anyone used a harbor freight 18 ton pipe bender - JeepForum.com
post #1 of 24 Old 01-29-2011, 06:02 AM Thread Starter
bft89yj
hey im think of getting a 20 ton pipe bender from harbor freight and i want to see if any one has used it and weather it will cut it to bend some pipe for a stinger and maybe some one inch to make some rocker guards/ steps even if i have to use my torch to heat it befor bending thats fine with me
not so stock 89 yj on 35s
bft89yj is offline
post #2 of 24 Old 01-29-2011, 06:51 AM
yjcrawlr
It is a kinker!
90 YJ 102 in wb stretch, SOA, dana 60, 14 bolt welded,4.56s, 37in Parnelli jones dirt grips, currie twin stick dana 300, york oba, tractor link traction bar, full custom armor,poison spyder tube fenders, 95Cherokee High Output 4.0
2014 JKU, modified Rubicon Rails, RC stubby with warn 8000m, 2" leveling springs and OME trim spacers, Superchips Flashcal, Spidertrax wheel spacers, rubi shocks, and Lots more mods soon!!!
yjcrawlr is offline
post #3 of 24 Old 01-29-2011, 07:49 AM
Kettles
I haven't used it, but I have read enough about the HF pipe benders to say...
If your bending PIPE, it will probably do just fine. PIPE ≠ TUBE, they have different OD, and it will kink tube without a lot of extra work.
_=====o000o
//__l_l_,\____\,____
l_--\_l__l_/--|lllll|
_.(o)_)__.(o)_)--o-)_)
"Dee", a Patriot Blue 2001 Cherokee Sport 4.0L High-Output
"Live Free Or Die; Death Is Not The Worst of Evils." -General John Stark
Originally Posted by speedbucket View Post
perfect depends on how far away you are when you look at it:D
Originally Posted by Millermagic View Post
It's a 4.0 ... as long as there's something in the crank case that isn't coolant I'm sure it will still run forever.
Kettles is offline
post #4 of 24 Old 01-29-2011, 07:57 AM
jatepper
X2. You will kink your tubing with a pipe bender.
1986 CJ7 Laredo - Auto 14k miles
1985 CJ7 Renegade - Auto 33k miles
1982 CJ8 Scrambler - T5 T-SPD
jatepper is offline
post #5 of 24 Old 01-29-2011, 06:37 PM
Wrangler_91
I have not personally used it but I have heard that it will bend tubing ok if you pack the tubing with sand and seal off the ends. Just throwing that out there.
Wrangler_91 is offline
post #6 of 24 Old 01-29-2011, 08:09 PM Thread Starter
bft89yj
im not looking to bend like exhaust tubing i want to bend some stuff to make a roof rack and some side steps and stuff
bft89yj is offline
post #7 of 24 Old 01-29-2011, 08:25 PM
yjcrawlr
I have one it makes kinks not bends.
yjcrawlr is offline
post #8 of 24 Old 01-29-2011, 08:58 PM
bmxer0122
1987 YJ Wrangler
http://www.harborfreight.com/1-2-hal...der-94623.html
has anyone had experience with this bender? I would be using it to make a custom bumper and maybe tube fenders.
bmxer0122 is offline
post #9 of 24 Old 01-29-2011, 10:09 PM
timatoe
timatoe's Avatar
Did you see this....
Originally Posted by Harbor Freight
* Great for copper and aluminum tubing
* Bends to 180
* Handles tubing as thick as 18 gauge
* 29" handle for leverage and control
* For 1/2" and 7/8" diameter tubing
That's not what you're looking for.
timatoe is online now
post #10 of 24 Old 01-30-2011, 12:04 AM
Rutdigger
2015 JK Wrangler
You can use it..but you are going to need to do some modifications to it. You will need to make some pieces that go ontop of your shoes to keep the tube from walking up. Then you are going to have to take the shoes with you when you get your tubing and get the size that actually fits the show. Then you are going to need to fill it with sand and pack it in. It bends square tubing great after you build a show for it..lol. I used it for everything on my Jeep. Look up my projects on here they all start with "my turn to build..". If you are looking for a really cheap alternitive to buying a more expensive bender then the dies associated with it, then get this one.
You can find out more about me by visiting my website:
The more you play with it, the bigger it gets!
Rutdigger is offline
post #11 of 24 Old 01-30-2011, 07:23 AM
bmxer0122
1987 YJ Wrangler
wow i read that but for some reason it didnt register... does anyone have any recommendations for an affordable tube bender?
post #12 of 24 Old 01-30-2011, 09:08 AM
Rutdigger
2015 JK Wrangler
Well, if you are a do-it-yourself guy, which is appears you are, then there is a guy selling plans for one hereTube Bender I have these plans and this is a VERY good bender. All in all it will cost you are bout $350ish to make. But when you are done you will have yourself a great tube bender!
Click on the link then click "proceed to website"
post #13 of 24 Old 01-31-2011, 10:18 AM
93yj_1
i bought one and only use it for construction now lol. wast of time and money!
1993 YJ 4.5 Rough country lift, no sway, 31" with steelies, and much more to come.
93yj_1 is offline
post #14 of 24 Old 02-03-2011, 01:37 PM
TheNewbie
I got one and tried to bend some 1" conduit. It folded it in half and the bender went back to HF.
1995 YJ 2.5 - 4 RC lift - 1" MML - 33's - flat fenders front - TJ flares rear -Raptor lined exterior - Herc'd interior - DIY front bumper & winch plate - 136 amp alternator mod - 4.0 TB swap
I've got a shotgun, a rifle and a four wheel drive...
TheNewbie is offline
post #15 of 24 Old 02-03-2011, 03:23 PM
mark123
believe it or not I did some nice 90 degree bends with 1" and 3/4" sch 40 aluminum pipe with one of these benders. The trick was to aneal it first. I blackened the bend areas with acetylene only and then burnt the soot off with a neutral flame (the temp neede to burn soot is close to the anealing temp needed) and as soon as the soot was gone I quenched the pipe in cold water. After that it bends nicely.
mark123 is offline
Harbor Freight "bender"? Hussler Fabrication Shop 6 11-10-2010 06:17 PM
Harbor freight frumpy General Jeep & Off-Road Equipment 20 12-09-2007 08:09 PM
Harbor Freight cs1094 General Jeep & Off-Road Equipment 35 02-15-2007 07:56 AM
Harbor Freight ? TJ_with_Tusks General Jeep & Off-Road Equipment 2 12-25-2006 02:41 PM
Harbor Freight Tube Bender Muddy Tj Zack Fabrication Shop 6 06-23-2006 08:28 AM
