Best drill bits? Unibits, hole saw bit - JeepForum.com
post #1 of 16 Old 12-17-2010, 08:29 AM Thread Starter
jatepper
Well, I'm tired of going through unibits on my never ending projects. I always use cutting oil and control my RPM's, but the firse few steps of the bit always get worn out pretty quick as they are used the most. What unibits have you guys found that last a long time? I don't mind paying the extra money for a good quality bit as long as they pay for themselves over time.
Also, what about good drill bits? I have used DeWalt bits and they also don't last all that long. I always buy the "better" (more expensive) bits, but to me they all seem the same.
I have had pretty good luck with my ACE Hardware hole saws. Is there something better then a hole saw for cutting out 1 9/16" holes that you guys would recommend?
Thanks again and Merry Christmas to you all!
1986 CJ7 Laredo - Auto 14k miles
1985 CJ7 Renegade - Auto 33k miles
1982 CJ8 Scrambler - T5 T-SPD
jatepper is offline
post #2 of 16 Old 12-17-2010, 09:27 AM
shadowulf
real "unibits" are usually pretty good. Check out Klein Tools version. We use them for electrical boxes and mild steel alot. I started using "popper" bits that sheet metal workers use as pilot bits to get more precise and avoid wearing out otherwise good bits. They are short (3" long) double ended drill bits, good for up to 1/4" thick material.
We also use Lennox holes saws in the field. There is a really good hole saw that cuts stainless real well, but I can't recall the maker. It has 3 slots in the saw, using carbide teeth. I remember them lasting a long time too.
Also, try using Anchor Blue for drilling/cutting. Its more like a paste and seems to help alot when I'm drilling/tapping structural steel.
shadowulf is offline
post #3 of 16 Old 12-17-2010, 09:49 AM
Bad_Karma
I've had really good luck with my Craftsman cobalt drill bits. I think there's only one in the set that is burned up and I would like to try sharpening it. The cobalt bits were a huge improvement over the old black oxide bits, and I have burned up some titanium coated bits as well, these have held out the best for me.
I have a cheap unibit (Auto Zone special) that has done fine, but I only have used it on thinner sheet metal.
Had pretty good luck with the Ace hole saws as well for drilling into exhaust pipe for O2 sensors and the like. They don't last forever, they did dull out on us after a while, but they had a good life.
2006 Wrangler X 4.0L 6 Speed
1989 Wrangler 2.5L 5 Speed (Sold to my Brother)
Bad_Karma is offline
post #4 of 16 Old 12-17-2010, 09:51 AM
adamandjessyj
harbor frieght has a $20 air file that i use for sharping my unibits. i have some blue point brand unibits that are older than me. and sears has some titanium coated brill bits that are the best ive used for under 50bucks. i agree with shadowwulf-klein tools are very well built, you wont go wrong by beefing up you tollbox with them.
where thers a will, theres a way!
its not a just a truck, its my hobby.
adamandjessyj is offline
post #5 of 16 Old 12-17-2010, 01:22 PM
Jim1611
Jim1611's Avatar
Jeremy here are a couple of places that I deal with to order tooling for my shop. Industrial Supply Equipment from MSC Industrial Supply & www.maritool.com
The later is almost always better on price but does not have the variety to choose from. One thing you can do with MSC is to ask to be added to their email offers. Sometime they will have 50% off on something that I need. You won't get this deal without the email notifictation they send you and the rebate code that's in it.
Also buy only American made drill bits. Chicago Latrobe is a very good brand name, and always buy the cobalt drill bits. You're using cutting oil and getting your rpm set right so you ought to see some good life out of your drills. Also if you order the larger drill bits, like about 1/2" they make them with 3 flats ground on them so that they won't be as apt to spin in the drill chuck, get these. You'll be glad you did. Oh and get the ones that say they are ground with a split point, they really drill easier.
Get an account setup with these two places and you'll get great service. I can order from MSC and have it the next day on regular ground UPS. Maritool takes one more day but that's still pretty good service.
(Crabtree Shackle Hangers)
My build thread
Jim1611 is offline
post #6 of 16 Old 12-17-2010, 04:04 PM
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
For the larger holes (like 1 9/16") a hole saw should last a long time if RPM is kept slow and the teeth kept cool. I've been using the same 1 1/2" Milwaukee hole saw for the past 2 years.. and have drilled hundreds of spindle holes thru 3/16" with it. Also, there are "carbide tipped" hole saws that are basically like annular cutters. A few months ago, a small shop down the street closed their doors. The owner gave me a trash bag full of brand new carbide hole saws still in their boxes. I tried one out and it went thru 3/16" like an annular cutter.. like buttah!!
For 1/2"-1" bits, you might consider using Annular Cutters. Most that I've seen require a 3/4" chuck but they're what I use for things like drilling shackle mounts. I think my current 1" cutter has done about 250 holes (1" diameter thru 1" thick hot rolled bar) without being sharpened yet. Again, a nice slow speed to allow the bit to take a good "chip" and liberal coolant/lube.
