Any welding tips for a total newbie? - JeepForum.com
post #1 of 15 Old 02-03-2011, 01:31 PM Thread Starter
TheNewbie
I have a cheap crappy Harbor Freight flux core welder. I've screwed around a little bit just to get a feel for it before doing my tube fenders. But some actual expert advice would be appreciated.
It only has 2 settings... high and low. And I'll be welding thin metal to 1 1/2" .120 tube.
1995 YJ 2.5 - 4 RC lift - 1" MML - 33's - flat fenders front - TJ flares rear -Raptor lined exterior - Herc'd interior - DIY front bumper & winch plate - 136 amp alternator mod - 4.0 TB swap
I've got a shotgun, a rifle and a four wheel drive...
TheNewbie is offline
post #2 of 15 Old 02-03-2011, 01:55 PM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
I bought a Welding textbook from the local Vo-Tech. Try on-line for a used textbook. Miller, Lincoln or Hobart has some short videos and FAQ's for welding on their website.
Practice, practice, practice. Cut apart your practice and see if you have good penetration.
Welding sheet metal, you have to use short 1/2- 1" stitch welds to prevent warping the sheet metal.
Beter quality welders are easier to use and make better welds.
CJ7-Tim is offline
post #3 of 15 Old 02-03-2011, 01:56 PM
MONSooNmonkey
Practice Practice Practice Practice Practice Practice Practice Practice Practice Practice Practice Practice Practice Practice Practice Practice Practice
oh and a steady hand goes a long way + good ventilation, have a fan on you or at least your face to keep the fumes away from your lungs. fumes = bad + will give you a headache for a few days if you get enough, ask me how i know
Sadface :(
MONSooNmonkey is offline
post #4 of 15 Old 02-03-2011, 01:57 PM Thread Starter
TheNewbie
So weld and inch, skip 3", weld one, skip 3... Then come back and fill in the middle sections and inch at a time once it's cooled?
post #5 of 15 Old 02-03-2011, 01:58 PM Thread Starter
TheNewbie
Oh, and should I set it to low or high? Low would be my guess, but I don't want to screw this up.
post #6 of 15 Old 02-03-2011, 02:20 PM
MONSooNmonkey
Always weld to the thinner material. So if you burn through the sheet on high use low and move a bit slower.
Sadface :(
post #7 of 15 Old 02-03-2011, 02:51 PM
CJ7-Tim
CJ7-Tim's Avatar
Yes.
CJ7-Tim is offline
post #8 of 15 Old 02-04-2011, 05:23 AM
JokerZero
Start off by getting rid of that Harbor Freight. Made that mistake it burns through sheet metal and isn't strong enough to weld thicker guages. Maybe it's just me but I use a Lincoln and Miller at work with gas assist and those things are literally plug and play anyone can run a solid bead with them. On the other hand my buddy loves his Harbor freight so it could be personal preference
95 YJ Crooked Tooth
Triple 6/Wreckin Krew
JokerZero is offline
post #9 of 15 Old 02-04-2011, 06:40 AM
RJMICP
your harbor freight will work just fine for what you're using it for... I have the same machine, but let me give you some advice... get rid of the cheap POS flux core that it came with, and get yourself a spool of Lincoln wire... I recommend 0.035... you can pick it up at Home Depot for about 13 bucks... I'm doing a rocker panel and floor pans once the weather breaks...
RJMICP is offline
post #10 of 15 Old 02-04-2011, 01:03 PM
ldso
X2 practice and have ventilation. I am a newbie still, but it is getting easier.
I found a local place that sells by the pound not by the piece, they sell me tubing and plate scraps for .25/lb. I can make stuff, decide it looks ugly, and start over real cheap. Just find a simple project to start. Mailbox holder? Bird feeder? Cargo rack?
The ventilation is no joke. If you have brake cleaner on the steel when you weld, the smoke that comes off of it is poison. It will make your organs shut down. Be careful! Even in winter I open two doors to the garage and try to keep my face out of the path of the smoke.
Think about it, you are using electricity and gases to make carbon molecules change how they bind to things. Very powerful and cool stuff
I am having fun with it, I'm using the $100 Harbor Freight stick welder. I've gotten good enough to do a few things to the Jeep. But I have other fun projects in mind too, like making big house numbers for the front of the house from steel plate, maybe like a big metal dinosaur, or something
1995 YJ "Mabel", 2.5L Muncie SM465 np231j 4.88's HP30 Lockright JK 44 Detroit 33s CJ clip
Actually, it's pronounced "mill-e-wah-que" which is Algonquin for "the good land."
ldso is offline
post #11 of 15 Old 02-04-2011, 01:51 PM
MONSooNmonkey
^^ does said local place ship?
Sadface :(
post #12 of 15 Old 02-04-2011, 08:42 PM
stuff2c
clean clean clean... if it ain't clean it needs to be...REAL CLEAN, I don't know crap about welding! but i do know this one. and like they have already said... do not breath the stuff.
Thanks to the interstate highway system... most people don't see nut'n in the USA.
stuff2c is offline
post #13 of 15 Old 02-05-2011, 02:28 PM
CoryA
Best welding tip right here
take a class at your local community college
pretty cheap hopefully a good instructor, access there machines materials
most let you bring in your own projects and will help you along the way
I've learned a ton by doing this
CoryA is offline
post #14 of 15 Old 02-05-2011, 03:14 PM
ScottHightower
I hate to be redundant but practice as much as you can.
One thing newbies seem to forget is to watch the puddle. If you keep an eye on the puddle you will see the metal melting and know that you have good penetration. Work the nozzle in a circular or back and forth "U" pattern to make sure you tie in both parts. Be careful to keep your wire in the puddle at all times. If you jump out of the puddle you are moving too fast. If you are blowing through you are moving too slow.
The final test is a destructive test. Weld two parts together, clamp one part in a giant vise, then smash the second part with the largest sledge hammer you can find. Eventually the two parts should separate but the weld should be in tack. If the weld is good the metal adjacent to the weld will tear first.
Scott
Fab Manager
Welders360.com
ScottHightower is offline
post #15 of 15 Old 02-05-2011, 05:01 PM Thread Starter
TheNewbie
Good tips here. Thanks guys.
Stick welding tips Hesher420 Fabrication Shop 61 04-13-2010 03:14 PM
Vertical Welding tips CoriolisSTORM Fabrication Shop 10 08-10-2008 12:14 PM
Tips and suggestions for MIG welding (?) jgorm Fabrication Shop 16 10-17-2007 03:24 PM
Stick welding- Some tips? Ryanpowell167 Fabrication Shop 3 05-09-2007 08:58 PM
I need Mig Welding Tips Tri_X_Troll Fabrication Shop 8 12-08-2004 03:20 PM
