best welder - JeepForum.com
post #1 of 8 Old 09-20-2007, 07:20 PM Thread Starter
Wrangler91
best welder
I was looking into getting a welder for some fab work and stuff. Just wanted to know what everyone here had. what is the best kind and type of welder to get for making fenders, possible frame strech, ect. basically just a good everyday welder that will get the job done, but not cost a fortune.
Wrangler91 is offline
post #2 of 8 Old 09-20-2007, 07:27 PM
Jeepinjon
I have the Hobart 145 Mig. Running it gasless, others will tell you to run gas. I don't recommend it if you're welding outside or somewhere that might be drafty. However, I prefer a stick welder, I feel I have more control over the puddle. Anyway, go with what you're more comfortable with. I just used my MIG to fab up a pulley bracket for a customer's leg press. It needed to hold 400lbs. The little 145 handled it just fine, now the leg press frame flexes, not my bracket. Anyway, good luck. I know I got off topic a little, sorry about that.
Jeepinjon is offline
post #3 of 8 Old 09-20-2007, 07:30 PM
mean90yj
Yota Recovery Specialist
mean90yj's Avatar
i have been lookin at a MIG for a while....from the research i've done the lincoln 175 MIG seems like the best pic of the bunch. its not too expensive but its a welder that will give you what you need, its also the easiest to learn on if you've never welded before.
'90 I6 258 w/ Weber 32-36 Carb.
32" BF M/T's with cragar rims
5" BDS springs, MORE greasable shackles, XJ driveshaft, AA SYE kit, RE SS brake lines. Bilstein 5150's, 255/70 valving all around, 14" travel in front, 10" in rear.
~Enjoy>>>
JF MOTO>>>>"Ban a tard...save a life" <<<contributed by leftlanetruckin
OMNIPOTENCE...gotta get me some of that
mean90yj is offline
post #4 of 8 Old 09-20-2007, 07:38 PM
dgm5186
I just bought a Miller 140 with the autoset feature(10 more dollars over regular 140, figured why not) Anyways I have the gas for it and I must say, it is a very very nice welder for the money. Sure 550 dollars is expensive but you get what you pay for. Good luck!
dgm5186 is offline
post #5 of 8 Old 09-20-2007, 08:00 PM
Joe Dillard
Electric Chair Operator
Joe Dillard's Avatar
I bought a Hobart 135 Handler & mix tank some years ago & it did a nice job for a 110V welder. No complaints at all for what it was designed to handle.
May of last year I decided I wanted to step-up my welders capabilities and do some fab work that requires a better overall welder. My choice was a MillerMatic 175 220V MIG & I use a CO2/Argon 25/75 mix tank for shielding gas. I got a great deal on it thru a local Miller distributor - so I couldn't pass it up.
Joe Dillard is offline
post #6 of 8 Old 09-21-2007, 07:26 AM
Bigbob
Bigbob's Avatar
Originally Posted by Wrangler91
I was looking into getting a welder for some fab work , possible frame strech, ect. but not cost a fortune.
You have some words in there that don't match. Frame stretch and cheap welder. If you want to weld Mig, and most people prefer Mig, then get a 220 volt unit. The Lincoln 175 or Hobart 187 is as small as I would go. So cheap is tossed out the window. The above welders can be had for about $650.00 but you will also need to get a shielding gas tank. I have the Lincoln 140 AMP 110 volt unit, and although it works very well, I'd never trust welding a frame with it. Just not enough heat. I will keep it to weld the thin stuff as it makes some very nice looking welds on 1/8" metal and smaller. But I am getting a stick welder to weld up the heavy stuff. Stick welders are 1/2 the price of a Mig. 1/3 the price if you just go A/C. Most on here don't like stick welding. But it is a very viable option for many.
If you want to stay Mig and your budget can handle it I would suggest a Hobart 187 Handler or 210 Ironman. TSC has good prices on them. If you need to stay with 110 volt units, the Lincoln or Hobart 140 is really a nice welder, but I would leave the frame welding to someone else.
Whatever you do, stick to the name brands. Miller/Hobart/Lincoln. These are proven welders and parts are available everywhere for them.
2006 Solar Yellow Rubicon Unlimited
Jeep Club Member #1340
6 Speed, Hardtop
Mods done: Hurst tee handle, cheap hand throttle, Rokmen Merc front bumper, Warn 9.5 TI winch with 3/8" X 100 worth of Viking yellow rope, DPG OME Ultimate with JKS ACOS up front, Kilby Gas Tank Skid, Kilby Steering Box Skid, Jeep Medic Belly Up, Skidrow Engine Skid, Rockcrusher Diff Skid in the rear, Warn Diff cover in front, , AR Outlaw II's and MTR 12:50/15's, Homemade rear Bumper, Cheap Cobra CB, Puma OBA, Sirius Radio, Locker Defeat, Rockhard cage, Rockmen short corners, homemade tire swing/tailgate hinge affair, Airlift air bags on the rear- - - - - - and more to come!
Bigbob is offline
post #7 of 8 Old 09-21-2007, 08:30 AM
rustywrangler
Got my eye on you.....
rustywrangler's Avatar
with Bigbob.
If you want to start welding on frames and do it right, you need to invest to begin with. Myself, I have the Millermatic180 ( same as Joe Dillard's only the next generation) Mig 220V with a 60CF C25 Gas bottle. From my Local welding supply, not a major chain, I was out the door for about $950 in the end with everything I just listed plus a cheap $50 mask.
I know for a fact what this machine can do and after using a 110 vs 220 I would feel 10X more confident in the 220 welds on a frame.
Congenital Heart Disease is a reality for me, BOTH of my children have it. Please read up and become aware for future generations
Lydia Ann-Acquired 08/05/05 Open Heart surgery 08/10/05
Jacob Patrick-Acquired 01/17/08 Open Heart surgery 02/15/08
rustywrangler is offline
post #8 of 8 Old 09-21-2007, 10:08 AM
jgorm
jgorm's Avatar
I've welded 1/4" steel a bunch of times with my miller180. Works fine and not even close to the highest setting and full penetration. Works good on 20gauge steel too. I love working with it.
jgorm is offline
Got a new welder Tomb Raider Fabrication Shop 2 02-23-2006 07:26 AM
Which Welder for what i want to do? jnkyrdg04 Fabrication Shop 12 02-21-2006 07:51 PM
i need a welder Texas TJ Fabrication Shop 33 02-14-2006 11:22 PM
Looking to buy a welder.... NEWtoTHEjeepLIF Fabrication Shop 2 12-31-2005 10:46 PM
welder 79cj5Dr Fabrication Shop 7 12-29-2005 08:14 PM
