Best way to accurately place leaf spring shackle mounts? - JeepForum.com
post #1 of 2 Old 08-04-2010, 02:20 PM Thread Starter
justinking06031
At the risk of sounding like an idiot...
Situation:
I am relocating my RE SOA springs for a rear stretch(about 8"). I welded a piece of 2x4x1/4" to the rear and welded Ruffstuff way back shackle hangers. I moved the forward leaf mount back on the frame and did get the 50* shackle angle i was wanting.
Problem:
The part I dont like is that i have about a 3/4" spread on my leaf springs. Measuring the width at the front of the springs is about 44" and at the rear near the shackles is 44 3/4".
Solution:
What is the best way to get them 100% straight?
Thanks,
And for the pirate members, yes i realize it is wednesday and I am a day late for stupid questions.
justinking06031 is offline
post #2 of 2 Old 08-04-2010, 03:54 PM
Area.3.Fiftyone
That's only 3/8 per side that needs to be adjusted.
They need to be as straight as possible. I would do the fixed eyes first, straighten your leafs and then weld on the back. It sounds like you did it backwards.
It's WAY easier to move the rear hangers to where they need to be.
79' CJ7 - 82' CJ8 - 94' YJ - 96' ZJ
Diagonally parked in a parallel universe.......
Area.3.Fiftyone is offline
Rear leaf spring shackle mounts have a small tear... repair? JCDubya Fabrication Shop 2 03-13-2010 09:59 AM
need help welding shackle mounts lakailimited06 Fabrication Shop 9 10-16-2009 10:47 AM
Bolt on Shackle mounts? ClimbStuff General Jeep & Off-Road Equipment 4 09-15-2009 09:09 PM
Place online to get weld-through shackle/D-Ring/Clevis mounts tweba99 Fabrication Shop 21 03-13-2006 11:56 PM
D ring shackle mounts penguinland Fabrication Shop 8 05-24-2005 07:13 PM
