Best tire carrier hindge - JeepForum.com
post #1 of 10 Old 09-28-2010, 10:28 PM Thread Starter
mknight759
Ok I am building a few bumpers and have been doing a little r&r on the hindges just curious on what everone thought was the best. I have read about a few failure with the standard trailer spindle cause of all the heat when welding it in.Has anyone had any problems and if so what kind did they use.
mknight759 is offline
post #2 of 10 Old 09-29-2010, 12:23 AM
gremlinsteve
i think this is the one ill be using on mine.
Netfirms Commerce Pro
gremlinsteve is offline
post #3 of 10 Old 09-29-2010, 02:44 AM
Ironworker709
Ironworker709's Avatar
Ummm..what does that anything to do with a tire carrier spindle??
Is this some kind of way to spam in a forum?
Don't DREAM your life, LIVE your dreams
Never forget 9/11
"Welding is like a woman,Get 'er HOT and Penetrate"
Gotta LOVE a person who knows everything about NOTHING
The only Thing necessary for the Evil to win is a good man to do nothing....
"How far you go in life depends on your being tender with the young,compassionate with the aged,sympathetic with the striving,and tolerant with the weak and strong--because someday YOU will have been all of these"....George Washington Carver
Want to know what an Ironworker is and the job scope of a Journeyman?..click here...
Ironworker709 is offline
post #4 of 10 Old 09-29-2010, 03:16 AM
Warlord2
Im also interested in peoples opinions on who makes a good hinge. So far I have found them in 1.25 inches, 1.5 inches and a 1.75 inch diameter one from polyperformance but its over $100 shipped I just started making a rear bumper and need to find something that will work for 35"- 40" tires... Anyone have better luck with one brand over another? they all seem to have the same components...
07 JK 2D X model with 6 speeds. Full Traction 3" ultimate lift kit. 315x75x16 Toyo Open Country M/T on Rock crawler procomp rim. Ruby dana44's front sleeved inside/outside C truss and rear with 5.13's gears. Homemade rock guards, rear bumper w/tire carrier, oilpan/tranny skid, evap canister skid, light bar, switch pod. Riddler diff covers, Cobra 75 w/wilson antenna, Polk speakers, 10" sub, 2x Amps, Lightforce 240 drive light, backup lights, rock lights.
Warlord2 is offline
post #5 of 10 Old 09-29-2010, 06:46 AM
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
Can't speak for everyone but here's my take on it...
I think the two common trailer spindle sizes are 1" (typical 1000lb axle spindle) and 1.375" (typical 2000lb axle spindle). Those are the inside bearing surface diameters.. not the shank diameters. I use the 1.375" spindle with my bumpers. I like them because the seal area diameter is 1.75" and that's where it gets welded to the bumper. They've been reliable for about the past 4 years or so.
The high price for those kits is due to the material/time to make them. My approx material cost (if I purchase a single unit with shipping) is..
Spindle.. $20
Raw 2.75" DOM Tube.. $20
Bearing Kit.. $20
Aluminum Cap.. $8
Then, figure about 30-45 minutes on my $5000 lathe to machine the parts.
Granted, I can purchase my material in bulk and get a better price break.. but then the old "it takes money to make money" comes into play. If I'm going to tie up $1000 in spindle material, I need to earn interest on it while those parts sit on the shelf.
So, I spend $68-$70 for the parts, 30-45 minutes of my time on my $5000 machine and make about $30 in profit (if I don't break a $6 lathe insert)..
... but I don't sell the pivots anymore. It's all I can do to keep up with my own bumpers.
BESRK is offline
post #6 of 10 Old 09-29-2010, 07:43 AM
smunns
I'm very happy with my hinge from A to Z Fabrication. Not only are they a Jeep Forum Vendor, their mega duty spindle upgrade is only an extra $20.
Tire Carrier Swingout Heavy Duty Hinge Kit
smunns is offline
post #7 of 10 Old 09-29-2010, 08:17 AM
snowrydr01
X2 on the AtoZ piece
the kit is cheaper then trying to piece together the parts from the next cheapest sources too
snowrydr01 is offline
post #8 of 10 Old 09-29-2010, 10:57 AM
timatoe
timatoe's Avatar
I used this one.... Tire Carrier Hinge Kit - 1000 Pound They now offer a double shear version.
I went with that one because you don't weld the spindle itself in, you weld in a sleeve then press the spindle in and it has a set pin that prevents it from coming loose, although I can't imagine how it could ever come loose without the pin..... Anyhow, it's not necessarily "better" than any other, I just preferred that design.
timatoe is offline
post #9 of 10 Old 09-29-2010, 02:39 PM
shadowulf
+1 for the AtoZ set up.
This is what I was planning on getting, before I found my current bumper/carrier for $120
shadowulf is offline
post #10 of 10 Old 09-30-2010, 05:56 AM
Warlord2
I just ordered the 1750lb one, I also like the weld in sleeve, will make removing it much easier then taking everything apart. I wonder why they dont make the 1750lb one into a double shear version...
Warlord2 is offline
Hitch Tire Carrier Cargo carrier HELP :D Madmanmiller802 Fabrication Shop 32 03-11-2011 07:04 PM
Largest Tire on a Stock Tire Carrier wcusoccer0422 General Jeep & Off-Road Equipment 4 11-01-2008 11:21 AM
You can safely fit a 33" tire on the stock tire carrier on door CB3 Tires & Wheels 35 04-27-2008 01:46 AM
building rear bumper with tire carrier... need suggestions for 40" tire Big-n-Broke-YJ Fabrication Shop 10 10-04-2006 03:34 PM
Difference between LoD extreme duty tire carrier/Heavy Duty tire carrier djaychris General Jeep & Off-Road Equipment 7 12-18-2005 09:53 AM
