axle welds - JeepForum.com
post #1 of 9 Old 09-16-2013, 08:24 AM Thread Starter
ArmyFO13F
axle welds
I am setting up an axle and doing the welds myself. I have nice welds for a beginner but how can I ensure they penetrated the axle and mounts enough? I used a flashlight to look inside the tubes and it seems I have good heat penetration. I am using lincoln 035 flux core with a 90 amp welder. Would it be smartest to tack them on then get them professionally finished?
ArmyFO13F is offline
post #2 of 9 Old 09-16-2013, 08:31 AM
Ironworker709
Ironworker709's Avatar
90 amp welder is not gonna get it...tack and take to someone who has a more sufficeint machine...
Don't DREAM your life, LIVE your dreams
Never forget 9/11
"Welding is like a woman,Get 'er HOT and Penetrate"
Gotta LOVE a person who knows everything about NOTHING
The only Thing necessary for the Evil to win is a good man to do nothing....
"How far you go in life depends on your being tender with the young,compassionate with the aged,sympathetic with the striving,and tolerant with the weak and strong--because someday YOU will have been all of these"....George Washington Carver
Want to know what an Ironworker is and the job scope of a Journeyman?..click here...
Ironworker709 is offline
post #3 of 9 Old 09-16-2013, 09:22 AM
jason280
I agree with the post above, 90 amps just isn't "hot" enough for axle work. Even 140a isn't ideal, but can be made to work in the right hands.
I would go ahead and tack everything in place, and let someone with a larger machine finish the welding.
None
jason280 is offline
post #4 of 9 Old 09-16-2013, 09:42 AM Thread Starter
ArmyFO13F
Next question, I have welded the spring perches on. Can I leave them on and have the pro weld over them or should I remove them and start over?
post #5 of 9 Old 09-16-2013, 11:02 AM
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
You probably can. However, it would definately help to run a grinder over your welds to knock them down.. or even a cutoff wheel to gouge them out a bit.
BESRK is offline
post #6 of 9 Old 09-16-2013, 11:17 AM Thread Starter
ArmyFO13F
Would a 170a welder do the job? I would really like to do this build on my own and learn things in the process. Thanks for all the helpful input so far guys.
post #7 of 9 Old 09-16-2013, 02:31 PM
jason280
It really depends on how good the welds are. The problem with most of the smaller machines is they don't have the heat to get good penetration, so while they may leave a decent looking bead, it will have very little penetration. Most shop guys, especially speaking from a liability standpoint, won't weld over old beads, so they will probably be some grinding involved. I know I wouldn't want to risk welding over a questionable bead, as there is too much chance for inclusions, etc...
As far as your other question, a 170a machine should provide enough heat. It still comes down to ability, though, but this is a great chance to work on your welding...just get in some practice!
Remember the old saying, your either a good welder or a good grinder!
None
jason280 is offline
post #8 of 9 Old 09-16-2013, 03:10 PM Thread Starter
ArmyFO13F
Thanks for the tip. I will definately take off the perches and start over with a stronger machine. Gives me a reason to buy a torch anyway.
post #9 of 9 Old 10-01-2013, 07:38 PM
BlueRubiconrich
use a ac/dc stick welder and use 7018 rod
Rubicon Rich ,05 TJ Rubicon: PatriotJeepers.com
86 CJ7 258,T18,Scout Dana300,twin sticks,Dana44's,4W Disc, locked,35's,YORK OBA,Warn 8274,fullcage.
51 M100 1/4 ton Jeep trailer
BlueRubiconrich is offline
