Axle swap - JeepForum.com
post #1 of 4 Old 02-27-2013, 01:52 PM Thread Starter
92cherokeetj
1992 XJ Cherokee
Axle swap
How would i go about putting dana 60s under a 92 xj
92cherokeetj is offline
post #2 of 4 Old 02-27-2013, 06:17 PM
SadDayPanda
Assuming you have the right diff drop and your not wanting to shorten it.
cut all brackets from dana 60
weld new coil brackets on at the correct spacing as the old axle
weld in new shock tabs that will match your shocks
get driveshaft cut down. the diff is larger lengthwise as well.
get your drag link fit onto the axle and your steering box.
A very rough list, but you'll need a cut off wheel tool/grinder, and a welder. maybe a taper bit for the drag link, i'd had a shop do the drag link and the drive shaft.
you also need to look at camber, if the axle has good brakes, calipers, internals.
there is a lot to it and plenty of guides already.
Search button
87, 93, 95 YJ
92, 98 XJ
87 J10
SadDayPanda is offline
post #3 of 4 Old 02-28-2013, 09:06 AM Thread Starter
92cherokeetj
1992 XJ Cherokee
Thanks you make it sound easy im sure its not though but its gotta be done
post #4 of 4 Old 03-01-2013, 07:46 AM
Tomb Raider
Addicted...
Tomb Raider's Avatar
Originally Posted by 92cherokeetj View Post
....................... but its gotta be done
I'd watch out for lightning
No seriously....good luck on the swap sir.
I like to build stuff. Want to know what I build, you can google it
Tomb Raider is offline
