Best budget tubing bender - Page 2 - JeepForum.com
post #16 of 26 Old 04-15-2013, 06:21 PM
Kenbo-Slice
This:
http://www.harborfreight.com/tubing-roller-99736.html
PLUS this:
http://www.swagoffroad.com/Harbor-Fr...ings_p_50.html
Will yield pretty surprising results. Get the correct size dies for the material you're using and bend away.
Jeep build up...ONGOING
Kenbo-Slice is offline
post #17 of 26 Old 04-15-2013, 06:36 PM
SFRautomotive
#WannaBeRockBouncer
SFRautomotive's Avatar
1992 XJ Cherokee
Originally Posted by Kenbo-Slice View Post
This:
PLUS this:
a tubing roller is not a bender, and will not yield the same results.
00XJ limited.....Tons, ORI's, Caged
92xj....Linked, Locked, Caged, Armored...RIP
what are leaf springs?
"You're what's wrong with America. You don't drink enough PBR and you probably run sway bars on the street. Fawking communist."-ibjeepin95
2013 COTY
SFRautomotive is offline
post #18 of 26 Old 04-15-2013, 09:21 PM
JohndKc
1987 YJ Wrangler
What radius does a tubing roller go to?
Also, i have a JD2 model three with a copperhead air over hydraulic ram kit.
33rd BCT
Alpha 2/122 FA
68W
JohndKc is offline
post #19 of 26 Old 04-16-2013, 08:50 AM
Kenbo-Slice
You're right they aren't. The same items can be made with either though.
A pipe bender isn't a tubing bender either. Given that, I didn't feel the OP was too particular. One can do quite a bit with a roll bender if they have some know-how. A tight radius 90 takes a lot more work and some extra waste but I digress.
I'll stick to sitting in the corner.
post #20 of 26 Old 04-16-2013, 09:30 AM
Tomb Raider
Addicted...
Tomb Raider's Avatar
Originally Posted by idflatwater View Post
What's the best budget tubing bender. I found Hydraulic bender on sale at Oak Harbor it's on sale for $99.99. I'm looking to build side skid bars and up grade my roll cage. Any one know if it'll do what I need to do?
You've got a 4bt cummin's and D44's in your YJ according to your profile. Your not afraid to spend a few dollars to get something that works right and lasts. Take that philosophy and buy a bender....you will be happier in the long run buying something of quality over price.
With that said. I've had a kinker from harbor freight, used a JD bender and currently own a rogue fab bender.
The harbor freight kinker worked for bends less than 15-20 degrees with no modification. Even 20 degrees is pushing it before thin tube (.120 or less) flattens out. In the end...you've spent 100 bucks and tube for something less than desirable. Do you "save"....in the short run, sure. But your limited, as well as either unhappy or limited for future bigger projects.
The JD bender was nice....but I'm not a fan of "rowing"....I prefer to get my workout's in the gym
The rogue fab bender I currently have is a great alternative that meets all my needs. Comes as a "complete" package ready to bend, uses air over hydro so no more "rowing" and the dies will bend well past 90 degrees. All that and less cost than comparable benders without air/hydro setups and only 90 degree dies.
These are not only "preferences"...but real world experience. Choose wisely young jedi
I like to build stuff. Want to know what I build, you can google it
Tomb Raider is offline
post #21 of 26 Old 05-13-2013, 04:54 PM
RogueFab
We also ship faster than ANYONE in the business. your order will be shipped in less than 2 business days. Give us an e-mail following up your order and let us know you want it ASAP and we can usually ship next day.
Tomb Raider is correct about the dies, every die set we sell bends 180+ degrees.
Just wanted to add some info if you think our product is worth considering while you are shopping around for your next big tool purchase.
Rogue Fabrication - Portland OR -
Air/Hydraulic tube benders- $595 w/180 degree die sets
Universal Drill Press Reduction Kits- $119 shipped
RogueFab is offline
post #22 of 26 Old 05-18-2013, 07:20 PM
schitzangiggles
King of Macastan
schitzangiggles's Avatar
Not to be a jerk, but you might wanna look at getting a Vendor membership before you push your wares here...
"Axeheads are supposed to be sharp, but you are one blunt tool."
FLynes
If you love wealth more than liberty,the tranquility of servitude more than the animating contest of freedom, go home from us in peace. We seek not your counsel nor your arms. Crouch down and lick the hand that feeds you. May your chains sit lightly on your shoulders and may posterity forget that you were our countrymen.
-Samual Adams
A government big enough to give you everything you want is big enough to take everything you have.
Thomas Jefferson
Calling Illegal Aliens "Undocumented Immigrants" is like calling drug dealers "Unlicensed Pharmacists"
Nemo Me Impune Lacessit
"No one provokes (attacks) me with impunity".
"Your right, the Tea Party and the OWS are the same, just like the America Revolution and the French Revolution were the same. The only problem is the American Revolution ended with Liberty, Freedom, Justice for all and a shining light upon a hill. The French Revolution ended with lynchings, guillotines, murder and socialism. So yeah, I could see how one could confuse the two..."
Mac Wilson
schitzangiggles is offline
post #23 of 26 Old 05-18-2013, 07:42 PM
underpowered
Bouncin' on a Budget
underpowered's Avatar
they are
look under the supporting vendors section, Rogue fab is one of 'em.
1998 ZJ-- lowered a touch
2005 GMC 2500HD 496 C.I.
Fat Amy-1989 K5 blazer. Linked, lifted, 38.5's on won tons. Big Girls can play in the woods too.
underpowered is offline
post #24 of 26 Old 05-18-2013, 08:43 PM
schitzangiggles
King of Macastan
Then his SN should have a vendor tag and look like a real vendor...
FLynes
-Samual Adams
Thomas Jefferson
Mac Wilson
post #25 of 26 Old 05-21-2013, 08:44 AM
Tomb Raider
Addicted...
Works for me........
post #26 of 26 Old 05-22-2013, 01:28 AM
schitzangiggles
King of Macastan
It used to have the SN in bold and site vendor under it to differentiate. If I paid for a vendor membership, I'd be pissed I had nothing to differentiate me from a non-supporting member.
Kinda like how my Lifetime member is different than a yearly membership and a plain jain member.
Sorry to piss in your Cheerios Joe/RogueFab. Carry on, I'll be in the corner...
FLynes
-Samual Adams
Thomas Jefferson
Mac Wilson
Has anyone used this tubing bender? jeepsterjc Fabrication Shop 10 02-04-2009 09:48 PM
just got tubing bender!!!!! 99dime Fabrication Shop 7 02-03-2008 06:58 PM
tubing bender ugrider21 Fabrication Shop 2 08-21-2005 01:21 PM
Tubing Bender CJ51973 Fabrication Shop 5 05-22-2005 07:07 PM
Which tubing bender? BESRK Fabrication Shop 2 08-19-2004 09:08 PM
