Arc sufficient for cage? - Page 2 - JeepForum.com
post #16 of 43 Old 08-15-2013, 04:17 PM
KMD
1976 CJ7
I would just really like to see cage that has been ARC Welded? Anyone post one up?
KMD is offline
post #17 of 43 Old 08-15-2013, 05:07 PM
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
While I don't have pics, a few years ago a buddy of mine stick welded a cage in his stretched TJ. I was totally blown away when he told me he used an Arc Welder... the welds sort of reminded me of the "stack of tacks" that some people do with a MIG. IIRC he used a 7018 Rod and was amazingly consistent with it.
He now runs his own shop "Full Awn Fabrication" up in Northern Virginia.. he's a very talented fabricator.
BESRK is offline
post #18 of 43 Old 08-15-2013, 05:51 PM
KMD
1976 CJ7
Sweet. I searched google and did not really find any.
KMD is offline
post #19 of 43 Old 08-15-2013, 07:19 PM
andrewmacc
I believe vetteboy on PBB did all the first stages of his build with an arc welder. I'm not positive if he actually did the cage with SMAW though.
"Chilton's and Haynes are for brake jobs, oil changes and starting campfires." - CJ7-Tim
'98 2dr/5spd Cherokee rockin' on tons, 5.9L V8 Magnum, HP60/14b, 5.13:1, locked, 14" coilovers, Dana 300 4:1 twin stick... oink oink!
andrewmacc is offline
post #20 of 43 Old 08-15-2013, 09:26 PM
Ironworker709
Ironworker709's Avatar
Originally Posted by Shadownwpa View Post
All these experts... it's incredible
A brief glossary:
Arc welding - Welding with the use of an electrical arc producing the heat required to melt two parent metals together with or without filler metal - includes gas metal arc welding (mig, gmaw), shielded metal arc welding (stick, smaw), and gas tungsten arc welding (tig, gtaw).... and many more.
Heliarc - Tig welding using high frequency alternating current (achf)
ALL WELDING requires clean metal to produce a sound weld, though some will show it more immediately and more visibly. Don't believe me go stick weld a groove over some grease, sand or paint and put it in a bender.
Can you weld a roll cage with stick? yea. If I had to I'd probably tack it in position, brace it, pull it out, and roll it so all the welds could be done flat for best visual appearance and penetration. I'd prefer mig though.
Since we're gettin all "Expertee" and "Techy".....lol
TIG is technicaly GTAW..Gas Tungsten Arc Welding
Heliarc is just an old knickname for GTAW using helium as the sheilding gas instead of argon or other common used sheilding gasses..
High frequency is used with AC current on TIG...frequency is how many times the AC cycles back and forth per second.......
Alternating Current is on AC,,,,,,not DC
So welding a ferrous common steel like roll cages you would be running DC..no high frequncy..and no Alternating Current......
"Arc Welding" is just another old well known knickname for stick welding (SMAW..Sheilded Metal Arc Welding)
People still use that as the knickname for SMAW...i generaly just call it stick welding...
Don't DREAM your life, LIVE your dreams
Never forget 9/11
"Welding is like a woman,Get 'er HOT and Penetrate"
Gotta LOVE a person who knows everything about NOTHING
The only Thing necessary for the Evil to win is a good man to do nothing....
"How far you go in life depends on your being tender with the young,compassionate with the aged,sympathetic with the striving,and tolerant with the weak and strong--because someday YOU will have been all of these"....George Washington Carver
Want to know what an Ironworker is and the job scope of a Journeyman?..click here...
Ironworker709 is offline
post #21 of 43 Old 08-15-2013, 09:45 PM
Ironworker709
I looked in some old pics and couldn't find any closeups of it,but stick welded both my bumpers made of a schedule 40 2" pipe with 3/32" 7018 before i upgraded from my old Lincoln 135 110v to the Lincoln 180 220v here at home...
As far as stick welding cages and such,it was the common process to use for drag racing and NASCAR among other motorsports before all these new wirefeed machines and good filler wires came out...Scratch TIG was also used if you had the money to invest in it back then...
My father and his best freind used to build and race dirt track cars in Smyrna Delaware and all the chassis and roll cages were stick welded and certified before they were allowed ro run.
