any one know source for these ? - JeepForum.com
post #1 of 8 Old 12-30-2013, 12:37 PM Thread Starter
SMT73
1987 YJ Wrangler
I am building new wheelwell boxes for the rear of my yj in the near future that go almost to the top of the body sides. I will have to rig up a homemade makeshift metel brake for this.....
I would rather buy them if it makes financial sense.
Anyone know somewhere that makes them...
SMT73 is offline
post #2 of 8 Old 12-30-2013, 12:59 PM
athos76
http://www.tuffyproducts.com/p-87-sp...ar-cutout.aspx
2006 I6 6-Speed X, 33" Goodyear Duratrac, 8.8.
athos76 is offline
post #3 of 8 Old 12-30-2013, 01:42 PM Thread Starter
SMT73
1987 YJ Wrangler
Thanks for the response , but in my haste i see i wasnt clear on what i was doing...
I am replacing the entire rear wheelwell with the top almost even with the top of the body so i can enlarge my wheel opening to stuff the tire more.
Just like Jp magazine used in their whole "no lift on 40's wrangler", then do mention M.O.R.E., but i cant find them, maybe they stopped making them.
Just looking if someone makes them so i dont have to try not screwing them up.
SMT73 is offline
post #4 of 8 Old 12-30-2013, 05:13 PM
athos76
Ah, ok. I thought you meant storage boxes. In that case, I think fabbing your own would be more cost effective. Use some posterboard to mock up what you want for a template, and get some 18g or 16g steel and cut it out. You can use clamps and some angle iron to make the bends, or find a fabrication shop in the area to make the bends for you.
athos76 is offline
post #5 of 8 Old 12-30-2013, 08:54 PM
schitzangiggles
King of Macastan
schitzangiggles's Avatar
Instead of poster board, use foam bard for picture mounting, more rigid, weighs less and is easy to cut. Do you have a steel supplier? they can cut and bend it for you. My local place charges $5 per cut and $7.50 per bend for 10 gauge steel which is overkill for an inner fender well. I would also tack in or have some one roll in some bends to stiffen the assembly as it needs some rigidity because your cage mounts to it. Or, you can weld some angle iron that wraps the corners to stiffen it. Actually if you can source angle iron cheap enough, you can build a frame out of angle iron and weld in the sheet metal to it and you don't even need a brake or have it bent. 3/16x1.5in would be more than enough and runs me about $10 for a 20ft stick of it.
"Axeheads are supposed to be sharp, but you are one blunt tool."
FLynes
If you love wealth more than liberty,the tranquility of servitude more than the animating contest of freedom, go home from us in peace. We seek not your counsel nor your arms. Crouch down and lick the hand that feeds you. May your chains sit lightly on your shoulders and may posterity forget that you were our countrymen.
-Samual Adams
A government big enough to give you everything you want is big enough to take everything you have.
Thomas Jefferson
Calling Illegal Aliens "Undocumented Immigrants" is like calling drug dealers "Unlicensed Pharmacists"
Nemo Me Impune Lacessit
"No one provokes (attacks) me with impunity".
"Your right, the Tea Party and the OWS are the same, just like the America Revolution and the French Revolution were the same. The only problem is the American Revolution ended with Liberty, Freedom, Justice for all and a shining light upon a hill. The French Revolution ended with lynchings, guillotines, murder and socialism. So yeah, I could see how one could confuse the two..."
Mac Wilson
schitzangiggles is offline
post #6 of 8 Old 12-30-2013, 08:55 PM
schitzangiggles
King of Macastan
Here is the article the OP is referencing.
http://www.fourwheeler.com/project-v...angler-part-1/
FLynes
-Samual Adams
Thomas Jefferson
Mac Wilson
post #7 of 8 Old 12-30-2013, 09:21 PM
Jeffro06
Jeffro06's Avatar
I can't get past the title "1994 Jeep Wrangler TJ - No lift Wrangler, Part 1".
TJ's started in 97.
Hopefully they are doing some sort of YJ/TJ combo.
Jeffro06 is offline
post #8 of 8 Old 12-31-2013, 08:23 PM
schitzangiggles
King of Macastan
Editors miss things. I love how a 1" body lift and lift shackles is a no lift for 40" tires.
I have waggy springs and 36" tires so an honest 2" lift with no body lift and I am in process of highlining my hood for the front and I will most likely pick up a 120mm mortar can to build my inner rear fender tops out of.
FLynes
-Samual Adams
Thomas Jefferson
Mac Wilson
