Bending 1/8" steel plate without a brake - JeepForum.com
post #1 of 26 Old 09-16-2011, 10:46 PM Thread Starter
athos76
Well, my plans on bending my corner guards at the local DIY auto shop on Base fell thru...
I've seen plans online for homemade brakes, but they aren't capable of bending 1/8".
Anyone have a DIY homemade way to successfully bend 1/8"? I've looked into using a telephone pole or some pipe.
The local welding shop will do it, but it won't be a priority, and they would need my jeep there to test fit...and they want $65 an hour...
2006 I6 6-Speed X, 33" Goodyear Duratrac, 8.8.
athos76 is offline
post #2 of 26 Old 09-17-2011, 07:40 AM
50wllystrk
athos76, Hi there, I notice you mentioned plate instead of tubing, is this true? If so is the bend you want going to be a smooth rounded bend or crisp bend right to the angle you desire?
If you want a crisp angle I have a great way to shape it, if you want a rounded bend, not much I can tell you.
50wllystrk is offline
post #3 of 26 Old 09-17-2011, 10:29 AM Thread Starter
athos76
I will have to make small gradual bends every 1/2" or so to get the shape desired. It won't be one straight bend.
athos76 is offline
post #4 of 26 Old 09-17-2011, 10:45 AM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
There are times when buying what you need is simply cheaper and easier than making it yourself.
Considering your time, material costs, and fabrications costs, corner armor is a good example. Most machine shops charge about $75 or more per hour for set-up hours and production hours.
Warrior Products S916 Steel Corners (.104" thick) are about $130.
CJ7-Tim is offline
post #5 of 26 Old 09-17-2011, 10:49 AM
50wllystrk
I have a press of which can bend up to 1/2" to a 90 degree with no problem. But the are times I want control the bend and it's angle more precisely. Recently in my build thread I made some spring top plates, the one that the ends are turned up a bit. I chose this method and they turned out great. Yesterday I wanted 1/8" plate that was 4" wide to have about 30 degree bends, I chose this method also. I used a 3" inch cut off wheel to make the cross cut about 3/4 deep, then by hand, bent the plate back for my desired angle. Then welded to fill the cut and ground it smooth. If this helps, great, if not, perhaps it's an idea for the future.
Both sides bent with the angle thingy to check for accuaracy between both sides.
Fill the groove with Mig welding.
Grind it smooth. I use a 4 1/2" grinder with the flap discs.
post #6 of 26 Old 09-17-2011, 03:26 PM Thread Starter
athos76
I would have gone with the poison spyder's or others, of they made them in diamond plate... I already have AtoZ diamond plate rockers, and wanted to stick with the theme.
athos76 is offline
post #7 of 26 Old 09-17-2011, 03:29 PM
wushaw
Rockin jeep
wushaw's Avatar
A forming block and a rose bud tip on the torch.
wushaw is offline
post #8 of 26 Old 09-17-2011, 11:38 PM
schitzangiggles
King of Macastan
schitzangiggles's Avatar
Why not have a metal supply shop do the radius bend for you? Vernon Steel (my local supplier does it all of the time for a nominal fee ($20 or so).
"Axeheads are supposed to be sharp, but you are one blunt tool."
FLynes
If you love wealth more than liberty,the tranquility of servitude more than the animating contest of freedom, go home from us in peace. We seek not your counsel nor your arms. Crouch down and lick the hand that feeds you. May your chains sit lightly on your shoulders and may posterity forget that you were our countrymen.
-Samual Adams
A government big enough to give you everything you want is big enough to take everything you have.
Thomas Jefferson
Calling Illegal Aliens "Undocumented Immigrants" is like calling drug dealers "Unlicensed Pharmacists"
Nemo Me Impune Lacessit
"No one provokes (attacks) me with impunity".
"Your right, the Tea Party and the OWS are the same, just like the America Revolution and the French Revolution were the same. The only problem is the American Revolution ended with Liberty, Freedom, Justice for all and a shining light upon a hill. The French Revolution ended with lynchings, guillotines, murder and socialism. So yeah, I could see how one could confuse the two..."
Mac Wilson
schitzangiggles is offline
post #9 of 26 Old 09-18-2011, 06:28 AM
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
Saw this pic on Pirate... it might not be too difficult to increase the size a bit to get the proper radius.
BESRK is offline
post #10 of 26 Old 09-18-2011, 10:51 AM Thread Starter
athos76
That's one method I was going to try out. My local DIY shop has a nice 60 ton press and some scrap steel I can use to brace it. I just need to find some pipe large enough to use.
athos76 is offline
post #11 of 26 Old 09-18-2011, 12:13 PM
hallway94yj
Read page 5 and 6 of this build, or the whole thing if you have a few minutes
hallway94yj is offline
post #12 of 26 Old 09-18-2011, 02:49 PM
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
Hmmm.. I may have to mess with this idea myself. I'm thinking cut the pieces on the plasma table. Instead of a large piece of DOM, maybe cut a few round disks with slot in them for strips of flat stock.. similar to making a beer keg out of strips of wood. A 20 ton (or even 12 ton) press should be plenty strong to make a large radius bend in material up to 3/16". Might be an easy way for me to do corner armor.
BESRK is offline
post #13 of 26 Old 09-18-2011, 04:32 PM Thread Starter
athos76
Anyone know off hand what the radius of the TJ corners are? I've got a local train car repair yard that has various chunks of pipe laying around and they'll lend me a piece to use.
athos76 is offline
post #14 of 26 Old 09-20-2011, 06:24 PM
Roughboy
I'll tell you what I use, but beware it probably isn't the safest way, and it is certainly a miss use of equipment. I bought one of those cheap harbor freight pipe benders for $80 with one of there 20% off coupons. As a pipe bender, it sucks, but I use the 3/4 in. die, place a 4 in. piece of 3/4 in square tube in it with the edge up. I then place the flat plate cross ways thru the bender. I place a couple of c-clamps at the top of the bender to add a little strength, and bend away. I have bent up to 1/4 x 4 in plate into a 90% angle this way. It beats the way I used to do it by a long shot, I used to clamp the plate to my work bench, heat it with my torch, and bear down on it with long crescent wrench handle. I'll post up pics of anyone is interested. PS. I really like the press picture from pirate, I'll have to make one of those, it's probably much safer.
Roughboy is offline
post #15 of 26 Old 09-22-2011, 04:03 PM Thread Starter
athos76
Well, I acquired some 6 1/2" pipe and used a 75 ton press to bend the corners. The radius is a little too tight, so I'll have to heat it up and flex it out some. One corner bent about an inch from where I wanted it to, so I'll have to work on that a little more. The bending was real easy and the width of the jaws on the press were almost perfect spacing.
athos76 is offline
Bending Plate (3/16") without a brake Freefly TJ Fabrication Shop 16 10-11-2008 06:45 PM
Bending Aluminum Diamond PLate Scrambler82 Fabrication Shop 8 09-07-2007 07:01 AM
bending steel quarter panel boise49ers General Jeep & Off-Road Equipment 12 03-15-2006 11:11 AM
Looking for 1/2" Steel Plate (maybe 3/8") Scrambler82 Fabrication Shop 8 06-08-2005 09:30 PM
Bending Diamond Plate rmagers Fabrication Shop 7 01-08-2005 07:37 AM
