Base metal temp affecting welds???? - JeepForum.com
post #1 of 15 Old 11-14-2008, 07:45 PM Thread Starter
firejeep344
1983 CJ7
Hey guys I was welding tonight and the welds were very porous. It was almost like I had a lot of rust or oil in the weld, but it was clean bare metal. I am welding 1/8" box with a hobart 187 at 5/50 with 25/75 gas nad .030 wire. It got down to like 25 degrees. Welds were great yesterday @ 60 degrees and nothing else changed. Would a lack of gas be doing the same thing? I have like 550 psi left in the bottle and the flow is @ 30 -35 lpm. I also thought my nozzle may be clogged. Any tips and help would be appreciated.
firejeep344 is offline
post #2 of 15 Old 11-14-2008, 08:33 PM
Bear-Olemiss
1981 CJ5
Take a torch an preheat just a touch, to get the chill out. Yes. base metal temp affects welds and BTW gas is too high.. 22-25 lbs
BAIL! "Welder's have hotter rods"
Arc-Up Welding Inc.
Vicksburg, Ms
Bear-Olemiss is offline
post #3 of 15 Old 11-15-2008, 12:26 AM
mcneil
The torch will also burn off any excess moisture, which causes porosity.
mcneil is offline
post #4 of 15 Old 11-15-2008, 01:56 AM
Unlimited04
This post/info=my opinion
Unlimited04's Avatar
check your O-rings on the gun lead. my friend and I screwed around for two weekends trying to figure out why we had porosity...turned out the O-rings where shot. Replaced them & applied a light coat of vasoline and they welds were perfect again.
Useful Write-Ups:
Fabrication & Build:
Funny:
Unlimited04 is offline
post #5 of 15 Old 11-16-2008, 05:21 AM
willness33
I doubt the base metal temp being 40 degrees cooler would affect the weld considering the thousands of degrees temps created by the arc. Welding mild steel takes place in the coldest of climates without preheating. Your nozzle could need cleaned. Also, you state your gas flow in l/min? You have a funky regulator/flowmeter on that bottle. If it's the one that comes with the 187 it's in cf/h increments, not l/min. One last thing, I think tap 5 might be a bit hot for 1/8" and on tap 5, the wirespeed of 50 i/min would be on the low side. Give tap 4 a try with the wirespeed at 50-55.
Sorry, I have to keep typing here. LOL 550 psi left in the tank is still plenty of gas. That's not your problem. Was there any breeze blowing where you were welding?
willness33 is offline
post #6 of 15 Old 11-16-2008, 06:07 AM
rustywrangler
Got my eye on you.....
rustywrangler's Avatar
I would check a few things first. If your connection of the gun to the machine is like mine, it is very possible that you are not fully seated into the bracket allowing gas to leak out past the o rings. You could have a gas leak at the back of the machine or the tank.
Congenital Heart Disease is a reality for me, BOTH of my children have it. Please read up and become aware for future generations
Lydia Ann-Acquired 08/05/05 Open Heart surgery 08/10/05
Jacob Patrick-Acquired 01/17/08 Open Heart surgery 02/15/08
rustywrangler is offline
post #7 of 15 Old 11-16-2008, 08:58 AM
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
If the metal is pretty clean, the next place I'd look is at "lack of shielding gas" as mentioned already. As for the 550psi, that's plenty. I alwasy run my bottle till it doesn't even register on the PSI gauge. Then, I keep my eye on the flow gauge until it drops to about 20ish... or slightly below. When it won't maintain 20cfh, I switch tanks.
BESRK is offline
post #8 of 15 Old 11-16-2008, 10:44 PM Thread Starter
firejeep344
1983 CJ7
Thanks for all the help. I think that it was a clogged nozzle. I cleaned it out and everything seemed ok. I just did a few spot weld though no long beads. I was mistaken about the lpm (thinking of O2 at work) it is cfh, and I turned it down to 25. That should help a tank of gas last longer eh. We'll see how it goes tomorrow when I finish my fenders.
post #9 of 15 Old 11-17-2008, 02:37 PM
E_ROCK
I actually have trouble with my welder below about 40 degrees. The wire will not spool out smoothly and instead it come out jerky. Instead of getting the “frying bacon” sound, it more like someone playing a bass line through a blow speaker.
I can sit there and watch the wire slipping on the drive wheel, but it will not improve no matter how much or little tension I have on the drive wheel.
Any suggestions?
Garage Monkey, Wheeling Junkie
E_ROCK is offline
post #10 of 15 Old 11-17-2008, 03:03 PM
Unlimited04
Any suggestions?
point a small heater at the welding wire? not enough to cause the welder to overheat and shut off, but just enough to raise the temp around the welder to ~50.
Useful Write-Ups:
Funny:
post #11 of 15 Old 11-17-2008, 07:02 PM
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
I've run my welder (Miller 210) in temps below freezing without problems. Maybe your liner needs to be changed out?
BESRK is offline
post #12 of 15 Old 11-18-2008, 05:24 PM
E_ROCK
Maybe, I have only put like 25lb of wire through it. What is the recommend amount of wire to feed though it before changing it?
E_ROCK is offline
post #13 of 15 Old 11-18-2008, 07:55 PM
Porky
I would get porosity in my welds occasionally. I tracked it down to the wire i used had corrosion or contamination on intermittent spots towards the end of the roll of wire. What a pain in the a**. I had to strip off a bunch wire and look at it in good light to find it. Name brand wire, pi**ed me off.
Porky is offline
post #14 of 15 Old 11-18-2008, 08:01 PM
Kenbo-Slice
This is why I prefer TIG welding.
Jeep build up...ONGOING
Kenbo-Slice is offline
post #15 of 15 Old 11-18-2008, 08:59 PM
Unlimited04
i think its about how the material deteriorates over time and use in that time...i.e. sunlight (UV rays) break down plastics, rubber dries out and cracks, steel rusts, etc. How much gas you cycle through will probably effect it too...Argon being very inert will probably make the liner last longer, but flux-core & air will probably deteriorate the liner faster. I'm sure rusty wire would scrap and causes deterioration as well. I don't know crap about liners tho, haven't had to replace one yet...
Linky for reading: http://www.webrodder.com/article.php?AID=205&SID=3
Useful Write-Ups:
Funny:
1st Welds BAH07 Fabrication Shop 17 09-17-2009 09:26 AM
first ever welds, how'd i do?? willyb8 Fabrication Shop 14 02-11-2009 11:17 PM
First welds Steamer98 Fabrication Shop 7 06-30-2007 08:02 PM
Pinch Welds drewguere General Jeep & Off-Road Equipment 2 02-21-2006 01:47 PM
Cleaner welds with MIG? shad4th Fabrication Shop 4 12-03-2003 07:08 AM
