 16 Old 01-14-2013, 09:50 AM
duc202
also, i didnt notice, but would the stock sound bar be able to be used with the cage?
duc202 is offline
post #11 of 16 Old 01-14-2013, 09:57 AM Thread Starter
svtkev
I dont have a hardtop so im not sure , it doesnt interfere with the soft top at all so i would think it would fit ok,not sure tho
If the spreader bars were welded the soundbar would work ,the way i bolted mine together it would require it to be moved back an inch or so.
I dont use the soundbar in mine so i didnt miss it
svtkev is offline
post #12 of 16 Old 01-14-2013, 03:15 PM
duc202
it looks good nonetheless dude
the top spreader bar at the rear of your jeep...did that come with the kit or was that something that you fabbed up? i didnt see it listed with the kit on their website
the price is fantastic also
duc202 is offline
post #13 of 16 Old 01-14-2013, 04:16 PM Thread Starter
svtkev
We made that rear spreader bar , they sell some bolt in ones but they are straight bars and leave no headroom for rear passengers
svtkev is offline
post #14 of 16 Old 01-19-2013, 02:57 PM
Molonlabemike
Nice work and it looks thought out. Not a big fan of the bolt together setup but to each their own
Molon Labe
Molonlabemike is offline
post #15 of 16 Old 05-08-2013, 08:20 AM
mrJ
2002 KJ Liberty
started mine last night and having issues with the a-pillar and windshield support lining up. huge gaps at the welding areas. also, with the extra dash side plates, do you weld those on and then the lower windshield bar to that or just the windshield bar to the dash panels? and how the **** do you mount the windshield support to the rollbar? i see how the diamond shaped plate ties into the windshield, but the rollbar i can't figure out how that plate works. or do you just weld it to the rollbar? i emailed BTF and they weren't much help. i'm just worried now that we should have welded that extra dash side panel plate on first and then put the windshield bar on. but like i said, btf wasn't a big help when i emailed and just kinda said, "it's diy, good luck"
Build In Progress...
It's a Jeep, it's not supposed to work right all the time.
Live in Florida? Check out Florida4x4.org!!!
mrJ is offline
Low Life Chassis Build.... Blue Torch FabWorks BlueTorch Fabrication Shop 12 05-11-2009 08:31 AM
PSC Trail Cage Install Unlimited04 Fabrication Shop 3 07-27-2008 09:51 PM
PSC Trail Cage Black Hills TJ General Jeep & Off-Road Equipment 2 01-11-2008 04:12 PM
Trail Cage Black Hills TJ General Jeep & Off-Road Equipment 1 11-23-2007 04:12 PM
chasing contact for blue torch fabworks aussie stu Fabrication Shop 4 06-25-2007 02:00 PM