BESRK is offline
post #7 of 16 Old 12-17-2010, 05:34 PM
chet44
I'll agree with BESRK about "cooling". A lot of guys talk on here about drilling/milling with cutting oil, and for low rpms and/or deep mill cuts, that's fine. But for faster RPM's and smaller drills (Anything under 1/2" diameter), I like to use a water soluble oil. Use that, and you will get a lot more work out of your tools between sharpenings. Makes cleanup easier too. MSC will carry that, several brands in fact. The stuff we use at work you mix 50 to 1 with water. Keeps your drill nice and cool, which means longer life, and it cuts easier. How do you sharpen your drills? During my apprenticeship, the guy who taught me my trade (Tool and Die Maker) insisted I learn to sharpen drills by hand. His reasoning was that most common drill sharpeners only handle up to a 1/2" drill. What happens when you have to sharpen 2" drill? And you need it right now? When I buy drills for myself, I buy Hertel. They are also available at MSC. As far as bigger holes, I cheat and use a 3-axis machining center and just circle mill them, so not much help for you there.
chet44 is online now
post #8 of 16 Old 12-18-2010, 12:40 AM
jeepfreek383
i might have posted this on here once before if i did im sorry. one way to save any bits life is to drill pilot holes. but then you need to sharpen or keep buying small drill bits at a couple $$$ a piece it sucks. what i do is go and buy a pack of self tapping metal screws usually they have a 5/16 or 3/8 hex head and drill about an 1/8 hole. use a center punch to mark your hole location and then use a drill with the self tapper to make the pilot hole. sometimes it takes two if the screw is junk or material is thick i've used them up to 3/16 carbon steel plate but you get like 50-150 in a pack for under 6.00 at hd. this way if you go buy the expensive irwin uni bits it really saves the 1/4 inch tip on the bit
jeepfreek383 is offline
post #9 of 16 Old 12-19-2010, 03:07 PM
JLC08JK
What was I thinking?
JLC08JK's Avatar
The "Drill Doctor" sharpening system is great for bits up to 1/2".
Even broken bits can be saved with this little machine.
Jim
JLC08JK is offline
post #10 of 16 Old 12-19-2010, 04:09 PM
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
You know they have a bigger Drill Doctor that can do up to 3/4" bits (IIRC). I think it's the Drill Doctor 750..
BESRK is offline
post #11 of 16 Old 01-02-2011, 09:15 PM
CoryA
in adition try some elmer's glue my machine shop teacher says it really helps
haven't tried it myself but he's a really sharp guy.
CoryA is offline
post #12 of 16 Old 01-02-2011, 09:37 PM
Krochus
Best?
I dunnow we use evolution (british) or Nitto (japanese) bits for our Nitto/Slugger style magnetic drills
http://www.nittokohki.com/tools/prod...ers/index.html
http://www.evolutionpowertools.co.uk...essories3.html
Think Green recycle your YJ's sway and trac bars today!
Originally Posted by buickgnx88 View Post
"Jeep Wave threads, it's a newb thing, you wouldn't understand!"
Krochus is offline
post #13 of 16 Old 01-16-2011, 04:14 PM
aallison28
I've had good service from my Hitachi drill bits. Use oil and slow RPM's.........
And my Miluawkee bits are good.
aallison28 is offline
post #14 of 16 Old 01-23-2011, 07:41 AM
Flaggdog
1979 CJ7
I'm a glazier, I install glass and aluminum framing in high rise commercial buildings. Sometimes my job requires me to drill alot of holes in 1/4" thick steel. My company supplies us with jobber bits, these are not high speed bits, but lots of newbs burn these bits up after only one hole. The reason for this is you have to use low RPM's like you said, but ALSO lots of pressure. If it is not a high speed bit (HSS) you must use low RPM's, coolant is your freind (I prefer cool-tool, the pink stuff) and most importantly pressure. I mean you have to really bear down on these things, it's not uncommon for me to use a 2x4 on the end of the drill for leverage. When done right I can make one bit last all day, and blow through steel in half the time.
Flaggdog is offline
post #15 of 16 Old 01-23-2011, 07:58 AM
underpowered
Bouncin' on a Budget
underpowered's Avatar
we use Iriwin Unibits at work, had the same one in my toolbox for 2 years now, and hard telling how long it was in there before i acquired the box. no issues other than the 3/8 size on it is a bit dull. But i always drill a pilot when using it, i never start a hole with my unibit.
for other bits, we jsut titanium coated one, not sure of brand but with proper cooling and correct RPM they will last forever. we use Kool-Mist cooling fluid for everything.
hole saws, Only Lennox is used in our shop, and we have some hole saws probably eveyr bit of 10 years old we still use and are sharp
1998 ZJ-- lowered a touch
2005 GMC 2500HD 496 C.I.
Fat Amy-1989 K5 blazer. Linked, lifted, 38.5's on won tons. Big Girls can play in the woods too.
underpowered is offline
Drill Bits-I Need A New Set explorerlyon Fabrication Shop 31 07-06-2010 07:26 PM
Dear IRWIN turbomax drill bits Hussler Fabrication Shop 16 04-07-2010 06:50 AM
Good Drill Bits Suggestion Wrangler_91 General Jeep & Off-Road Equipment 7 06-12-2009 11:07 AM
Can I drill a hole through my winch drum? dbshea General Jeep & Off-Road Equipment 9 01-08-2009 01:41 PM
Drill bits and drilling busted bolts ARGH CanukYJ General Jeep & Off-Road Equipment 7 11-05-2004 02:21 PM