I LOVE to stick weld anything..especialy pipe/tube.it was always a challenge and sort of an art ,in the early 80's i worked in a shop in Pa that built vessels and pipe work for DuPonts and i learned pipe welding there,the old guy i worked under always said"it's all in the twist of the wrist boy".
I beleive stick welding is much harder to master than TIG,always hear people say how hard TIG is,TIG is much slower and controlable..with stick you have to be able to hold a correct arc length and feed it,,angle of the rod,,watch the puddle and speed all at the same time
Stick takes a heck of a lot longer to learn than any other process to be even "acceptacle" at it...
Even though i live to stick weld..if i have a choice between a wirefeed for cages and automotive type work...wirefeed wins everytime
Never forget 9/11
post #22 of 43 Old 08-16-2013, 01:11 AM Thread Starter
takeitsleazy
thats interesting, I find stick welding MUCH easier than tig. i think it might just be the difference in pace, though. i started welding SMAW, only just recently (past couple of weeks) started tig. unfortunately my job doesnt require much welding, almost no tig. i dont even know why im being paid to learn it right now haha.
i think when i get back to the shop ill practice my pipe welds, and take it from there. good looking bumper!
2013 JK 2DR 3.6L, 1991 XJ 4DR 4.0L, Wife:2008 JK 4DR 3.8L
takeitsleazy is offline
post #23 of 43 Old 08-16-2013, 09:32 AM
KMD
1976 CJ7
Nice bumper. I agree Stick welding seems harder then TIG to me. I can stick weld and get stuff to stick together but it is not pretty and would probably never pass an inspection.
TIG I can do quite well with as well as MIG.
How about some torch welded tube work? Not brazed but actually welded. I was practicing that before I got a TIG machine,no pics though.
KMD is offline
post #24 of 43 Old 08-16-2013, 06:27 PM
danielbuck
1946 CJ2
I've got a roll of .035 NR-211 flux core wire that came with my Lincoln welder, is it worth trying other types of flux core wires, like the 233 mentioned on the first page?
danielbuck is offline
post #25 of 43 Old 08-17-2013, 12:53 AM
Ironworker709
NR-211 is more than fine
The NR-233 is designed for infrastructure in the USA now because of all the earthquakes and tornado's and hurricanes...
I never priced it myself.only ran it on jobs..i would imagine its high dollar wire and unnecesary and total overkill for anything we do at home or on vehicles
Never forget 9/11
post #26 of 43 Old 08-17-2013, 01:48 AM
danielbuck
1946 CJ2
I've not compared prices yet, but if the 211 and 233 are comparable for the home redneck, that's fine with me! I'll stick to the cheaper one
I've been having a bit of trouble though. My 211 flux core welds usually seem to look "ok" (no buggers, but not as good as my MIG welds with gas). When I use the flux core wire, I get alot of weld that have no slag on top of it to chip off. I assume this means I'm either not traveling at the right speed, or the wire feed and power isn't set right? I've tried on very clean metal, and somewhat dirty metal as well, with a bit of mill scale on it. The sound seems good to me, it's a hissing burning sound, quite a bit hotter sounding than the mig wire + gas "bacon" sound. Any ideas?
Any tips for getting better welds with the flux core wire? I assume that since I'm not getting much slag coating on top, it's mixed in with the weld, haha!
post #27 of 43 Old 08-17-2013, 03:50 PM
squire_wj
I know this has prob been said but being a welder by trade when people call stick or smaw welding "arc" welding that is my pet pev. Almost every type of welding is arc welding. Unless we are talking about braze welding or explostion welding or plastic welding.
squire_wj is offline
post #28 of 43 Old 08-17-2013, 03:58 PM
AtTheHelm
I've used HTP's e71t-gs with good results and its only $78 for two 10lb rolls.
When you're using flux core wire you always want to be pulling the puddle along in a drag motion. Not sure if thats what you've been doing or not.
AtTheHelm is offline
post #29 of 43 Old 08-17-2013, 07:50 PM
KMD
1976 CJ7
How about some thermite welds?? Fun to watch..
KMD is offline
post #30 of 43 Old 08-17-2013, 08:53 PM
danielbuck
1946 CJ2
I did try it both ways, I didn't notice a whole lot of difference, but I did pull instead of push most of the time. With mig I usually push.
