Anybody own a cnc plasma or waterjet? - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Fabrication Shop > Anybody own a cnc plasma or waterjet?
Currie RockJock Products!!This is a shout out to all INTERNATIONAL Customers! Yes weEngo winches available at www.rockridge4wd.com! Free shipp
Unread 06-14-2014, 10:43 PM   #1
BCrawford64
I need a logo cutout of 16ga steel. It needs to be about 6" wide. Can anybody do this for me? You will be compensated.
BCrawford64 is offline   Reply With Quote
Unread 06-15-2014, 07:53 PM   #2
jbryant
Junior Member
jbryant's Avatar
Do you have a dxf file of what you want?
2000 TJ 5.2/46re, Zone 4.25, 35" Goodyear MTR's w/Kevlar
jbryant is offline   Reply With Quote
Unread 06-15-2014, 08:14 PM   #3
sbsg2005
How big and a .dxf or good quality picture and and I'll get ya a quote worked up.
sbsg2005 is offline   Reply With Quote
Unread 06-16-2014, 12:06 PM   #4
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
Can you post a jpeg of the logo?...
Ground Pounder Fab
Lower 2
Guardrail
Down Schoolbus
Slickrock Tellico
Save
Crozet
More Crozet
BESRK is offline   Reply With Quote
Unread 06-16-2014, 06:38 PM   #5
BCrawford64
Here it is. Sorry but it's only .png but can easily be converted to .jpeg, I actually changed my mind and want it around 8" wide.
Those white dots are where I need small holes so it can be tack welded to steel.
It's going to be placed on a speaker box. The font is from dafont.com and the name of the font is Yikes! Thanks guys.
Unread 06-17-2014, 01:35 AM   #6
athos76
That picture is going to need some work before it can be cut. The letters will have to be turned to stencils. I'll try to convert it tonight to make it easier for someone else
2006 I6 6-Speed X, 33" Goodyear Duratrac, 8.8.
athos76 is offline   Reply With Quote
Unread 06-17-2014, 08:19 AM   #7
el_magico
1995 XJ Cherokee
Stenciling would not be necessary for this project. If he wanted the wording to be cut out of a flat plate kind of like a license plate he would need it that way. But the Black portion is the keep and all the White is the drop. Everything else is connected fine.
1995 XJ Sport 4.0L (Nothing special to list yet)
el_magico is offline   Reply With Quote
Unread 06-17-2014, 05:32 PM   #8
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
Did a quick DXF.. lower left. I would drill the holes for the tack welds.. just to make sure you don't get pinholes.
Ground Pounder Fab
Lower 2
Guardrail
Down Schoolbus
Slickrock Tellico
Save
Crozet
More Crozet
Unread 06-17-2014, 06:15 PM   #9
BCrawford64
Yeah sounds like a good idea.
Unread 06-17-2014, 06:33 PM   #10
burke_78
I have a friend in Tucson that has a CNC plasma that he has gotten dialed in to cut very very clean
Stellar Machine & Performance
(520) 481-6946
you could give them a call and see if Tim can help you out.
burke_78 is offline   Reply With Quote
Unread 06-27-2014, 04:02 PM   #11
WSS
Ps:91
WSS's Avatar
1972 CJ5
Just noticed your request, still need it? I can draw/cut/ship 4pcs out of 16ga for 50 smackers. the next batch would be cheaper of course, no drawing time
www.metaltechus.com
Our Yellow 72 CJ5 build thread
Yellow Jeep club member #73802
WSS is offline   Reply With Quote
