Quantcast BB install with pics........ - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Fabrication Shop > BB install with pics........
TJ 5.25" Speaker Adapters - NalinMFGFree Shipping on TIRES at KrawlOff-RoadGenuine Italian leather shift boots for your Jeep!
Old 07-04-2005, 01:20 PM   #1
branman444
I was told i should post this here if its not allowed then please delete/move it.
OK i set out to install my BB and things today and finaly got it done. It took about 5/5.5 hrs.
1st i used the instructions that i got off Kevinsoffroad.com. That helped a lot. I just jacked up one side of the axle as high as i could and with the tire off and set two jackstands right behind the lower control arm(LCA's). un-done the sway bars. Got my spring compressors tight
PIC.http://img65.imageshack.us/img65/6544/lift012r1ny.jpg
and then lowered the jack so that the frame stoped on the stands and the axle went as low as i could get it.
PIC2.http://img28.imageshack.us/img28/7910/lift011r8fh.jpg
Here it is after i got the BB installed on the spring post
PIC3.http://img212.imageshack.us/img212/5703/lift009r4in.jpg
And finaly here it is with the spring back in place and the bump stop extention on the bottom
PIC4.http://img212.imageshack.us/img212/1382/lift007r8kn.jpg
Now for the rear ones. Did the same thing for the rear as far as the jack goes. Here you can see that i have installed the 2" bump stop extentions the BB and the spring retainer arm extentions. Now my jeep has UC so i already had a spacer on the bump stop i took it out and just used the 2" extender/spacer.
PIC5.http://img220.imageshack.us/img220/8448/lift005r3wz.jpg
This actualy turned out pretty easy. Ill try to answer any questions if you guys that are planning on doing one soon have any. Now the final results
PIC6.http://img141.imageshack.us/img141/8595/lift004r8ib.jpg
1997 Jeep Grand Cherokee Limited ZJ
5.2L V8
Up Country
Yellow Top
ProComp ES9000 Shocks
OME Steering Stabilizer
Bridgestone REVO AT's 245/75/16
Kevins 2.5" BB
Home made Sliders
Kevins Trackbar conversion
Rubicon Express Addj. LCAs
Working on Roof Rack....
branman444 is offline   Reply With Quote
Old 07-06-2005, 11:24 PM   #2
onlyone
2007 WK
Very nice job.
Thank you Jesus
With all this talk about going "Green" I decided to buy a green Jeep. :)
07 Grand Cherokee Rocky Mountain Edition 4.7 V8 Jeep Green 255/70/17 Bridgestone Dueler A/T Revo's,
http://i22.photobucket.com/albums/b3...d/DSCN0296.jpg
onlyone is offline   Reply With Quote
Old 07-08-2005, 04:54 PM   #3
Bobbywolf
You have the final results, but do you have a before picture for comparison?
Bobbywolf is offline   Reply With Quote
Old 07-13-2005, 06:48 PM   #4
branman444
No i sure dont although i wish i did. My Wife had to go get new tires on before i got a chance to take a before pic. SORRY!
5.2L V8
Up Country
Yellow Top
Kevins 2.5" BB
Home made Sliders
Old 07-21-2005, 04:27 PM   #5
olivapot
New member....great site!
OK, I joined because I am ready to start upgrading my ZJ. Starting with my tires and looking for advice. I have stock 225/70/16's, considering 255/65/16's as a safe bet....can I get away with installing them without any other modifcations? Could I go bigger without any major rubbing?
Thanks for any help,
Mike
'96 Jeep Grand Cherokee Limited ZJ - 5.2L V8
olivapot is offline   Reply With Quote
Old 07-22-2005, 12:06 AM   #6
supaasianpdjr
Mike
Mike,
You might want to try and ask that question in the ZJ technically section, you might get a better response there: http://www.jeepforum.com/forum/f13/
[FONT=Book Antiqua][CENTER][SIZE=4][COLOR=Navy]'97 Patriot Blue TJ Sport[/COLOR][/SIZE]
"35x12.50 Mickey Thompson MTX | "4 Skyjacker
[URL=http://www.vofotos.com/]vofotos photography and design[/URL][/CENTER][/FONT]
supaasianpdjr is offline   Reply With Quote
Glock Forum
