Arc sufficient for cage? - Page 3 - JeepForum.com
post #31 of 43 Old 08-17-2013, 07:56 PM
andrewmacc
Originally Posted by danielbuck View Post
I did try it both ways, I didn't notice a whole lot of difference, but I did pull instead of push most of the time. With mig I usually push.
"If it's got slag.. drag.."
"Chilton's and Haynes are for brake jobs, oil changes and starting campfires." - CJ7-Tim
'98 2dr/5spd Cherokee rockin' on tons, 5.9L V8 Magnum, HP60/14b, 5.13:1, locked, 14" coilovers, Dana 300 4:1 twin stick... oink oink!
andrewmacc is offline
post #32 of 43 Old 08-18-2013, 10:34 AM
freeskier93
Originally Posted by squire_wj
I know this has prob been said but being a welder by trade when people call stick or smaw welding "arc" welding that is my pet pev. Almost every type of welding is arc welding. Unless we are talking about braze welding or explostion welding or plastic welding.
There's also oxy fuel welding, electric resistance welding (spot welding), laser beam welding, electron beam welding, thermite welding, cold welding, and soldering.
freeskier93 is offline
post #33 of 43 Old 08-18-2013, 10:54 AM
squire_wj
There are all kinds of welding, I just wasn't going to start listing them all
squire_wj is offline
post #34 of 43 Old 08-18-2013, 11:52 AM
Kettles
Well, ERW is not just spot welding, almost all tubing and pipe is made by ERW at least initially; amongst other things.
_=====o000o
//__l_l_,\____\,____
l_--\_l__l_/--|lllll|
_.(o)_)__.(o)_)--o-)_)
"Dee", a Patriot Blue 2001 Cherokee Sport 4.0L High-Output
"Live Free Or Die; Death Is Not The Worst of Evils." -General John Stark
Originally Posted by speedbucket View Post
perfect depends on how far away you are when you look at it:D
Originally Posted by Millermagic View Post
It's a 4.0 ... as long as there's something in the crank case that isn't coolant I'm sure it will still run forever.
Kettles is offline
post #35 of 43 Old 08-18-2013, 01:54 PM
schitzangiggles
King of Macastan
schitzangiggles's Avatar
That is because with MIG welding there is no slag to create an inclusion in the weldment.
like others have said, 99% of the time if theirs slag you drag.
"Axeheads are supposed to be sharp, but you are one blunt tool."
FLynes
If you love wealth more than liberty,the tranquility of servitude more than the animating contest of freedom, go home from us in peace. We seek not your counsel nor your arms. Crouch down and lick the hand that feeds you. May your chains sit lightly on your shoulders and may posterity forget that you were our countrymen.
-Samual Adams
A government big enough to give you everything you want is big enough to take everything you have.
Thomas Jefferson
Calling Illegal Aliens "Undocumented Immigrants" is like calling drug dealers "Unlicensed Pharmacists"
Nemo Me Impune Lacessit
"No one provokes (attacks) me with impunity".
"Your right, the Tea Party and the OWS are the same, just like the America Revolution and the French Revolution were the same. The only problem is the American Revolution ended with Liberty, Freedom, Justice for all and a shining light upon a hill. The French Revolution ended with lynchings, guillotines, murder and socialism. So yeah, I could see how one could confuse the two..."
Mac Wilson
schitzangiggles is offline
post #36 of 43 Old 08-18-2013, 02:10 PM
squire_wj
The shop I work at we run 1/16 dual shielding flux core 100% CO2 and everyone of us push, its in the welding procedure. Gives it a much flatter profile and helps eliminates under cut.
post #37 of 43 Old 08-18-2013, 02:25 PM
AGDubyaJ
Dual shield you drag no matter what wire size or or shielding gas mixture your using. If your not getting a nice flat weld profile when dragging, turn your wire speed down a bit, or crank up the voltage a little. I run dual shield all day, everyday (mostly .045) with a 82/18 or 75/25 gas mixture. No need for manipulation either, even when welding vert. up.
98 XJ- 4.0L, NP231, AW4, chryco 8.25, 4.5" mid arm 3-link, 285/75 Herc terra tracs on moabs, V8 ZJ tie rod, fabbed bumpers...
AGDubyaJ is offline
post #38 of 43 Old 08-18-2013, 03:50 PM
squire_wj
It's the only way to avoid undercut when running 350 ipm and 28 volts. And about 90% of are welds are UT and its very rare one fails. It's in the wps to push. Also welding with 100% CO2 is a different monster then using mixed gas
post #39 of 43 Old 08-18-2013, 05:32 PM
AGDubyaJ
We switched over to mix gas because were running ESAB wire... it calls for Argon/CO2 mixture. Havent had any problems with undercut, could just be the fact that your running 1/16" wire... that stuff burns HOT.
AGDubyaJ is offline
post #40 of 43 Old 08-18-2013, 06:13 PM
squire_wj
That's exactly why and the co2 makes it really dig. But the company wants 100+ feet of weld a day so that's why we use 1/16th.
post #41 of 43 Old 08-24-2013, 07:12 PM
wgirvine
1992 XJ Cherokee
Wait... can we go back to the EXPLOSION welding? This, I gotta see....
The road goes on forever, the party never ends....
wgirvine is offline
post #42 of 43 Old 08-24-2013, 07:16 PM
squire_wj
Look it up on YouTube, its pretty sweet.
post #43 of 43 Old 08-24-2013, 07:18 PM
squire_wj
this is the video we watched when I was on school
