Which bender for roll cages, tube fenders, and bumpers? - Page 2 - JeepForum.com
View Poll Results: Which one do you prefer?
Hydraulic 8 100.00%
Manual 0 0%
Voters: 8. You may not vote on this poll
post #16 of 24 Old 12-08-2013, 11:26 PM
AtTheHelm
I have and use the HF pipe bender, its extremely limiting but works for simple stuff. If I were to build just one cage I would definitely buy a real tube bender.
You really can't bend anything bigger than 1" pipe (1.33"OD) to 90*. The 1" nominal pipe bends pretty good without filling with sand. 1.5" pipe (1.90"OD) can be bent to 60* if filled with sand. I use pipe size tubing, not astm rated pipe.
Center hoop with 1.5" nominal pipe size tube.
Rack made with 1" nominal pipe size tube and 1"x 0.95" hrew tube (straight cross bars)
AtTheHelm is offline
post #17 of 24 Old 12-10-2013, 11:35 AM
ltrail
1984 XJ Cherokee
Not bad. But figure that the cheapo bender will cost 110 or so and marginal at best. I pay 150 for the jd2 (die separate 250) buy sometimes I see the bender and a die at package deal price. Also takes guess work out as there isn't a degree wheel on the cheap one.
84 xj 350tbi, sm465, 203/205, 60/70. links and other junk.
what size sawzall blades does it take to fit 40's?
ltrail is offline
post #18 of 24 Old 12-10-2013, 01:59 PM
AtTheHelm
Forgot to mention too that the cheap pipe benders are limited to 90*. there are 180* dies for the JD2 which is almost mandatory for a lot of tube fab jobs.
post #19 of 24 Old 12-12-2013, 08:34 AM Thread Starter
j33p4l1fe4x4
Can a 180* die bend 90*?? As in 1-180 ??
Wanted: HP30 4.88 / bikini top!!!
j33p4l1fe4x4 is offline
post #20 of 24 Old 12-12-2013, 12:03 PM
Danno6102
Yes. A 180 die can bend from 1-180. A 90 die can bend from 1 to only 90.
"Evolution through carnage, the Jeep will keep what it needs."
Danno6102 is offline
post #21 of 24 Old 12-19-2013, 06:22 AM
pazur
1981 CJ7
Don't even think of making 180 deg. bends with these machines unless you have very narrow tubing.
i.e. OD 25 mm or so.
Tubing OD 40+ mm & 2mm walls - no chance you make kink-free or not flattened bends without madrell and serious machine with price tag far beyond jd2.
pazur is offline
post #22 of 24 Old 12-23-2013, 07:59 AM
ltrail
1984 XJ Cherokee
My jd2 makes amazing 180* with no issues. Shock hoops are cake, I can almost do a complete circle (though I haven't tried to make perfect circles) I believe my dies are ~240*.
That's with 1.5" .120 Dom or hrew.
ltrail is offline
post #23 of 24 Old 12-23-2013, 01:05 PM
underpowered
Bouncin' on a Budget
underpowered's Avatar
my Pro tools makes a very nice 180* bend with minimal tube flattening. i do 90* + bends on a regular basis without issue. no kinks and minor flattening so i don't know what you are referring to in this post.
1998 ZJ-- lowered a touch
2005 GMC 2500HD 496 C.I.
Fat Amy-1989 K5 blazer. Linked, lifted, 38.5's on won tons. Big Girls can play in the woods too.
underpowered is offline
post #24 of 24 Old 12-23-2013, 04:11 PM
Unlimitedlou
I think he was referring to the cheap eBay/HF benders.
2005 Unlimited Rubicon, too much junk to list!-sold
2012 JKU Orange Crush
Unlimitedlou is offline
