any one ever make a cage for a cj or wrangler with out a pipe bender - JeepForum.com
post #1 of 13 Old 11-03-2008, 02:14 PM Thread Starter
extremecj7
1978 CJ7
any one ever make a cage for a cj or wrangler with out a pipe bender if so lets see descriptions and pics.....
ps. sorry if this thread already exists thousands of threads back
mud pits are like a hot chick w/ std's,you wanna hit it, but your scared of the consequences
extremecj7 is offline
post #2 of 13 Old 11-03-2008, 02:54 PM
frumpy
frumpy's Avatar
I don't know if it has or hasn't. But if you do... have fun.
2002 Dodge Dakota quad cab V8
2011 Dodge Grand Caravan
frumpy is offline
post #3 of 13 Old 11-03-2008, 09:08 PM
skullver
Tarpitz
1991 XJ Cherokee
pipe benders are for ....pipe. You must be talking about a tubing bender, made for bending structural tubing.
If you are thinking of miter cuts/welds in place of bends......boy, I would not even think about it, there is nothing safe about that! Really you would only need a few bends though so it is not the end of the world, you can get pre-bent hoops if you don't want to spring for the bender. Hopefully I misunderstood your question.
Blah blah blah blah.
my Jeepspeed build thread:
skullver is offline
post #4 of 13 Old 11-04-2008, 07:35 AM
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
I saw a picture of a rig that was built with all "straight tubing".. it looked strong engough... but really low rent.
BESRK is offline
post #5 of 13 Old 11-04-2008, 07:44 AM
Contra
i think he means bending without a tubing bender
say by heating up and bending round a rotor or such...
Ever Gone Geocaching?
Contra is offline
post #6 of 13 Old 11-04-2008, 07:59 AM
Unlimited04
This post/info=my opinion
Unlimited04's Avatar
thats a really good way to kink and ruin some expensive tubing.
i suppose you could do a straight pipe cage with LOTS of gussets at every corner. i think it would be easier to source a bender locally...like check local forums, local shops, etc. Have a local shop bend you some tubing to your specs, shouldn't cost much. If you find a local guy with a bender, bring lots of beer. you don't need to buy a bender, just need to borrow one for a few days....beer is payment enough for many folks.
Useful Write-Ups:
Fabrication & Build:
Funny:
Unlimited04 is offline
post #7 of 13 Old 11-04-2008, 10:32 AM
OldFatGuy
You could thread the ends of the pipe and use plumbing fittings to put it together.
OldFatGuy is offline
post #8 of 13 Old 11-04-2008, 12:39 PM Thread Starter
extremecj7
1978 CJ7
well i found a garage to bend the pieces of tube i need bent thanks for everyones input
post #9 of 13 Old 11-05-2008, 06:17 AM
yellojeeper
yellojeeper is offline
post #10 of 13 Old 11-05-2008, 06:36 AM
jamaicanmecrazy
1994 ZJ
Call Taylor rental and see if they have one that can be rented.
They carry axle and bearing tools so I would give them a call. Some dealers carry more than others.
jamaicanmecrazy is offline
post #11 of 13 Old 11-07-2008, 03:31 PM
conrasm
conrasm's Avatar
Doesn't heating the tube to bend it sacrafice it's stregth as well?
Shawn
'00 TJ Sahara (RC 4" LA kit)
'06 Grand Cherokee Limited
'07 Ram 1500 quad cab
conrasm is offline
post #12 of 13 Old 11-08-2008, 03:48 AM
jamaicanmecrazy
1994 ZJ
Sure does but some will argue. Why because they are afraid to roll it over and test it and prove others right.
post #13 of 13 Old 11-08-2008, 08:49 AM
Unlimited04
yes it does. it lowers the yield stress and elastic modulus (meaning it becomes more ductile and less brittle)
bending cold steel 'cold works' it - http://en.wikipedia.org/wiki/Work_hardening
Cold working the metal increases the yield strength and reduces ductility. Meaning it requires a larger force to break the steel, but it is more brittle.
Useful Write-Ups:
Funny:
Tube/Pipe bender quality, price and purpose Godchsr Fabrication Shop 4 02-27-2009 08:40 AM
custom exhaust from home.. certain pipe bender? TXjeepTJ Fabrication Shop 2 12-01-2006 11:49 PM
Pipe Bender Miterez Fabrication Shop 1 07-27-2005 09:24 PM
Pipe Bender M/TR Man Fabrication Shop 7 02-12-2005 11:58 AM
Wrangler sport cage advice yjrebel General Jeep & Off-Road Equipment 6 07-28-2003 12:46 PM
